Risk Management Plan Template - ISO 14971:2007 Compliant
rob73
looking for answers
#11
Mor628
If your complaint is non-product related i.e. missing inspections, then using the RM (ISO 14971) would not be appropriate.
Depending on how your QMS system is set up, you should be raising a corrective action (CAPA) to detail any containment, corrective or preventative actions, as well as a root cause/risk analysis. (i use the term "risk analysis" loosely here as this could mean a full process FMEA or a quality engineer listing the possible outcomes from the issue.)
If you are unsure about CAPA a quick search of elsmar will give you plenty to read.
Marcelo
#12
From what the auditor asked me, I understand that a customer complaint (or any post-production information) should feed back into the risk management process.
It may need to be fed back into RM (as a lot of other info). However, I would take care in feeding it back directly without evaluating if it really needs to be fed back. This usually means including an evaluation in the complaint decision flowchart to ask the question "Does this need to be fed back in the RM process"? Also, please see 4 - Production and post-production feedback loop in ISO TR 24971.
My question is where does it feedback to? Back to Residual risk, where I assess whether the failures identified in the complaint have been covered in the residual risk? And if they have what would be my next step?
Focusing on your example of failure, you would need in principle to verify if the failure is already identified in the risk analysis, not residual risk. If it's already identified, one of the questions to ask is, is that failure under our predicted failure rate? If it's not identified, I would ask "Why has it new been identified? Is it a new problem or is there a problem with my RM process?"and then I would need to initiate a risk analysis using this failure as an initiating event, for exemple.
Please not that the "where"really depends on the analysis of the problem, you may need to fed it back at different steps in the process depending on the problem.
Mor628
#13
Dear Marcelo,
Happy New Year to you!
Thanks for taking the time to explain this to me, especially pointing out the ISO TR 24791, such a good read! I really needed that.
Just following up with my last question, if the failure is under the predicted failure rate, then there is no further action taken?
Also, if I am using customer complaints to identify failures, and there is no root cause for that particular complaint, what would be the next step? For example, customer complaints about latex foley catheter balloon not inflating. However, when we test the samples and find no malfunction, do I then still need to view it as a potential hazard? Or do I do that only when my investigation has shown a genuine malfunction of the catheter balloon?
Ronen E
Problem Solver
Moderator
#14
Dear Marcelo,
Even if there's no technical malfunction it doesn't mean that there's no root cause. This can be a usability (use error) issue.
There is always a root cause. We just don't know it / can't identify it properly sometimes.
adir88 MDR requirement: Risk Management Plan for "each device" ISO 14971 - Medical Device Risk Management 5
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Non conformance Report to Risk Management-Plan ISO 14971 - Medical Device Risk Management 16
U Product Level Software Risk Management Plan and Report ISO 14971 - Medical Device Risk Management 2
E How to write a Validation Risk Management Plan for Equipment ISO 14971 - Medical Device Risk Management 5
T Medical Device Risk Management Plan ISO 14971 - Medical Device Risk Management 11
T Developing the Risk Management Plan - Risk Management Policy and Objectives ISO 14971 - Medical Device Risk Management 25
Y Risk Management Plan for Medical Device - ISO 14971 ISO 14971 - Medical Device Risk Management 1
T Risk Management Plan for a Mature Product - ISO 14971 ISO 14971 - Medical Device Risk Management 2
Q Risk Management Plan for a Class III Medical Device (Bone Void Filler) ISO 13485:2016 - Medical Device Quality Management Systems 5
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
S Risk Management and other Files ISO 14971 - Medical Device Risk Management 8
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B ATP 5-19 "Risk Management" Misc. Quality Assurance and Business Systems Related Topics 2
N Risk Management besides mandated FDA requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Identifying Hazards - Risk management process ISO 14971 - Medical Device Risk Management 6
R Risk Management in the Medical Device Industry ISO 14971 - Medical Device Risk Management 4
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
Ronen E The unbearable insensitivity of risk management language Other Medical Device and Orthopedic Related Topics 1
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A Defining Expected Service Life in Risk Management File Reliability Analysis - Predictions, Testing and Standards 5
R Linking the Processes of Continual Improvement, Change Management, Risk Management, Action Planning, etc? Preventive Action and Continuous Improvement 5
D Risk management according to ISO 14971 - When to document risk controls? ISO 14971 - Medical Device Risk Management 10
J Software for Techfiles and Risk management ISO 14971 - Medical Device Risk Management 1
M Informational ISO TC 210 IEC SC 62A JWG 1 Medical device risk management – São Paulo meeting 2019 Medical Device and FDA Regulations and Standards News 6
M Medical Device News ISO TC 210 IEC SC 62A JWG 1 Medical device risk management – São Paulo meeting 2019 Medical Device and FDA Regulations and Standards News 0
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
T Risk Management Report as per MDR Requirements EU Medical Device Regulations 4
S Medical Device Cybersecurity Risk Management File ISO 14971 - Medical Device Risk Management 2
M Medical Device News Health Canada Notice of intent: Strengthening the post-market surveillance and risk management Canada Medical Device Regulations 1
Q Evidence of precautions (clinical evaluation report, risk management report) EU Medical Device Regulations 6
Q Risk / benefit Analysis in Risk Management Report CE Marking (Conformité Européene) / CB Scheme 12
A How to view supplier APQP timeline and do risk management APQP and PPAP 4
O Medical Device EMC Risk Management CE Marking (Conformité Européene) / CB Scheme 4
S ISO 13485:2016 - How I can integrate a risk management approach in our SOPs ISO 13485:2016 - Medical Device Quality Management Systems 1
B Time necessary for all Risk Management activities ISO 14971 - Medical Device Risk Management 2
W Virtual Manufacturer and Risk Management ISO 14971 - Medical Device Risk Management 3
O CQE Handbook - Missing Section VII - Risk Management Misc. Quality Assurance and Business Systems Related Topics 1
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
