Routine Testing for Class I Medical Device
sara_jg
For one of our product (class I device) we have already done type testing as per IEC 60601-1.
For doing routine testing in all our products before dispatching whether we need to do high voltage testing(dielectric test) and insulation resistance (IR test) testing as per 60601-1 std. or shall we define our own routine tests keeping 60601-1 and 62353 as reference??
please help.
Thank you in advance
saran
The tests and requirements set out in 60601-1 are, as you identify, Type Tests.
It is generally understood that some of these tests can be damaging to the unit under test. For instance, the impact test tends to dent panels and the marking durability tests can scuff labels. Neither necessarily constitutes test failure - but leave the unit in an unsaleable condition.
This accumulation of damage is why the sequence of tests (see Annex B) is defined. Your device should still be functional and safe after all he tests have been completed - but it may look a little worse for wear.
The dielectric strength test places significant stress upon electrical insulation. It may even permanently damage the insulation. And that damage may not be visible. So, it is not possible to guarantee that a test unit has undamaged insulation - so should never enter the market.
So what tests should be used on production?
Clause 5.1 describes the use of Type Tests. The 'Note 2' to that clause identifies IEC 62354 Annex K as guidance for 'Production Tests' and IEC62353 as guidance for 'Recurrent Tests'. Both have alternate methods for both the dielectric tests and various leakage current tests.
The guidance rationale for Clause 5.1 is useful:
Production tests need not be identical with TYPE TESTS, but can be adapted to manufacturing conditions and possibly invoking less RISK for the quality of the insulation or other characteristics...
One option for the dielectric tests that is quite commonly used, for instance by manufacturer's of transformers, is to perform the full voltage, full 1 minute, test on a sample to 'Type Test' it but then, for production, test at full voltage - but only for 5 seconds. This is, basically, the test we perform for production.
One thing to highlight - the dielectric strength tests only apply to solid insulations. If you are using 'creepage and clearance' insulations then you use a ruler as your test equipment - not the dielectric tester!
Also, when it comes to production dielectric tests, it is often a mistake to test from the 'back to the front'. By that I mean testing from the mains input to the front panel connectors. What happens then is that the test voltage stress is applied across more than one insulation and will be 'shared out' unevenly and unpredictably.
phase90
What are the requirements for dielectric tests during production? I have had conflicting information. As an example, the test house that certified a product for 60601 requires us to test with full voltage (1500 VAC) for 60 seconds (3000 VAC for applied parts to mains). The notified body that audits us to keep our CE certification tells us we are testing it too long and could damage the insulation. They recommend 5 seconds. :confused:
The test house is only used to doing Type Tests - hence their suggestion of 60s dielectric test.
For the production test 5 seconds is preferable. But, even then, make sure that you are only testing solid insulation and you are not stressing parallel insulations (where the test voltage would be unevenly divided).
phase90
Thanks Pads.
What I have been told now is that it can be tested for a shorter period of time, but at a higher voltage. (1000 + 2x line rating) * 1.2 for 1 second. (1776V, since they are using 230 VAC in the calculation, rather than 250V)
Randy956
If testing at hipot for 5 seconds, what IEC standard would support this time frame?
I've seen hipot being applied to production line units for 60 seconds and I think that's too long. I need some sort of "official" reference I can point to before I can suggest shortening that dwell time. Any suggestions on what document I can use as reference?
Thanks!
Randy
Hi Randy and welcome to the forums.
The 'Type Tests' for medical electrical equipment are what is in IEC 60601-1 (plus collateral and particular parts).
For 'Production Tests' the technical report IEC 62354 provides guidance.
For 'Recurrent Tests' (perhaps those done by a hospital's equipment management service each year) the technical report IEC 62353 provides guidance.
sara_jg
Hi
it would be of great help if any body could share a copy of IEC 62354 standard.
Thank you
sara
Marcelo
<snip> it would be of great help if any body could share a copy of IEC 62354 standard.
Any deliverable from IEC (IEC TR 62354 is in fact not a standard, but a technical report) is copyrighted and must be bought. Please refrain from asking for pirated copies of copyrighted material in this forum.
