RTY (Rolled Throughput Yield) - Use Poisson Distribution Calculation
stanley.su
I am glad here are so many friend with solid experience and knowledge, now i am confused for the following question:
Initially, we calculate the RTY use product of each FTY, but with Sixsigma training, the alternative calculation method is using Poisson Distribution, I tried to use different method to perform the RTY calculation, but the results are different.
Could anybody can help me to eliminate the confusion? Thanks in advance!
Stanly
Tim Folkerts
Re: RTY - Use Poisson Distribution Calculation
I haven't specifically seen calcuations using Poisson distribution, but presumably it related to how you deal with multiple defects on a single object. Typically the poisson distribution is used when a single part can have multiple defects, while the binomial distribution is used when there can only be only one defect.
For example, if there is an average of 1 defect for every 10 parts, and you run 100 parts through, you could either have
  • 90 good and 10 bad (for a typical binonomial-type process)
  • 91 good, 8 bad, and 1 double bad (for a typical poission-type process)
Both have 10 total defects, but the calculations would be slightly different if you can have two (or more defects) on a single part. The poission-type process has a slightly better yield, even though the defect rate is the same!
Tim F
Tim Folkerts
Stanley,
There is much more to say on this subject. You might also check the threads listed at the bottom of this page. They show previous discussions on the topic of RTY.
Tim F
B How RTY (Rolled Throughput Yield) applies to different industries Manufacturing and Related Processes 1
N Definition TDU (Total Defects per Unit) and RTY (Rolled Throughput Yield) Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
H Rolled Throughput Yield (RTY) Loss - Can you measure in PPM? Six Sigma 3
H Rolled Throughput Yield (RTY) Calculations for a Sequential Process Six Sigma 2
B How to define and Calculate the DPU, DPMU, DPMO, Yield, Rolled Throughput Yield (RTY) Manufacturing and Related Processes 3
S DPMO (Defects Per Million Opportunities) vs. RTY (Rolled-Throughput-Yield) Six Sigma 7
L RTY (Rolled Throughput Yield) Calculation Other ISO and International Standards and European Regulations 4
M Question About Rolled Throughput Yield Manufacturing and Related Processes 5
M Rolled Throughput Yield Benchmarking 0
P Is throughput yield the same as FPY or FTY? Rolled Throughput Yield Manufacturing and Related Processes 3
J SST .625 dia Cold Rolled 303 bar and Magnetism Manufacturing and Related Processes 6
L Wearing an ESD Smock with Rolled Up Sleeves Misc. Quality Assurance and Business Systems Related Topics 4
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
B Hot Rolled Steel Coil Rust Prevention Tests Manufacturing and Related Processes 3
Bev D World Class Rolled Throughput Yields - 2012 Six Sigma 1
F Rolled Throughput Yield and Confidence Interval Six Sigma 3
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
G How do I calculate PPM from a Rolled Wire Suppllier Supplier Quality Assurance and other Supplier Issues 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
F Technical question - U-BOLT microscopic cracks on the tooth of the rolled thread Manufacturing and Related Processes 14
C Standard for surface roughness on hot rolled steel Manufacturing and Related Processes 2
J How to Define Scrap Metrics & Objectives - Stamped Cold Rolled Steel Fasteners ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E NCR (Nonconformance Report) for device defects - Hot rolled coils Nonconformance and Corrective Action 1
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
K Resistance Welder Settings for cold rolled and galvanized steel Manufacturing and Related Processes 3
R Rolled Throughput Yield - Is anyone using this metric, and if so, how Lean in Manufacturing and Service Industries 6
apestate Tolerances for cold rolled, hot rolled, DOM tubing Other ISO and International Standards and European Regulations 10
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
K Definition Throughput - Definition and Calculation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
F Throughput time measurement Cpk summary Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Calculating Throughput Yield or Yield Six Sigma 10
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
