Risk Management for Medical Software?
temujin
#11
QMS Eager might be referring to this draft:
ISO/PRF TS 29321 :
Health Informatics -- Application of clinical risk management to the manufacture of health software
regards
t.
Jen Kirley
Quality and Auditing Expert
#12
Thanks heaps Roland!
We have of course validated the software in terms of accurate functions, algorithms used within the software in order to deliver accurate output, as well as easy to interpret and accurate user interfaces.
We have also evaluated our software regarding risks with wrong or faulty input and eliminated such risks by means that we do not handle input containing the wrong parameters. However, we have not done much concerning the QUALITY of the input vs the QUALITY of output (assuming right input but with poor resolution). Of course our software still performs the right algortihms and calculations even though the QUALITY of the input is poor, but the output might not be good enough for diagnosis. Looking at that issue, the final output from our software might be insufficient for diagnostics and hence lead to faulty diagnosis due to insufficient quality of the original input. Can those risks be considered eliminated only be defining the desired quality of the input data? Still a forseeable misuse would be to use input with poor quality, wouldn´t it?
Yes, inaccurate diagnostics resulting from poor resolution capabilities in software is one type of risk of poor software quality. The risk is not eliminated by defining the quality, as in setting the gates, but by sharpening the resolution.
And yes, it's forseeable to misuse software, resulting in poor diagnosis. For example, if settings must be input by the operator and the method/setting type is not clear; that is, the operator can't figure out how to make the setting, or sets the software to 8 when it should be 10. That's a rough sketch of the subject.
So yes, both accuracy and usability are risk factors, though usability is not a risk the developer carries responsibility for so much as the accuracy: the ability for the software to perform to the intended function.
Some threads of related subjects are listed at the bottom of this page, if you would like further reading.
alexander73
#13
Thanks for your reply, I will revise the suggested documents!
Our product is pure software used by radiologists for medical imaging post-processing. It is used to perform data analysis and visualizations based on medical images. Hence, there is no monitoring involed and no immediate life-threathening risks involved while using the software. However, the software and it´s resulting output will form the basis of the diagnosis and as far as I can understand we still have to consider risks associated with wrong diagnosis based on hazards/defects in our software output. Here are where things start to be complicated. Or is it as easy as implement test protocolls confirming that all functions deliver output as expected, or do we have to evote the software in a larger context?
Where did you come from? Our companies have the same application domain, but we defended 13485, 14971 and CE in 2007-2008. And, you know, we had hard time sweating and slaving. Is it 3-4 months enough to solve this problem? Though to my knowledge Notified Bodies are softer to small companies :)
Q
QMS eager - 2010
#15
The document is describing how to implement ISO 14971 for medical software. I dont have the possibility to share the file as it´s under control of copyright. We bought it from the organisation developing it. Unfortuneately I can not share the name or price with you as the person responsible currently has vacation.
Q
QMS eager - 2010
#16
The Title of the document is:
IEC/TR 80002-1 Ed.1: Medical device software – Guidance on the application of ISO 14971 to medical device software
Im sorry about the similar posts previously, I didn´t recognize that the Discussion was continued on additonal pages and kept on thinking that my posts weren´t posted...
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
R Risk Management in the Medical Device Industry ISO 14971 - Medical Device Risk Management 4
M Informational ISO TC 210 IEC SC 62A JWG 1 Medical device risk management – São Paulo meeting 2019 Medical Device and FDA Regulations and Standards News 6
M Medical Device News ISO TC 210 IEC SC 62A JWG 1 Medical device risk management – São Paulo meeting 2019 Medical Device and FDA Regulations and Standards News 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
S Medical Device Cybersecurity Risk Management File ISO 14971 - Medical Device Risk Management 2
O Medical Device EMC Risk Management CE Marking (Conformité Européene) / CB Scheme 4
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
T Using Risk Management in ISO 10993 - Medical Device Accessory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J What ever happened to Medical Device Risk Management, anyway? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
A Implementing Risk Management in a Medical Device "Distributor Only" company ISO 13485:2016 - Medical Device Quality Management Systems 2
Marc Are you looking for ISO 14971 - Medical Device Risk Management? Risk Management Principles and Generic Guidelines 1
N Risk Management for 510k Exempt Class I Medical Device ISO 14971 - Medical Device Risk Management 7
A FDA Guidance for Risk Management for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N Medical Device Failure Rate as part of the Risk Management Report ISO 13485:2016 - Medical Device Quality Management Systems 10
E Risk Management Methods in Medical Device Component Manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14971 Medical Device Risk Management FAQ ISO 14971 - Medical Device Risk Management 38
Q Advice about Risk Management for a Medical Device Distributor ISO 13485:2016 - Medical Device Quality Management Systems 7
T Risk Management in a very small low tech, Class 1 Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
N Minor Concern - Medical Device Software and Risk Management ISO 14971 - Medical Device Risk Management 2
A Where can I buy EN ISO 14971:2009 (Medical Device Risk Management)? ISO 14971 - Medical Device Risk Management 11
Q ISO 14971 Class II Medical Devices - Product Realization & Risk Management ISO 14971 - Medical Device Risk Management 5
Marc The FDA and IEC 80001-1 (Risk Management for Medical Device IT networks) Other Medical Device Related Standards 2
I PFMEA RPN Numbers Medical Device Risk Management FMEA and Control Plans 1
K ISO 62304 Software Risk Management and Medical Device Class IEC 62304 - Medical Device Software Life Cycle Processes 5
R Rate the Effectiveness of Risk Management in the Medical Device Industry Other Medical Device and Orthopedic Related Topics 7
bio_subbu Supply Chain Risk Management for the Pharmaceutical and Medical Device Industries ISO 14971 - Medical Device Risk Management 2
T Medical Device Risk Management Plan ISO 14971 - Medical Device Risk Management 11
M Link between Risk Management, Usability Engineering and R&D in Medical Devices ISO 14971 - Medical Device Risk Management 2
M ISO 14971:2007 Risk Management - Class I A Sterile Medical Device ISO 14971 - Medical Device Risk Management 4
Q Books / Literature: Risk Management for Medical Device Software recommendations Other Medical Device and Orthopedic Related Topics 4
V ISO 14971:2007 Application of Risk Management to Medical Devices ISO 14971 - Medical Device Risk Management 9
D Risks related Wire & Cable for Electronic Medical device - Risk Management Other Medical Device and Orthopedic Related Topics 1
Y Risk Management Plan for Medical Device - ISO 14971 ISO 14971 - Medical Device Risk Management 1
M Risk Management for Class I Medical Devices? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Software to Manage Compliance to ISO 14971 (Medical Device Risk Management). ISO 13485:2016 - Medical Device Quality Management Systems 9
R Medical Device Software Risk Management and ISO 14971:2007 ISO 14971 - Medical Device Risk Management 7
W Application of Risk Management - ISO 14971:2007(E) Medical Devices ISO 14971 - Medical Device Risk Management 69
J FMEA "Types" - ISO 14971 (Medical Devices - Application of Risk Management) ISO 14971 - Medical Device Risk Management 7
Q Risk Management Plan for a Class III Medical Device (Bone Void Filler) ISO 13485:2016 - Medical Device Quality Management Systems 5
A ISO14971:2001 - Risk Management for Medical Devices - Help need copy ISO 14971 - Medical Device Risk Management 10
I Applicability of Risk Management for Medical Devices - ISO 14971:2000 ISO 14971 - Medical Device Risk Management 20
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
S Risk Management and other Files ISO 14971 - Medical Device Risk Management 8
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
