Run Down Adapters Calibration Processes
johannajamison
We have several of Run Down Fixtures/Adapters that we use regularly for torque calibrations. I was wondering if anyone could please tell me a little about Run Down Adapters and their calibration process. We take them apart every so often to grease the parts, but I wonder is there a verification process for checking that a Run Down Adapter is working properly after the device has been disassembled and put back together?
Thank you
mhannon
Calibration leader
I do not believe calibration is required on RDAs. They are only there to simulate a load (a screw or nut/bolt) therefore reducing some of the sharp impact which creates irregular high peaks in torque, thus providing more repeatable measurements.
They will not reduce any of the force, just smooth out sudden impact.
Analyzing a pneumatic driver directly with a torque analyzer will show different results than if you measured the torque on a bolt going into a threaded hole. RDAs are designed to give you results that are more in line with its intended real world use, instead of measuring the output of a driver in a lab setting.
Instead of enrolling them into our calibration program, we keep ours on a preventative maintenance list and follow the manufacturer's (Mountz) recommendation of disassemble, clean, and re-apply molybdenum grease to the threads only, every 6mo.
Every manufacturer of torque analyzer recommends using RDAs (for pneumatics, not hand tools) to improve results, but I have never seen anyone mention calibration.
johannajamison
Thank you for your reply mhannan. We recently purchased a new Mountz 1-10 run down adapter. We check new adapters when they come in and the tool worked correctly when we first tested it. However, it was taken apart last week for cleaning and the molybdenum grease was applied, and now it appears to be slipping/jumping around the 1-4 mark when we use it to calibrate our tools. I was wondering if there is a way to verify the adapters after they have been cleaned and reassembled. Could we do a repeatability test using a power tool?
mhannon
Calibration leader
Which model are you using? I am assuming you are saying yours is rated for the 1-10 lbf.in range?
There are a couple types: manual screw ones which must be manually reversed each time, auto reversing, spring type... there may be more.
I really only have experience with the manual screw ones. If this is what you are using, I can recommend cleaning all of the old grease out first. Don't just re-apply new grease. There could be shavings or other debris that is causing the threads to bind up. We wipe off as much grease as possible, then clean out the threads with alcohol as best we can, then lightly grease only the threads. Don't pack it full, and the washers don't need to be greased either.
If you have a manual type and you say it is slipping/jumping, it sounds like the threads are dirty or damaged.
Also, ensure it is being used correctly if it is a manual reversing type. You need to loosen the bolt after every run. You don't need to back the bolt all the way out, just enough to take the pressure off of the washers inside. Most are only designed to be used in clockwise rotation (tightening the bolt in the RDA). If you test in counterclockwise, you will simply be unscrewing the bolt and not applying any force to the RDA.
As far as verification, If you have a known good DRA, you can take several readings using that one. Then (using the same power tool and torque analyzer) switch to the RDA in question and take several readings. Hopefully they are similar. If not, you have a damaged RDA. I definitely recommend having a couple on hand.
johannajamison
Hi mhannon,
It is a Mountz RDA-10i with a 1/4" Sq. Dr., it must be manually reversed but does have a spring. shown here: RDA-10i Run Down Adapter (mountztorque.com). Thank you again for your recommendations. We will clean it thoroughly and reapply grease lightly, as well as check the threads for damage. We only have one of this kind, so we will purchase a few more in order to have a couple on hand to compare.
Thank you!
B Run at Rate - when to perform / is it mandatory? IATF 16949 - Automotive Quality Systems Standard 19
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
H Can I just forget physical run charts and start digital? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
O Production run inventory sell-by expiration date? APQP and PPAP 3
P Arena simulation, How can my Arena model have exactly the same output each time I run it? Process Maps, Process Mapping and Turtle Diagrams 0
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
I New to LEAN but not to Quality - How to run Kaizen events Lean in Manufacturing and Service Industries 1
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 15
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
E Translating from Automotive to Medical Device industry - [email protected] Other Medical Device Related Standards 2
Q How to run a Management Review Management Review Meetings and related Processes 10
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
M What is required to run human clinical trials in France EU Medical Device Regulations 9
M Case study - If the restaurant (ISO 9001:2015 certified) was run by 2 persons covering cooking and purchasing processes (Mother and Father) supported ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
U Run & rate for bulk materials IATF 16949 - Automotive Quality Systems Standard 6
N Can you use parts from Run at Rate to use in your PPAP? APQP and PPAP 4
L Formulas to be able to answer these Run Chart questions Statistical Analysis Tools, Techniques and SPC 7
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W AS9100 Clause 8.5.1.3 Production Run Verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Supplier Sample Run Rejection ISO 13485:2016 - Medical Device Quality Management Systems 3
I Run a batch every year to revalidate the validated condition? Qualification and Validation (including 21 CFR Part 11) 4
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
W AS9100C registration - How long does the system have to run before initial audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Standardized P Chart for Short Run Production Statistical Analysis Tools, Techniques and SPC 13
B How to Demonstrate Stability and Repeatability in very Short Run Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Y Resin Use - Engineering Run to GMO run for the same Product US Food and Drug Administration (FDA) 1
M Setup Time vs. Economic Run Quantity Manufacturing and Related Processes 1
D What to look for in a well run Injection Molder Manufacturing and Related Processes 11
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
S Should PPAP Samples Come from a Production Run? APQP and PPAP 3
F Run Minitab Macro from Excel Using Minitab Software 3
E How to run an OLS or Logistic Regression when I have Panel Data in Minitab Using Minitab Software 1
W Production Trial Run in AIAG APQP and Run at Rate (GP-9) GM 1927 APQP and PPAP 2
M Average Run Length (Student Question) Statistical Analysis Tools, Techniques and SPC 3
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
R What is a "DNOM Chart" in reference to Short Run SPC? Statistical Analysis Tools, Techniques and SPC 2
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
CalRich Retention of First Piece from each Production Run IATF 16949 - Automotive Quality Systems Standard 11
