Root Cause for Minor Non-conformance regarding Supplier Delegation
L
lamahed
My company recently received a minor non-conformance in re-cert audit to AS9100 Rev. C, Statement of Non-Conformity was "Supplier delegation requirements were not fully met" referencing Clause No. 7.4.3 of AS9100 Standard.
Stated Objective Evidence was: Requirements for supplier delegation were not defined nor were there a register of delegations maintained.
Obviously, it's a pretty easy fix. However, I'm having a terrible time with the Root Cause. I am extremely hesitant to say something like, "Company failed to understand Standard, Poor Training of Standard Requirements" ect." I know we should be looking at what in the system failed that caused the non-conformance but I'm having a really hard time figuring out where in the system the company failed in implementing the standard...
Anyone had experience with this or something similar? Any advice would be appreciated.
Thank you
Mikishots
I would look at two things: the process documentation that defines how suppliers are controlled with respect to inspection activities, and the internal audit process. I'm aware that a documented procedure isn't a hard requirement, but you've been found to be missing defined requirements as well as the register.
Based on the auditor's finding, there is no evidence that there is a defined method of delegating requirements, or of a register of delegations (we've already established this, correct?). So...the next question might be why didn't the internal audit pick this up? An organization is required to ensure that its processes meet the cited requirements of the standard; this requirement is very plainly stated.
I'm curious - does your quality manual make no mention of this either?
Whenever a process is documented, it needs to be reviewed to ensure that it has been proven to be adequate prior to issue (4.2.3). The omission was never seen because the review of requirements was likely not carried out.
No comment on the "minor" classification - I'm not in agreement...:cool:
L
lamahed
Thank you for the feedback. Actually, our Quality Manual does mention the requirement, however, I believe the requirement was misunderstood and poorly written in the manual from the beginning.
Manual States: Where the organization delegates verification activities to the supplier, the requirements for verification shall be defined and a register of delegation maintained on the appropriate purchase order.
This may be a reason it was never caught in the internal audits (or multiple external audits).
Wes Bucey
Prophet of Profit
Thus it would appear you have answered your own question - the written procedure/process for initially delegating and ror continued monitoring and recording of the effectiveness of such delegation was vague or confusing in describing the process or procedure. The corrective action is to rewrite the procedure/process in more clear language and ACTUALLY implement the rewritten [revised] procedure/process.
Why not discuss with those who actually are expected to follow the procedure/process and thus develop a workable process once everyone understands the need and motive behind effective delegation?
Mikishots
I'm curious by your meaning of "register of delegation maintained on the appropriate purchase order". A PO is not the appropriate place for a register of delegation.
L
lamahed
Wes - Thank you, I think you may be correct.'
Mikishots - Yes, a PO is not an appropriate place for a register of delegation. Again, I believe there was a misinterpretation/lack of understanding of this requirement - i.e.: verification activities delegated to supplier would be recorded on a PO.
Delegation and/or register of delegation was misunderstood here.
Thanks again.
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause for minor Document Control issues Problem Solving, Root Cause Fault and Failure Analysis 21
qualprod What is exactly the root cause? Nonconformance and Corrective Action 9
M Test failure Root cause not found Customer Complaints 10
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 26
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
P Is it a rule to fill in all the 5 why in order to get the actual root cause? Quality Tools, Improvement and Analysis 5
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
H Root Cause Corrective Action Examples Nonconformance and Corrective Action 4
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
J Root Cause Determination Training for Production Managers Nonconformance and Corrective Action 6
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
