RoHS Compliance requirement for Hexavalent Chromium
N
NikkiLuna
We are OEM's whose products are made with galvanized steel and/or galvalum. Our RoHS compliance issue comes from passivization method to chemically treat our steel because Hexavalent Chromium (Cr(VI)) is present in the treat. The RoHS requirement for hexavalent chromium must be less than 0.01% of the substance, by weight, at the raw homogeneous materials level. Per our steel supplier, a 0.2% chemical treatment, which contains Cr(VI), is used to prevent corrosion (white rust) during storage and transit. The product is applied at the mill and becomes trivalent chromium within a few days of production through oxidation. However, the supplier does not guarantee a RoHS compliant product when we receive it. Therefore, for reporting purposes, we are saying we are not RoHS compliant.
We are getting pressure from some of our customers regarding our treatment, and to be completely honest – I’m a little lost. Based on the information that was provided to us, we are lead to believe that the CR(VI) converts to trivalent chromium (CR(III)) within a few days after leaving the mill. Since the steel we use sits for days with the processor, then for days/weeks at our plant before it’s used then for days/weeks in S&R here then at the customers… a month or two has passed. If the chemical only needs a few days to convert and our product sits for a month - is there a concern? Are we RoHS compliant or not? How do we prove it? Is there a test that can be run to determine compliance? Is there an alternative treatment out there that we can use?
Kales Veggie
People: The Vital Few
Yes, there is a concern, because Cr (VI) is highly toxic. Are you protecting your workers?
I am not aware the Cr(VI) converts to Cr(III).
1) I would ask for evidence from your supplier that it converts to Cr (III).
2) I would send different aged well prepared sample to a lab
3) I would talk to my supplier and ask for alternatives.
4) Do some research to see if my supplier is correct.
N
NikkiLuna
Thanks. This helps alot. One more question (hopefully). Who/what kind of lab do I send samples to for analyzing? Do you know of a reputable lab in Ohio? What do I google?
Kales Veggie
I am not familiar with labs in Ohio. A starting point would be Intertek (I am no affiliated with them, but have use them in the past). There are other labs as well, just Google "rohs testing".
JimmyM
The company I work for purchases parts that have been Nitric 1 passivated which according to the ASTM contains dichromate. If the part is rinsed well after the passivation process, they will more than likely pass outside XRF testing (I am not saying don't get them tested).
Have you considered a Nitric 2 or 3 passivation (according to the ASTM contains no restricted materials) or even a Citric passivation?
I can't remember the ASTM number off the top of my head, but I can get that info when I am at work on Monday so you can google it yourself.
Cheers,
JimmyM
Ray Kremer
The sodium dichromate in some nitric passivation baths is there to be an oxidizing agent. It does not in any way deposit onto the surface of the stainless. The passive chromium oxide layer on stainless is formed by the reaction between oxygen gas in air and the zero valence chromium on the surface of the steel that has remained after the acid treatment.
RoHS is actually completely irrelevant to stainless steel passivation since RoHS is concerned with coatings and stainless passivation is not a coating, and no amount of the passivation bath remains on the surface.
However, most people don't really get into the details of RoHS and just want a quick yes/no on compliance.
A967 is the ASTM standard you were trying to think of.
However, none of that is relevant to galvanized steel, which is entirely different from stainless steel. I'm not as well versed on galvanized, but you can google on "galvanized steel passivation" for a quick run-down. The result at the American Galvanizers Association is pretty good. You might also be interested in the pdf presentation at ASTM's website titled "RoHS Compliant, Non-Chrome Passivation of Galvanized Steel with Lugalvan Passivation".
