Rules of an audit interview - Writing a Cheat Sheet for Managers
Z
Zuggy
Hi
I am in the process of writting up a short cheet sheet for my managment regarding external audits. I am using the ISO:19011 auditing gidlelines for template. My question is:
During the interview section of the audit can the auditee have a represenative in the same room while the audtor is intervieing the employee?
Tim
:thanks:
AllanJ
Zuggy said:
Hi
Tim
:thanks:
Yes. But the other person maybe either an escort for the audit team or an observer. In either case, onlky the auditee must be allowed to answer whatever questions the auditor (audit team) might pose.
Z
Zuggy
Ok,
If the "guide" is some one like the company ISO person can I step in when a auditor may lead the employee or ask question that may be out of the expertice of the employee?
Tim :thanks:
AllanJ
Zuggy said:
Ok,
Tim :thanks:
If the employee does not have the expertise, why has that person been assigned to the particular process? In this case, No you cannot intervene: the auditor has found a problem with the training/ competence/ assignment of the auditee.
But, if the auditor is addresssing the wrong person, as the guide, you should take the hit for getting the auditor to the wrong place. In that case, apologise and learn your own (personal) lesson.
It is wrong, though, for an auditor to lead an auditee into an incorrect answer or to a predrawn conclusion. But, a good company will have trained its own people in how to be audited such that they are aware of the need to resist being lead along to an incorrect/ unfair conclusion. Process owners should be trained to respond accordingly. As the guide, take note of the situation. Then, at the exit intervioew you have every right to object to the auditor's inaccurate conclusions. One of my 12 Golden Rules of auditing, in my books etc. is that the auditor: must "always present a true and fair view". Thus, if the auditortries to present a view that is not fairly based, the auditee has every right to object. After all, the auditor's conclusions will go on file and might later mislead non-participants.
Caster
An Early Cover
Who is expeced to answer
Zuggy said:
Hi
Tim
Tim
Here is what we do. Similar to what Alan says. The auditee should be able to answer..if not there is a problem.
Audit Roles and Responsibilities
There are three groups involved (auditee, process owner, audit guide)
Audit Guides (QA)
Bring the auditor to the area, and introduce him to the process owner
Stand ready to assist if auditee and process owner are not able to answer
Observe the audit, interpret QS/TS rules to benefit the company
Process Owner
Please be present at all times during the audit to add your support and authority
If you are called away for urgent matters, we will move to another area and come back to see you when you are available
If you can’t attend at all please appoint a deputy to act for you
Auditee (Team Members)
The auditor will want to ask Process Owners Team Members questions since these are the people doing the work
Team Members will be expected to be able to answer the audit questions
If they can’t answer, then the process owner should step in to provide an explanation
If the process owner can’t provide an answer, then the audit guides will try to resolve the issue
Audit Guides are “The Third to Speak” – and if we speak it means there is a problem in your area
David Hartman
I have always taken a little different approach than what Allen is posing. I have always assigned an Internal Auditor as a guide for the Third-Party Assessor (or even to a Second-Party auditor).
In addition to the role of guide, I have asked that our "guides" participate where necessary as "interpreters", where the external auditor may not be using jargon that is understood by the auditee and it becomes necessary for the guide to step in and re-word the auditor's questions in an effort to clarify the question for the auditee. The guide is NOT to answer the question, nor are they allowed to guide the auditee towards a response (other than forming the question in a way understandable by the auditee).
I have never had an external auditor object to this methodology, and in-fact have found many that have been thankful for the assist.
AllanJ
ddhartma said:
In addition to the role of guide, I have asked that our "guides" participate where necessary as "interpreters", where the external auditor may not be using jargon that is understood by the auditee and it becomes necessary for the guide to step in and re-word the auditor's questions in an effort to clarify the question for the auditee. .
That can be OK, but, I have always taught the auditors that eye contact is important with the auditee and to rephrase the question if it seems the auditee cannot understand it. Another of my 12 Golden Rules is: "Always communicate effectively with the auditee (process owner)."
Thus if the "guide" needs to translate, in order for the auditee to comprehend, it suggests the auditor is less than accomplished in his/ her question technique.
Cari Spears
ddhartma said:
...a little different approach than what Allen is posing...
