Risk / benefit Analysis in Risk Management Report
#11
Hello, I work in requlatery medicens lab , I want to ask about Risk Mangement:
  • ISO31000 vs ISO 17025
  • What the risk policy of acceptability criteria for pharmacy lab
  • How Idintefy the scope and goals and classify and analysis of strengths and weaknesses by SWOT analysis
  • How identify the interested parties. Thanks
Ronen E
Problem Solver
Moderator
#12
hello,
does anybody have example of risk-cost-benefit for re-use and re-sterilization of “long time on market” single use medical devices, any guidance please?
(14971: 2012- 6.5)
Not sure what cost has to do with it... S. 6.5 talks about comparing residual risk against medical benefits.
Have you looked at Annex D.6?
#13
Risk / benefit analysis for each risk.
Is there an example?
There is no example since everyone shall be applying risk management for their devices in a different method. however please go through some of the points below:
1. Risk vs benefit is not applicable for all the risk since you might have already mitigated some of the risks to lower RPN.
2. Risk vs benefit is done only when there exists a risk after mitigation which is beyond your acceptable tolerance.
3. You need to specify the risk and what are its end level effects can be declared as side-effects in the IFU.
4. Benefits have to be specified as intended use is also acheieved (Performance evaluation report might be required.)
5. Thus you give the final statement that since benefits outweigh the risk we accept the risks.
E.g. Iodine bandages when used for bigger wounds can create Iodine-induced Hypothyroidism. Although if bandages changed every 8 hours to normal bandages alternately minimizes the probability of this phenomenon. Nevertheless,the benefit of using a iodine bandages leads to faster healing.
IFU shall state: bandages changed every 8 hours to reduce Iodine-induced Hypothyroidism.
Hope it helps.
A Risk-benefit Analysis - Hazard Analysis (HA) and FMEAs ISO 14971 - Medical Device Risk Management 17
W Risk Benefit Analysis - ISO 14971:2012 Requirements ISO 14971 - Medical Device Risk Management 27
C Help with Risk/Benefit Analysis Self-help Device for Diabetics ISO 14971 - Medical Device Risk Management 3
J Does anyone have an example of Risk-Benefit Analysis per ISO 14971? Other ISO and International Standards and European Regulations 2
M Estimating the benefit-risk ration under MDR EU Medical Device Regulations 1
M Informational Final guidance – GUIDELINES on the benefit-risk assessment of the presence of phthalates in certain medical devices covering phthalates which are carc Medical Device and FDA Regulations and Standards News 0
M Informational FDA discussion paper – Consideration of Benefit-Risk Approaches for Weight-Loss Devices Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
M Informational EU – 12th Meeting of the Working Group on Guidelines on benefit – risk assessment of Phthalates in Medical Devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – SCHEER – Minutes of the Working Group meeting on guidelines on the benefit-risk assessment of the presence of phthalates in certain medical devic Medical Device and FDA Regulations and Standards News 1
M Medical Device News FDA News - 14-09-18 - Benefit-Risk Factors to Consider for Substantial Equivalence Other US Medical Device Regulations 0
M Medical Device News FDA news - 05-09-18 - Draft - Uncertainty in Benefit-Risk Determinations Other US Medical Device Regulations 0
A MDSAP benefit for manufacturer of low-risk devices Canada Medical Device Regulations 3
AnaMariaVR2 Structured Approach to Benefit-Risk Assessment in Drug Regulatory Decision-Making Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
sagai New Draft Guidance from FDA - Factors considered for Risk/Benefit Determination Other US Medical Device Regulations 4
D Importing a general wellness low risk product Other US Medical Device Regulations 3
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
M Risk managment report of Surgical Mask Example ISO 14971 - Medical Device Risk Management 14
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 7
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
F Risk for Quality Assurance Department in a Hospital - Hospital Incident Reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
B Risk Assessment Checklist for Non product Software IEC 62304 - Medical Device Software Life Cycle Processes 1
K Identification of hazards and Risk file IEC 62366 - Medical Device Usability Engineering 7
S Risk based internal auditing Internal Auditing 6
Robert Stanley I'm @ RISK of not showing my RISKS! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
adir88 Information of safety can reduce risk now? ISO 14971 - Medical Device Risk Management 12
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 5
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 14
Tagin Is SARS-CoV-2/COVID-19 on your risk register? Misc. Quality Assurance and Business Systems Related Topics 11
D IEC 62304 Risk Classification - With and without hardware control IEC 62304 - Medical Device Software Life Cycle Processes 2
J ISO 14971 applied to ISO 13485? Low risk class 1 devices ISO 13485:2016 - Medical Device Quality Management Systems 3
DuncanGibbons Classification of aerospace parts depending on their risk and criticality etc. Federal Aviation Administration (FAA) Standards and Requirements 3
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
M Risk Classification For Supplier - Clinical Research Organisation (CRO) Supply Chain Security Management Systems 3
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
MrTetris Unacceptable risk and information for safety ISO 14971 - Medical Device Risk Management 16
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
B ATP 5-19 "Risk Management" Misc. Quality Assurance and Business Systems Related Topics 2
