Root Cause on Non-Conformity Against Quality Manual
Deli88
Hi all,
I'm struggling to come up with a root cause on a non-conformity brought up during our ISO9001:2015 upgrade audit. I am new to the company and have taken on the position which was left vacant by my predecessor for 4-6 months.
I initially said that the errors were caused by an oversight by the quality manager while editing the manual to fit the new standard. However our accreditation body have said that this is incorrect. How can I determine a root cause when the error was made initially by the previous QM.
Any ideas on how I could write a meaningful root cause that doesn't surmount to human error?
Deli88
a) The index covers clauses of ISO 13485:2012 only and does not include reference to ISO 9001:2015 (Note: ISO 9001:2015 is included in scope of manual however).
b) Appendices A and B which contain the company process maps were inadvertently removed during the upgrade of the Quality Manual from Revision 12 to Revision 13 and so are no longer present.
c) Although the Quality Manual was verified to include reference to procedures and work instructions, the structure of the documentation used in QMS is not included.
d) Details on the control of the work environment in the cleanroom are not included in Section 6.4 of the Quality Manual nor are reference to associated procedures.
JoshuaFroud
Hi Deli88,
Welcome to the Cove.
I think for anyone to be able to provide any specific assistance or guidance you may need to give a little bit more information on the nature of the non-conformance?
I can see why your notified body may have rejected human error as the root cause as there were potentially several checks or review steps for the document before it went live. A failure of the review system as opposed to the human error by the ex-employee may be more easy for the NB to accept. A corrective action can be applied to a system but not a person, especially a person no longer in the employ of your company.
Is that the whole NC statement? No references to requirements in the standard?
Deli88
Hi Jim,
It was raised against 4.2.2 of ISO 13485:2012(2003) and 7.5 of ISO 9001:2015.
That is the non-conformance in its entirety. I have made all the amendments to the manual.
Would lack of understanding due to ineffective training be an appropriate reason for this non-conformity? I do believe that my predecessor believed he was making the correct changes to the manual at the time.
Golfman25
I would go with Josh's thoughts. In effective review process. While the updates where made, he should have had someone to review it, to at least make sure it made sense -- ie; no references to non-existent sections. It's still human error, just looks different. This is not an area you want to spend a lot of time on. Fix it and move on. Good luck.
Mark Meer
This is not a non-conformity, IMO. As long as your scope and and exclusions are clearly stated, there is no requirement to maintain an "index".
This sounds like a problem with your change control. Go back to the change records and see if this removal was documented. Was justification given for the removal? How was the impact assessed?
How long was it in this state? Should this deficiency have been identified in your internal audits?
Are these covered anywhere else in your documentation (e.g. Manufacturing process procedures)? If so, there is no problem. There is nothing in the standard that requires "details on the control of the work environment" to be in your quality manual (though there should be reference to the procedure).
The auditor is smoking some bad stuff. Can you provide some better stuff for them to smoke? If not, suggest they point out WHERE in ISO 13485 these things are REQUIRED. Once they can't suggest they stop asking for them and move on. If they argue, call their CB's Operations management and conference them in. If all else fails, show them the door...
Hi Jim,
If that's the whole thing, you have an incompetent auditor. That's no way to write an NC statement. Nonetheless, I'll go with the others here who say that it's the review process (if there is one) that needs attention. Simply fixing what was allegedly broken doesn't explain how the broken thing was allowed to be released into the wild.
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
L Root Cause for Minor Non-conformance regarding Supplier Delegation Nonconformance and Corrective Action 5
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
U Non Conformance - Root Cause & Corrective Actions - Civil Construction Projects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M Root cause analysis on non-defect defect reports? Problem Solving, Root Cause Fault and Failure Analysis 1
A Non-conformance Root Cause Analysis Finding: Stupidity? Problem Solving, Root Cause Fault and Failure Analysis 11
M Test failure Root cause not found Customer Complaints 10
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 24
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
P Is it a rule to fill in all the 5 why in order to get the actual root cause? Quality Tools, Improvement and Analysis 5
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
H Root Cause Corrective Action Examples Nonconformance and Corrective Action 4
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
J Root Cause Determination Training for Production Managers Nonconformance and Corrective Action 6
