Root Cause Analysis of Nonconformances - Presentations
P
Paresh_pn
Does anyone has presentation on root cause analysis showing different technique that can be used with examples.
This will help me to train people involved in investigation.
Re: Root cause analysis - Presentations
Have you tried searching the cove for files? There are several on 8D, 5-why, etc.
P
Paresh_pn
Yes. I have seen different methods, but could not find a presentation which complied with examples.
Probably one which a trainer should have.
trainerbob
Re: Root Cause Analysis - Presentations
Keep in mind that as the true root cause of a problem is turned on and off the problem should do the same. If If the problem dosen't react as we turn the root cause on and off, then we haven't found the true root cause and need to start over again.
Wes Bucey
Turning off [or on] a "suspected" root cause does not necessarily prove you have identified the true root cause - sometimes you have to ask whether there was an even deeper root cause affecting the suspected process. That deeper root cause may be lurking to bite you in the rear on another product.
I recall one instance where we determined a root cause of "chatter" on a CNC turning machine was due to the style and material of the tool bit and we therefore moved to a much more expensive tool bit which lasted a lot longer than the first, but still ultimately developed a chatter. A casual comment by a manufacturer's representative brought in to help us through our DOE led us to look at the material. A detailed metallurgical analysis of the material disclosed some inclusions not visible to the naked eye, but which were prematurely destroying our tool bits.
We replaced the material and were able to use either the original tool bit design or the newer one and get similarly large numbers of parts before we needed to replace the tool, resulting in production savings which far outpaced the cost of the root cause investigation.
Marc
True, but you definitely know you're on the right track.
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
B Root Cause Analysis and Corrective Action Program for Inventory Inaccuracies Nonconformance and Corrective Action 8
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
A Recommend good Root Cause Analysis Training Courses in the UK Training - Internal, External, Online and Distance Learning 8
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Triggering Root Cause Analysis for Hardware Returns Nonconformance and Corrective Action 3
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Smart or Sexy (CAR) - Poor Root Cause Analysis and Poor Effectiveness Check Nonconformance and Corrective Action 8
Moncia How to do a Root Cause Failure Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Anerol C Root Cause Analysis Coding System Nonconformance and Corrective Action 11
J Root Cause Analysis in a ISO 17025 Testing Laboratory ISO 17025 related Discussions 6
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Noneffective Root Cause Analysis: 6M Fish-Bone Template Problem Solving, Root Cause Fault and Failure Analysis 1
L Root Cause Analysis Training Training - Internal, External, Online and Distance Learning 12
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause Analysis (Medical Devices) - Management Support Quality Manager and Management Related Issues 14
F Root Cause Analysis Problem Case Study for Exercise? Problem Solving, Root Cause Fault and Failure Analysis 10
