Riveting - special process
Hello everyone.
As apprentice method engineer i would like to enderstand exactly why standart riveting is classified as special procces (PS) ?
I enderstand that blind riveting is a PS because it is impossible to check the back of the rivet.
Thank you for your answers
Nathan
John Predmore
In the aviation industry, a special process is defined as
"8.5.1.2 For processes where the resulting output cannot be verified by subsequent monitoring or measurement, the organization shall establish arrangements for these processes" [to verify or validate the quality].
Mechanical testing of an assembled rivet is probably considered a destructive test, so you can't do 100% test. Even if you do not pull test a rivet to failure, you can't be sure the rivet was not weakened by the test. The other case of a special process is when it is impossible to verify the quality of a component in an assembly before completing the assembly, which makes verification of the component impractical for the purpose of quality determination.
First, thank you for your answers. I am little bit troubled because, in the case of a standard rivet, the aircraft manufacturer made a control procedure for the deformed head of the rivet after assembly (visual control, measure the diameter of the head). But according to the definition of a SP, the resulting output cannot be controlled. That why I asked why this type of riveting is considered as a SP.
Cari Spears
In my experience, measuring the diameter of the head would be caliper checks done in between the pull tests. We would have to pull test a first piece and last piece, and caliper check the head diameter once per hour.
actually it isn't that the output can't be controlled. it most certainly can. the 'control' procedure you mention is a form of testing. the requirement for a special process is that it can't be confirmed or tested 100%. Rivets can't be completely tested.
The size of deformation of the head can be measured as Cari said. unless the head is in an unacceptable area. even more reason for it to be a special process. Of course measuring the deformation of the head is only ONE characteristic of the integrity of a rivet. it was the lowly rivet that brought down the unsinkable titanic...
optomist1
A Sea of Statistics
a properly "bucked rivet" is a thing of beauty...I may have missed it, but is the present process manual or robotic rivet bucking/installation?
optomist1
A Sea of Statistics
Hi nath57, a bit more insight will help;
this takes me back a few to my undergrad course on airframes...good stuff, below some more thoughts:
- so this manual process/tool entails the rivet set tool is the rivet a universal, does the process entail using a bucking bar, or is the process a hand held pneumatic or semi-automatic tool? Manual to me is I insert rivet in said hole, set bucking bar in place and buck away until head is properly deformed or formed (depending on your terminology) with the rivet set tool usually pneumatic. Is this part of a repair, or retrofit operation?
- echoing Cari's above post, are there pre and post samples that can be verified dimensionally and or sectioned...depending on the application, I have seen destructive sectioning or x-ray of samples before the process is allowed to continue. These results and samples could become part of the device build book or history for later reference?
And to be certain when it is fully manual, there is a high degree of skill required, especially to do so on a repetitive basis
Below from the NADCAP website....it could be that this is a matter or semantics? Note: below it refers to creation of products, could be intended to address the end product, vis a vis an intermediate process or sub-assembly? I am not an AS9100 expert...hope this helps
"In the AS9100 series of standards, special processes refer to a set of linked procedures that lead to the creation of products and services whose end results would not otherwise be measured, monitored or verified before being released to the customer. Hence, these products and services require special attention during production to ensure that they are free of defects
W Aluminum Riveting - Process specification for joining aluminium sheets AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Special 510(k) for orthopedic implant 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
J EU MDR getting closer - Special offer for Elsmar members 10/2020 EU Medical Device Regulations 14
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
L Special Processes for SERVICES AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K PSA Special characteristics Customer and Company Specific Requirements 0
Watchcat Advantages to pursuing a Special 510(k) instead of a Traditional 510(k) Other US Medical Device Regulations 5
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
M Special Controls and Class II Medical Devices Medical Device and FDA Regulations and Standards News 18
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
F Replacement Bone Screws - Traditional 510(k) or Special 510(k)? Other US Medical Device Regulations 7
F Assignment of Special Characteristics to government regulations IATF 16949 - Automotive Quality Systems Standard 5
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
S VW Special status condition IATF 16949 - Automotive Quality Systems Standard 3
K Letter to file vs Special 510 for additional accessory in orthopaedic kit Other US Medical Device Regulations 1
P Special 510(k) - Modified Medical Device Description Other US Medical Device Regulations 8
P V&V for Special 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
P Sanctioned Interpretations - IATF 16949 Cl. 8.3.3.3 Special characteristics IATF 16949 - Automotive Quality Systems Standard 3
E IATF 16949 Cl. 8.2.3.1.2 - Customer-designated special characteristics IATF 16949 - Automotive Quality Systems Standard 1
T Customer special status and initial IATF certification IATF 16949 - Automotive Quality Systems Standard 12
J NADCAP - Supplier Special Processes Certifications Manufacturing and Related Processes 1
N Special Vs Non-Special Processes Misc. Quality Assurance and Business Systems Related Topics 15
D Customer-Designated Special Characteristics vs. Special Characteristics IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
A Special Procedures for Non Aerospace Customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Metal Radiographic and Ultrasonic Testing - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Special Characteristic - IATF Definition IATF 16949 - Automotive Quality Systems Standard 4
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
I Special 510k Imported Legacy Blogs 0
Marc A special Supermoon comes—but what causes it? 14 November 2016 Coffee Break and Water Cooler Discussions 0
J Are Product Special Characteristic(s) Mandatory? IATF 16949 - Automotive Quality Systems Standard 4
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
Q US FDA UDI Compliance Question - Class II (Special Controls) Other Medical Device and Orthopedic Related Topics 4
