V
Re: Root Cause Analysis - Presentations
A very valid point to cross check the efficacy of RCA. Usually people get lost in euphoria after diagnosing the apparent 'Root Cause' which may or may not be the real 'Root Cause'.
You have put in a known fact in precise wordings. Well said
Keep in mind that as the true root cause of a problem is turned on and off the problem should do the same. If If the problem dosen't react as we turn the root cause on and off, then we haven't found the true root cause and need to start over again.
