Rolled Throughput Yield (RTY) Calculations for a Sequential Process
If we have a a sequential process A -> B - > C, and for each process we collect the First pass yield weekly. What is the best way to calculate RTY for the month. Do we just do the following
(sum of # Rejected for month from process A / sum of # Tested for month in Process A) * (sum of # Rejected for month from process B / sum of # Tested for month in Process B) * (sum of # Rejected for month from process C / sum of # Tested for month in Process C)
Or do we have to calculate the RTY numbers for each week and somehow roll up a number for the month .. basically .. what is the best way to calculate a monthly RTY for a prcess that we collect data for on a weekly basis????
W
wmarhel
Re: RTY Calcualation ???
What is the significance of a monthly number? The shorter the interval for the calculation (daily vs. weekly vs. monthly) makes more sense. Otherwise, your just accepting the results and tracking them. Four weeks of data just to spit a number out at the end seems a little pointless. Calculating RTY (your example calculation is correct) has a couple of purposes:
1) Determine the overall effectiveness/reliability of the process
2) Identify which step is most detrimental to the process and apply corrective measures
3) Determine if any particular step in processes exceeds the "typical" level of defects
You answered your own question in the last paragraph:
If you collect the data weekly.....report it weekly.
Wayne
M Question About Rolled Throughput Yield Manufacturing and Related Processes 5
M Rolled Throughput Yield Benchmarking 0
P Is throughput yield the same as FPY or FTY? Rolled Throughput Yield Manufacturing and Related Processes 3
B How RTY (Rolled Throughput Yield) applies to different industries Manufacturing and Related Processes 1
F Rolled Throughput Yield and Confidence Interval Six Sigma 3
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
N Definition TDU (Total Defects per Unit) and RTY (Rolled Throughput Yield) Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
H Rolled Throughput Yield (RTY) Loss - Can you measure in PPM? Six Sigma 3
S RTY (Rolled Throughput Yield) - Use Poisson Distribution Calculation Quality Tools, Improvement and Analysis 4
B How to define and Calculate the DPU, DPMU, DPMO, Yield, Rolled Throughput Yield (RTY) Manufacturing and Related Processes 3
R Rolled Throughput Yield - Is anyone using this metric, and if so, how Lean in Manufacturing and Service Industries 6
S DPMO (Defects Per Million Opportunities) vs. RTY (Rolled-Throughput-Yield) Six Sigma 7
L RTY (Rolled Throughput Yield) Calculation Other ISO and International Standards and European Regulations 4
Bev D World Class Rolled Throughput Yields - 2012 Six Sigma 1
J SST .625 dia Cold Rolled 303 bar and Magnetism Manufacturing and Related Processes 6
L Wearing an ESD Smock with Rolled Up Sleeves Misc. Quality Assurance and Business Systems Related Topics 4
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
B Hot Rolled Steel Coil Rust Prevention Tests Manufacturing and Related Processes 3
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
G How do I calculate PPM from a Rolled Wire Suppllier Supplier Quality Assurance and other Supplier Issues 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
F Technical question - U-BOLT microscopic cracks on the tooth of the rolled thread Manufacturing and Related Processes 14
C Standard for surface roughness on hot rolled steel Manufacturing and Related Processes 2
J How to Define Scrap Metrics & Objectives - Stamped Cold Rolled Steel Fasteners ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E NCR (Nonconformance Report) for device defects - Hot rolled coils Nonconformance and Corrective Action 1
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
K Resistance Welder Settings for cold rolled and galvanized steel Manufacturing and Related Processes 3
apestate Tolerances for cold rolled, hot rolled, DOM tubing Other ISO and International Standards and European Regulations 10
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
K Definition Throughput - Definition and Calculation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
F Throughput time measurement Cpk summary Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Calculating Throughput Yield or Yield Six Sigma 10
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
C Can I apply First Time Yield (FTY) for several products or processes of different nature? Manufacturing and Related Processes 5
O How to give a score/yield more correctly to my suppliers Supplier Quality Assurance and other Supplier Issues 12
E 21 CFR 211.103 Calculation of Yield Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
R Yield Plot for different groupings Using Minitab Software 3
N Accurate calculations of First Time Quality / First Time Yield Misc. Quality Assurance and Business Systems Related Topics 3
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
F Yield reaction higher than 100% Manufacturing and Related Processes 3
Q Validation of Predictive Models of Yield Statistical Analysis Tools, Techniques and SPC 19
B Machine Shop Yield and Cost - Productivity, Yield and Absorption Performance Manufacturing and Related Processes 3
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
B Calculation of First Pass Yield (FPY) Six Sigma 9
V Monitoring Specific Reasons and Categories of Yield Loss of Online Rejects ISO 13485:2016 - Medical Device Quality Management Systems 1
D Defining Yield Rate Targets for different Manufacturing Processes APQP and PPAP 2
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