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Earth (ground) leakage current routine test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B Routine Bioburden Monitoring ISO 13485:2016 - Medical Device Quality Management Systems 5
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
N Heavy tare to simulate high load in a routine sensitivity test of a floor scale? General Measurement Device and Calibration Topics 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
N Referencing of a standard's year in routine regulatory compliance documents Other Medical Device Related Standards 3
M Medical Device News FDA - Eliminating Routine FDA news 14-09-18 - Re-Review of Third Party 510(k) Reviews Other US Medical Device Regulations 0
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
C Dose Mapping - How to relate back to Routine Monitoring Position ISO 13485:2016 - Medical Device Quality Management Systems 3
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
J FDA Routine Inspection Pre-Anouncement - What will be checked? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Identifying Routine and Non-Routine Activities: OSHA OHSAS 18001 Occupational Health & Safety Management Standards 15
S How you define 'Normal & Abnormal' Conditions and 'Routine & Non-routine' Activities ISO 14001:2015 Specific Discussions 8
J Routine test for MD finished product IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
RoxaneB Environmental Objectives - Do they need to be linked into with Routine Indicators? Miscellaneous Environmental Standards and EMS Related Discussions 6
RoxaneB Search for another name for "Standardization Process" or "Routine Management" Quality Tools, Improvement and Analysis 4
D Line clearance - Routine components in the prep room for universal use ISO 13485:2016 - Medical Device Quality Management Systems 8
R Inspection and Detection - Kit to production - Need an inspection routine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
E Usability for Near Patient Testing Test Kit Human Factors and Ergonomics in Engineering 2
J Single Fault Testing for Secondary Circuits (60601-1 section 13.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Medical device testing lab/service standard Other Medical Device Related Standards 1
T Cytoxtoxicity Testing Dilution Other Medical Device Related Standards 1
M Altitude testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
H IEC 62368-1 Scope of Testing CE Marking (Conformité Européene) / CB Scheme 3
H EMC & Safety Testing of the product with the same Sr. No. for EC Declaration CE Marking (Conformité Européene) / CB Scheme 3
A Non-medical device testing in the medical system IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
H Is testing according to IEC 60601-1 & IEC 60601-1-2 mandatory for a device being registered under MDR? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W CQI-9 Testing Fluids Manufacturing and Related Processes 0
XRAY_3121 Class II heating pad - does the power supply have to have IEC 60601-1 testing?? US Medical Device Regulations 5
T Testing for proving food safety on USP class vi material RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Risk Analysis for Proficiency Testing Reliability Analysis - Predictions, Testing and Standards 1
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
M Is complete testing required as per ISO 10993 for materials used in orthopedic implants or is literature review route possible Other Medical Device Related Standards 3
B A testing lab within an organization ISO 17025 related Discussions 10
B Package integrity Testing failure ISO 13485:2016 - Medical Device Quality Management Systems 7
R Basic Lab Practices - related to ISO 17025 testing labs ISO 17025 related Discussions 1
N Microbial testing on food packaging materials Food Safety - ISO 22000, HACCP (21 CFR 120) 3
A Stability Testing of a device with sterile fluid pathway claim Other Medical Device and Orthopedic Related Topics 1
M Cosmetic Shelf Life Testing Misc. Quality Assurance and Business Systems Related Topics 10
S Safety testing IEC 60601 series Medical Device and FDA Regulations and Standards News 2
M EE's - Laptops/Printer Change and Emissions Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
keya1tos EU to UK plug adapter correct testing standard CE Marking (Conformité Européene) / CB Scheme 9
D IEC 60601-1-2: Is EMC immunity testing required for a device without essential performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 25
M Oral irritation testing Medical Information Technology, Medical Software and Health Informatics 0
A Fire Testing - EN 50339 Not 20 minutes ISO 17025 related Discussions 0
M Biological testing at the end of the real time of MD Other Medical Device Related Standards 3
M In Vitro irritation testing according to ISO 10993-23 ISO 13485:2016 - Medical Device Quality Management Systems 2
R SaMD Performance Testing US Medical Device Regulations 5
J 'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs Other Medical Device Regulations World-Wide 0
