Root Cause Analysis of Audit Findings - New Quality Manager
RM Myers
I took over the Quality Manager position 3 months after the AS9100 audit and after the last QM was let go. Most of the findings were omissions on the part of the prior QM. So far there is no chance of creating a reasonable RCA (out of thin air) HELP
Bob
sagai
Re: Root cause analysis as new QM way post audit
Well, sounds a bit strange rational to me that with the leave of your predecessor, problem solved. :popcorn:
It is difficult to say anything based on a single post, but it looks me obvious to do investigation, RCA and if there is any RC, than actions.
Cheers!
RM Myers
Auditor requires a complete RCA other than the guy was deficient in practice
RM Myers
Ive made several submissions to the auditor but due to my lack of knowlege they were 'insufficient' and are holding up the certification.
Randy
It doesn't matter what the auditor requires, what matters is that you have an RCA that is suitable and effective enough for you to be able to apply short term correction and them a long term solution to the problem that will keep it from happening again from the cause(s) you identify
Simply put....
You have a flat tire
Fix the flat tire
What do you think caused the flat to begin with
Develop a solution to prevent future flats caused by what you think the original problem was that caused the flat
Implement your solution
Keep you eyes on your tires and verify...No new flats (at least from the original cause)
You're auditor shouldn't dictate the process, he should only verify wether or not the process works effectively
Randy Lefferts
What were the findings that you are trying to answer?
RM Myers
Thanks but although corrections have been made that I feel are sufficient to prevent recurrence, the RCA that the auditor will accept escapes me. I could do it if I had been here during the audit and at the wrapup meeting but wasn't. I've plead the case that the guy was not trained properly but was told that was not accepble.
Sidney Vianna
Post Responsibly
If the organization allowed for an incompetent quality manager to perform work, what does that say about the organization's process to screen and hire personnel? What about the organization's process to ensure competence in the work place? What does that say about the organizations top management allowing for an incompetent quality manager to stay in place?
If I were you, I would be very pleased that the CB auditor is keeping your organization accountable to meaningful root cause analysis, as demanded by AS9101D. Otherwise, you your job could become the next escape goat to be sacrificed in the aftermath of a failed audit.
RM Myers
Primarily omissions in the process documentatons, weakness in the CA procedure and other issues where authorities were not clear and duties not completed. The guy didn't do a completye job in creating the system or follow through to support. He was not present during the Cert audit (let go) so his sins and reasons for are lost in history.
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
B Root Cause Analysis and Corrective Action Program for Inventory Inaccuracies Nonconformance and Corrective Action 8
A Recommend good Root Cause Analysis Training Courses in the UK Training - Internal, External, Online and Distance Learning 8
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Triggering Root Cause Analysis for Hardware Returns Nonconformance and Corrective Action 3
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Smart or Sexy (CAR) - Poor Root Cause Analysis and Poor Effectiveness Check Nonconformance and Corrective Action 8
Moncia How to do a Root Cause Failure Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Anerol C Root Cause Analysis Coding System Nonconformance and Corrective Action 11
J Root Cause Analysis in a ISO 17025 Testing Laboratory ISO 17025 related Discussions 6
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Noneffective Root Cause Analysis: 6M Fish-Bone Template Problem Solving, Root Cause Fault and Failure Analysis 1
L Root Cause Analysis Training Training - Internal, External, Online and Distance Learning 12
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause Analysis (Medical Devices) - Management Support Quality Manager and Management Related Issues 14
F Root Cause Analysis Problem Case Study for Exercise? Problem Solving, Root Cause Fault and Failure Analysis 10