K ROHs compliance requirement REACH and RoHS Conversations 10
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
R Certificate of compliance to RoHS/REACH/WEEE - any such animal? REACH and RoHS Conversations 18
Ed Panek CE REP questions about our devices ROHS compliance REACH and RoHS Conversations 1
R REACH and ROHS compliance for hundreds of parts made over 25 years REACH and RoHS Conversations 3
T CE Marking & Compliance to MDD, EMC, RoHS, and GPSD REACH and RoHS Conversations 4
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
P Necessary Compliance Documentation for RoHS and REACH REACH and RoHS Conversations 5
M RoHS Directive - Supplier Compliance - Declaration of Conformance CE Marking (Conformité Européene) / CB Scheme 12
dubrizo Who handles Your Reach, RoHS, 3TG Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 10
smryan Compliance Officer Outsourcing? RoHS, REACH, ELV, GADSL, IECSC Other ISO and International Standards and European Regulations 5
A RoHS compliance - Our market is non EU countries only ISO 13485:2016 - Medical Device Quality Management Systems 4
R RoHS Compliance Problem with One Component RoHS, REACH, ELV, IMDS and Restricted Substances 5
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Start Compliance to RoHS, SCHV and REACH RoHS, REACH, ELV, IMDS and Restricted Substances 10
S What needs to be done to demonstrate RoHS compliance for Medical Devices? RoHS, REACH, ELV, IMDS and Restricted Substances 6
J RoHS/REACH Compliance Tools and PLM Integration RoHS, REACH, ELV, IMDS and Restricted Substances 14
C Legacy Medical Devices -- RoHS compliance in 2014 or 2019? RoHS, REACH, ELV, IMDS and Restricted Substances 5
D IVDD RoHS Directive Compliance to 2011/65/EU RoHS, REACH, ELV, IMDS and Restricted Substances 4
A Are RoHS compliance certs sufficient to qualify material? RoHS, REACH, ELV, IMDS and Restricted Substances 6
B RoHS Compliance for a Medical Device Manufacturer RoHS, REACH, ELV, IMDS and Restricted Substances 12
J ROHS compliance for MRO (Maintenance, Repair & Overhaul) Items RoHS, REACH, ELV, IMDS and Restricted Substances 11
O Sample RoHS Compliance Procedure for plastic injection molding needed RoHS, REACH, ELV, IMDS and Restricted Substances 2
M Experience with IPC 1752 compliance? Manage and report ROHS information RoHS, REACH, ELV, IMDS and Restricted Substances 4
A Certification of Raw Materials for RoHs Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 3
E XRF vs. Spark Test for RoHS Compliance Verification RoHS, REACH, ELV, IMDS and Restricted Substances 24
J RoHS Compliance - Steel - Customer wants additional samples tested RoHS, REACH, ELV, IMDS and Restricted Substances 32
I Method of Identifying and Segregating of RoHS Compliance Material RoHS, REACH, ELV, IMDS and Restricted Substances 7
M RoHS Exemption Declaration for IVDR instruments REACH and RoHS Conversations 0
Anerol C On line training for REACH, RoHS, Halogen RoHS, REACH, ELV, IMDS and Restricted Substances 1
A RoHS & Electric vehicle charging cables RoHS, REACH, ELV, IMDS and Restricted Substances 2
Z Proving REACH/RoHS status for electronics components from Digikey/Mouser REACH and RoHS Conversations 7
Z Data sheet from McMasterCarr enough for RoHS/REACH documentation? REACH and RoHS Conversations 4
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
G RoHS Procedure REACH and RoHS Conversations 2
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
R ROHS Exemption Declarations REACH and RoHS Conversations 5
M ROHS : Applicability for AIMDs RoHS, REACH, ELV, IMDS and Restricted Substances 2
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
padraick63 REACH and ROHS Requirement for a Molded Part REACH and RoHS Conversations 1
T China ROHS exemptions - Are there any exemptions for ROHS 2 China? REACH and RoHS Conversations 0
D The Status of ROHS for Medical Devices - April 2019 REACH and RoHS Conversations 3
S Prop 65 and RoHS statement REACH and RoHS Conversations 6
J What my companies RoHS declaration should say 2011/65/EU, 2015/863, or 2017/2102 REACH and RoHS Conversations 3
bio_subbu EU Publishes New DIRECTIVE (EU) 2017/2102 AMENDING 2011/65/EU ON ROHS-2 REACH and RoHS Conversations 0
J RoHS, WEEE and REACH Consulting Expertise Needed REACH and RoHS Conversations 4
Q Guidance regarding Legally Refurbishing a Non-RoHS Instrument in the EU REACH and RoHS Conversations 1
