Routine Testing for Class I Medical Device
Kuldeep Singh
#21
Hello ,
Is it required to perform all the performance test such as dielectric strength test, leakage current test as specified in IEC 60601-1 on each and every machine at line assembly during its quality stage?
Yesterday during an audit , NB ask to perform the leakage current test on each machine. We are assuming that these tests shall perform only on prototype machine. Reference to above threads , it will also affect the performance of device if we perform these tests on device before its shipment.
At present we have leakage current tester designed to satisfy the IEC 60601-1 Cl. 8.7 requirement, which is costly equipment and kept in our Laboratory for performing the test on prototype machine. It will affect economically to us if we are bounded to provide this equipment in each halls to perform this test. Do you suggest any alternate & cheapest method to check the leakage current .
Peter Selvey
Moderator
#22
No.
When you declare compliance with standards like IEC 60601-1, this applies in both design and production. In fact, compliance in production is the real target for medical device regulations.
However, this does not mean testing every machine for compliance. This would be impractical, expensive and unnecessary.
Usually, for each requirement, the production engineers will take into account:
- the nominal or typical value
- the margins to safe limits
- the expected variability for each item in production
- possible failures in production (parts miss, assembly mistakes)
- the criticality of the requirement
Generally, in the case of dielectric strength and leakage currents, although they are "critical", the margins will be high and the variability low. So, the only reason to do the test in production would be to detect an assembly failure. Since that is the focus, the tests can be greatly simplified and do not need to follow IEC 60601-1 exactly.
For example, if you have a ac dielectric strength tester with 0.01mA resolution, it's possible to use that as a proxy for leakage current, rather than doing an actual leakage current test.
The most critical point is to make sure you have a qualified engineer designing the tests in production. They should have the confidence to explain why they selected the tests that are performed, and also argue against NB auditors.
The NB should never insist that a manufacturer do certain tests in production. Many of the tests in IEC 60601-1 are destructive or invasive, and would invalidate warranties if performed.
The NB can only ask how the manufacturer assures that each item (machine) in production meets the standard.
Kuldeep Singh
#23
Thanks Peter , that's what we are looking for, let see what are the opinion of other members.
Can you suggest me how to check the Earth leakage current with dielectric strength tester. As per my understanding, Dielectric strength tester is used for insulation and leakage current tester is for checking the leakage current in line, surface of enclosure and applied part.
Peter Selvey
Moderator
#24
In production, dielectric strength is not actually required, since it is really an ageing test for solid insulation (it's a frequently misunderstood test).
It can be used to check gross assembly errors and other production mistakes such as a dropped screw. In this case it's really just a high voltage test (HV test).
The main HV test you should be doing in production is a mains to earth (1.5kVrms). This is a simple test and in practice non-destructive, and useful for detecting gross mistakes. The other tests (mains to enclosure, mains to applied part etc.) are often destructive and may need special preparation of the sample to perform, it would be far more dangerous to do this on production items than any benefit from the test.
For the mains to earth test, the leakage during the test should be about 6 times the earth leakage when measured with the neutral open. For example, assume the device has two 1nF EMC capacitors, one L-E, one N-E (typical EMC filter), and no other major parts for earth leakage. In this case, we expect to see about 0.1mA earth leakage in normal condition @253V 60Hz and 0.2mA with the "neutral open" (this condition puts both the capacitors parallel, so double leakage). Then in the high voltage test, we would expect to see roughly 6 times this value (1.2mA). Thus we can use the HV test as a proxy for the earth leakage current test, in the sense that we are just looking for gross assembly errors. For example, if the result came back as 2.5mA, you could predict that someone put the wrong EMC capacitors in.
The circuit for earth leakage is also very simple, so it's not much work to make a simple low cost jig for this test as another option.
Again, I should stress, all of this should be organized by a qualified electrical engineer familiar with both the tests, your particular device and possible failure modes in production. There can be for example, special cases such as electrosurgical devices where the high voltages in the patient circuit would make a production HV test reasonable.
Tidge
#25
For what it is worth, I agree with Peter.
In my opinion, this good advice about seeking qualified engineers to design appropriate tests (quoted above) extends beyond this specific instance. Ideally, manufacturing processes (as well as products) are supposed to be 'engineered' so as to only perform testing which provides value. Testing which exposes manufacturing defects that occur at a known rate (and cannot be avoided) is much more preferred than repeating verification testing of every unit manufactured.
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
N Heavy tare to simulate high load in a routine sensitivity test of a floor scale? General Measurement Device and Calibration Topics 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
N Referencing of a standard's year in routine regulatory compliance documents Other Medical Device Related Standards 3
M Medical Device News FDA - Eliminating Routine FDA news 14-09-18 - Re-Review of Third Party 510(k) Reviews Other US Medical Device Regulations 0
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
C Dose Mapping - How to relate back to Routine Monitoring Position ISO 13485:2016 - Medical Device Quality Management Systems 3
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
J FDA Routine Inspection Pre-Anouncement - What will be checked? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Identifying Routine and Non-Routine Activities: OSHA OHSAS 18001 Occupational Health & Safety Management Standards 6
S How you define 'Normal & Abnormal' Conditions and 'Routine & Non-routine' Activities ISO 14001:2015 Specific Discussions 8
J Routine test for MD finished product IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
RoxaneB Environmental Objectives - Do they need to be linked into with Routine Indicators? Miscellaneous Environmental Standards and EMS Related Discussions 6
RoxaneB Search for another name for "Standardization Process" or "Routine Management" Quality Tools, Improvement and Analysis 4
D Line clearance - Routine components in the prep room for universal use ISO 13485:2016 - Medical Device Quality Management Systems 8
R Inspection and Detection - Kit to production - Need an inspection routine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
I IATF Lab Scope Testing Qualification and Competency Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 0
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 3
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam MDL in Canada without Canadian Electrical Testing Canada Medical Device Regulations 0
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
M Workplace Drug Testing in 2020 Misc. Quality Assurance and Business Systems Related Topics 9
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 13
