Root Cause Analysis and Corrective Action Program for Inventory Inaccuracies
bowanna03
I am reposnsible for reporting out and maintaining our companies inventory record accuarcy and cycle counting programs. I would like to start to build a robust Root Cause Analysis and Corrective action program for all of our record in-accuracies. Can anyone help with the intial set up or thoughts? Thanks for the help to all!!!
qusys
Re: Implementing a Root Cause Analysis and Corrective Action Program
You could use quality methods to address the most probable root cause, such as 5 Why's, brainstorming, Fishbone diagram, problem solving techniques .
The most important aspect to take care is multidisciplinary approach , working in team the all stakeholders and involved parts of the problem to be faced.:bigwave:
bowanna03
Thank you for the feedback and thoughts. I am going to look into creating a RCA team that will investigate all of the in-accuracies and meet when issues arise. We as a team will assign immediate corrective actions and a proposed action plan (PAP). I would love feedback if possible.
somashekar
First let us understand the problem description.
companies inventory record accuracy and cycle counting programs.
What does this consist of ? What activities ? What type of components in the inventory ? What counting methods ? What is desired ? A 100% accurate record of even the C class component that are stocked in tens of thousands ?
We must strike a good balance between efficiency and effectiveness.
I wish you detail your companies inventory record accuracy and cycle counting programs, for our better understanding to respond back.
bowanna03
I have two metrics to which I am measured upon. 1. Cycle Count Accuarcy, we run a daily cycle count with A,B, and C classification parts.2. Inventory Record Accuracy. As a team we are doing great job at finding our problems and not having to write off material but we are not doing a good job of preventing the problems from re-occuring. Record Accuarcy will tell us that our records don't match our locations then we have an issue that could lead up to a cycle count write off in the future.
somashekar
I have a question ...
Do you count to a fair accuracy all the parts that comes in before moving them to your inventory, or you go by the package label count, that the supplier provides ?
This accuracy is always against your system vs the various supplier system.
How has been the various suppliers count ? You have some inputs on these. Were there any CA on suppliers for want of inaccurate count in supplies ?
bowanna03
Everything including weigh counted items are hand counted at time of receiving accepting the material. If there ia an issue with a count a secound count takes place to verify that there is a discrepancy. Then the vendor is notified of the error. Our Quality team hold the vendors accountable for any errors wheteher it be documentation or incorrect quantities.
RoxaneB
Change Agent and Data Storyteller
Depending on your inventory count accuracy level, might I suggest that you not implement root cause analysis for every occurrence of a discrepancy? In a previous position, we set up triggers for RCA on inventory count issues with criteria including:
  • quantity (i.e., % variance)
  • value of item(s) (i.e., $)
  • criticality of item(s)
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
A Recommend good Root Cause Analysis Training Courses in the UK Training - Internal, External, Online and Distance Learning 8
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Triggering Root Cause Analysis for Hardware Returns Nonconformance and Corrective Action 3
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Smart or Sexy (CAR) - Poor Root Cause Analysis and Poor Effectiveness Check Nonconformance and Corrective Action 8
Moncia How to do a Root Cause Failure Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Anerol C Root Cause Analysis Coding System Nonconformance and Corrective Action 11
J Root Cause Analysis in a ISO 17025 Testing Laboratory ISO 17025 related Discussions 6
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Noneffective Root Cause Analysis: 6M Fish-Bone Template Problem Solving, Root Cause Fault and Failure Analysis 1
L Root Cause Analysis Training Training - Internal, External, Online and Distance Learning 12
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause Analysis (Medical Devices) - Management Support Quality Manager and Management Related Issues 14
F Root Cause Analysis Problem Case Study for Exercise? Problem Solving, Root Cause Fault and Failure Analysis 10