This was the response that was forming in my head - I could not have said it better. I just wanted to also add that there is nothing wrong with anyone saying "I don't know the answer to that - I would go ask so-and-so or go look it up in procedure XYZ."
Cari Spears
We are talking about external audits. Besides - I am way less "rigid" about this with internal audits. I take advantage of internal audits to "coach" auditees in order for them to feel more comfortable when the registrar or customer auditor is here.
AllanJ
I care not of the type of audit. It is for the auditor to communicate effectively with the auditee. If on an internal audit, the auditor is incapable of that there is a problem as the internal auditor should have the advantage of being more intimately acquainted with the organization's processes and therefore able to express his/ her questions accordingly.
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
shimonv Rigid rules for handling supplier audit findings ISO 13485:2016 - Medical Device Quality Management Systems 11
M Why have IATF rules required the CBs to audit remote supporting functions at first? IATF 16949 - Automotive Quality Systems Standard 11
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
Mikey324 Questionable Audit Findings after Rules 4th Edition Release IATF 16949 - Automotive Quality Systems Standard 4
J Audit days calculator based on Rules 4th IATF 16949 - Automotive Quality Systems Standard 2
Manix Should a 3rd Party Auditor Audit against IATF rules and not just the ISO standard? General Auditing Discussions 4
QMMike ISO/TS 16949 (Rules 3rd Ed) Audit Man-day Requirements IATF 16949 - Automotive Quality Systems Standard 3
M Supporting Sites, Separate Certificates and Audit Reports - IAOB TS 16949 rules? Registrars and Notified Bodies 9
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
S Drugs and Cosmetics Rules - India Other Medical Device Regulations World-Wide 0
G Do HIPAA Rules Apply to a 3rd Party Logistics Shipper? Other US Medical Device Regulations 2
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
N Is there a standard / rules pertaining to eating in medical device manufacturing area? Manufacturing and Related Processes 5
M Informational TGA – Advertising health products: Rules about safety claims in advertising Medical Device and FDA Regulations and Standards News 0
D Volkswagen Complaints Management Rules Customer and Company Specific Requirements 0
M Informational US FSA – Surgical staples – Guidance and proposed rules Medical Device and FDA Regulations and Standards News 0
M Informational MDCG 2019-2 Guidance on application of UDI rules to device-part of products referred to in Article 1(8), 1(9) and 1(10) of Regulation 745/2017 Medical Device and FDA Regulations and Standards News 0
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
M Medical Device News FDA Withdrawals Two Proposed Rules Other US Medical Device Regulations 0
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C What are rules to notify customers if IATF cert is put on hold? IATF 16949 - Automotive Quality Systems Standard 2
L What are the rules on significance of digits in numbers in IEC/ISO standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Rules associated with introducing new QMS processes IATF 16949 - Automotive Quality Systems Standard 1
R IATF 16949 certification rules IATF 16949 - Automotive Quality Systems Standard 5
K Rules or guidelines for quoting FDA announcements and such? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M INDIA - GSR 78 (E) - New Medical Device Rules - 2017 Other Medical Device Regulations World-Wide 6
L Hypothesis Testing + Thumb Rules Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Percentage Thumb Rules for Quality Costs Misc. Quality Assurance and Business Systems Related Topics 1
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
Sidney Vianna IATF 16949 Areas of Impact - Rules 5th Edition Document (February 2017) IATF 16949 - Automotive Quality Systems Standard 0
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
Marc Rules for Posting in the Paid Consulting, Training and Services Forum Paid Consulting, Training and Services 3
M I am looking for the text of the copyright 'rules' for AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F Rules to respect when changing from Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Ajit Basrur New Medical Device and IVD Registration Rules - Pakistan Other Medical Device Regulations World-Wide 5
A PUWER (Provision and Use of Work Equipment Regulations) and old machines (UK rules) Occupational Health & Safety Management Standards 4
M Translating and Rotating Rules when programming or measuring with a CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Are there specific rules regarding ISO 13485 and R&D? ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO/TS 16949 Rules about Commodities IATF 16949 - Automotive Quality Systems Standard 4
N IATF Appeals on ISO/TS16949 Rules - 4th Ed. - Removal of Site Extensions IATF 16949 - Automotive Quality Systems Standard 2
M Scope content of TS 16949 certificate under Rules 4 IATF 16949 - Automotive Quality Systems Standard 6
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
