Roll Form Thread Standard
Dr.mr555
We have a supplier that has used a roll form tapping process on parts we specify a thread requirement of UNF 10-32 2B. My research on producing internal threaded parts using a roll formed tapping process indicates that we cannot specify a thread standard if we wish to allow the roll form process to be used which produces an inconsistent minor diameter. The minor diameter limit of size is clearly defined for the for threads produced to the UNF standard. The inspection method used by our supplier is to use a go no-go UNF 10-32 2B gauge only, which is why we received parts which the minor diameter measured .180? plus. Obviously an oversized drill was used. I would think we cannot specify a standard if we allow roll forming. I understand that a higher quality thread is produced, but how can I allow this process in a ISO 9001 controlled environment? Please help!
Jamie_
I don't know how helpful this will be, but our supplier only uses a go/no go gauge as well and it's never been an issue. That said it's not a huge part of our fabrications so I may be completely deficient in this and it's never come up. I'll be following this thread with great interest to see what the consensus is on this.
Michael_M
A roll form thread still requires the UNF 2b class of fit to apply. Class of fit requires both pitch diameter (thread gage) and ID (gage pins).
As I understand it, a roll form thread is a bit stronger than a cut thread but both still require the form of the thread to be correct:
ID
OD
Pitch diameter
Angle of cut
Threads per inch.
Wayne
Gage Crib Worldwide
We have a supplier that has used a roll form tapping process on parts we specify a thread requirement of UNF 10-32 2B. My research on producing internal threaded parts using a roll formed tapping process indicates that we cannot specify a thread standard if we wish to allow the roll form process to be used which produces an inconsistent minor diameter. The minor diameter limit of size is clearly defined for the for threads produced to the UNF standard. The inspection method used by our supplier is to use a go no-go UNF 10-32 2B gauge only,.... I would think we cannot specify a standard if we allow roll forming.
A roll form thread still requires the UNF 2B class of fit to apply. Class of fit requires both pitch diameter (thread gage) and ID (gage pins).
I agree with Michael M, but wish to expand on his reply a little bit.
Know that screw thread plug gages do not test the screw thread minor diameter for over-size condition. This is true regardless of the method of manufacturing the screw thread. In all cases inspection of any internal screw thread requires the use of GO/NOGO Screw Thread Plug Gages, to check most of the screw parameters; used in concert with GO/NOGO Plain Pin Gages, to test the Minor Diameter.
From a manufacturing perspective; regardless of the method of manufacturing, if the tap drill hole is larger; less work is required of the machines and tooling (less broken/worn taps) to make the screw thread. This means cost savings for the manufacturer. If the manufacturer can convince you that a feature (the minor diameter) is not controllable, he can save on his cost of making the part and have greater profit. (Profit is not a bad word, but it should not be to the determent of the understood/specified conditions of the part.)
The minor diameter is controllable. The size is defined in ANSI/ASME B1.1 and the test methods in ANSI/ASME B1.2. Work with the supplier to correct his error; or find a new supplier.
I hope this helps.
I
ISOCOP
A go/ no go thread gauge will not detect an oversize minor ID. If the minor is oversize it will have a negative impact on thread engagement and strength.
N
ncwalker
I cut a LOT of threads at my factory, well, roll form them.
They absolutely meet the UNC/UNF thread classifications. The major difference is if you have a forming tap, you must use a different tap drill size than a cutting tap. The tap hole for a roll formed tap is larger, you need the negative space to "squish" the material in to. And yes, they are typically stronger.
Two users also very correctly stated (I apologize, I don't know how to scroll up and see who they were) that a thread gage does NOT check for an oversized minor diameter condition. This has burned us in the past, don't make this mistake. They must be checked with a go/no-go thread gage AND a no-go pin sized to the minor diameter.
If your supplier is having minor diameter issues it is typically:
1) They have the wrong tap drill size (too large, making too much negative space)
2) Their tap drill is wobbling. (They should write a CMM program have a special CNC program that skips all the taps leaving just the tap drill holes. You burn a part or two, but you get to check the form of the tap hole AND you get much better measurements for true position, not probing threaded holes).
3) If it is a casting you are tapping, there's porosity in there. (The porosity ALSO makes negative space and when the form tap squishes the material out of the way, some of it fills the voids, resulting in partial threads with the material missing from the minor diameter. Another reason for the intermittent program in 2) above, you can see the porosity. Sometimes forming covers them).
Wayne
Gage Crib Worldwide
A go/nogo thread gauge will not detect an oversize minor ID.
Thread gages are made as PLUG and RING gages.;) This chain is speaking of plug gages. :rolleyes: Thread PLUG gages do not test the part thread minor diameter. :( For the record; thread RING gages do not test the part thread major diameter. :agree1:
K Roll Form Thread Tolerancing - Aluminum castings - Help needed Various Other Specifications, Standards, and related Requirements 6
dgrainger Informational Good news: Commission proposes a progressive roll-out of the new In Vitro Diagnostic Medical Devices Regulation EU Medical Device Regulations 3
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
J How to manufacture best Roll Forming machine? Manufacturing and Related Processes 1
J Procedure for Document Roll Out ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Quality System Roll Out Proposal Procedures and Content Quality Manager and Management Related Issues 13
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
C Procedures or Work Instructions on Roll Flagging for a flexible packaging company Document Control Systems, Procedures, Forms and Templates 5
J SPC roll-out Plan for company-wide SPC Statistical Analysis Tools, Techniques and SPC 6
D Formula for Determining Finished Good Roll Diameter Manufacturing and Related Processes 7
Marc Boeing 707 (Boeing 367-80) "Dash 80" completes a Barrel Roll circa 1954 Travel - Hotels, Motels, Planes and Trains 5
L Setting a Sine Plate with Roll Pins - Roll Dimensions for Sine Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Does anyone know the Shelf Life of a Diazo copy roll of Microfilm? Manufacturing and Related Processes 1
P Roll forming Best in Class - Uptime, Change over time, Capability, etc. Manufacturing and Related Processes 3
A You can only choose one Rock n' Roll album to save Coffee Break and Water Cooler Discussions 46
R Your top 10 picks for greatest Rock n' Roll songs Coffee Break and Water Cooler Discussions 182
P Part 21G - Liabilities of a Quality Manager Form 4 Post Holder EASA and JAA Aviation Standards and Requirements 4
bryan willemot Chain of custody form for counterfeit parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Casana Step 7 in AIAG/VDA FMEA form FMEA and Control Plans 17
M AS9102 Form 1 Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Use of Supplier's Corrective Action Form vs. Corporate Form Supplier Quality Assurance and other Supplier Issues 4
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
D Japan adverse event form Japan Medical Device Regulations 1
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
M Prescription Form - Medical Devices US Food and Drug Administration (FDA) 2
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
Miner Reported content: Post in thread 'Form of real time study for establish shelf time' Document Control Systems, Procedures, Forms and Templates 1
A Form of real time study for establish shelf time Reliability Analysis - Predictions, Testing and Standards 4
M GP-12 procedure form and requirements Customer and Company Specific Requirements 1
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
D Faxback form versus amendment License for Class II Canada Medical Device Regulations 1
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 5
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
