RMF Inspection to IEC 60601 ed 3 when Conformity Not Claimed
h689e2NR2ok4mceQ
Sorry, I didn't know how else to word the title...
I recently had a CE audit for a device that has a Part 2 standard not due to transition until later, the date not yet set for publication in the OJEU. I'm still claiming the 2nd edition of 60601-1 gives Presumption of Conformity to the Essential Requirements since the Part 2 standard determines the Transition date.
However, the auditor gave a nonconformity for not considering failure modes listed in the 3rd edition of 60601-1. The auditor's assessment of the risk management documentation, relevant for EN 60601-1:2006 compliance, doesn't seem appropriate at this time to me.
Is this appropriate?
There is a Risk Management program in place to 14971:2009 already and I'm writing an assessment for a transition plan to the third edition for this particular device in all markets. I'm hoping that assessing the regulation and having a plan for future based compliance with the third edition should be enough for that issue. This device has been 510k cleared and on the market in the USA for a while with no significant change so the EU will be driving compliance to the updated standard.
So I'd like to ask if there's something I'm missing? Like I said, I don't think that it's appropriate to assess RM to the third edition for this device right now but could the argument for assessment be that we should consider "state of the art", or something like that?
The Part 2 standard is tentatively scheduled to be published sometime mid-2013 per CENELEC and I'm trying to get some breathing room until we go all-in.
Thanks in advance!
drewsky1
This is interesting. Did you recognitize and address the failure modes within your risk management document?
We have several legacy products and understand if there has not been any "significant change" to the device for existing FDA approved devices, it may not require to meet the new standard (3rd ed). Can anyone describe or give an example of what a "significant change" would be? I would think anything that would change the form, fit, or function of the device that may impact safety and effectiveness would apply here and therefore would require a filing. This then would mean testing to new standard would apply.
h689e2NR2ok4mceQ
Yes, of course risks are assessed per 14971 and the hazards outlined in the standard are covered. It's just that the hazards aren't itemized, detailed and cross-referenced to the relevant sections between 14971 and the 3rd edition standard in a presentable way to satisfy "Compliance is checked by inspection of the RISK MANAGEMENT FILE" to the auditor, which I believe isn't stated in the 2nd edition.
The device does need a proper assessment to the 3rd edition and I can see the value of more diligent handling of risk management in the standard but we don't expect any major surprises in transition that will make the device inherently less safe. Well, I submitted an assessment and plan to do it properly when it's required so I'll see how it goes.
I can't post links but if you search "ucm134575" you'll find FDA guidance with examples of modifications that may require a new 510(k).
IMO it's always good to refer to FDA guidance when there's change and you'd probably use the 3rd ed. even though the transition is June 30, 2013. I believe Health Canada takes a similar approach for licensed devices but the deadline has already passed. In the EU all devices, new, modified, and current production are expected to have addressed the 3rd edition to remain eligible for CE marking to the MDD, unless it has an applicable Part 2 Standard published.
drewsky1
This is good to know as we are in process of updating our risk documents and this is exactly how we are structuring it.
I did the search you mentioned here in Elsmar but the only item that comes up is this correspondence.
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
