Safeguarding Calibration on Digital Equipment
aamoroso
#21
If an operator inadvertantly sets the zero on his calipers and makes bad product that goes unoticed until the next operation or worse shipped to a customer our NCP procedure would activate an investigation. If it could be determined that the operator used the instrument incorrectly, the corrective action procedure would kick in and the corrective action would state training in proper use of measuring instruments is required.
I would never say that Starret tools or Brown & Sharpe or any others make a product which is faulty or not acceptable. To remove adjustability from a measuring tool you would have to have solid measuring for everything you measure. There is nothing stopping someone from using a tool incorrectly other than training. If your operators do not understand how to use a pair of calipers properly train them or take the calipers away.
#22
aamoroso said:
...the corrective action procedure would kick in and the corrective action would state training in proper use of measuring instruments is required.
But you would probably have a job description that would include the need for the operator to be able to use the tools of the trade, no? So maybe the root cause goes a bit deeper.
aamoroso
#23
Absolutley JSW05,
If you go back into my previous posts, I have preached that proper training is safeguarding against bad adjustments of the calipers. :agree1:
#24
Hehe - here is my 2 cents since I've been calibrating mechanical tools since 1975:
There is a difference between mechanical and electronic gages. In the mechanical world, we have a mechanical zero that is typically set at 3 points on a vernier micrometer for example. Once we have these 3 zero points set, we can then begin calibration. Once the vernier gage is calibrated and leaves our lab, the operators will usually call us to verify the gage since it no longer indicates a mechanical zero (they do not have the wrench necessary to make changes on the barrel). Usually the deviation from zero is the result of debris on the anvil surfaces. Once we show the operators that they need to wipe the anvils to check, they can see that the zero returns to it's original position. This mechanical zero remains accurate as long as the micrometer is not dropped or used as a C-clamp. This is the way it was 15-20 years ago.
Today with digital gages, you are no longer setting a mechanical zero, but instead a electronic one that can be set anywhere on the gage. We no longer get calls to verify gages because it's done by the operator, who might rezero the gage with debris on the anvils; thus, preventing an accurate measurement. I agree that training plays a very important part, but I guess I'm from the old school - I trust the ability of mechanical gages more readily than electronic.
Ryan Wilde
#25
Jeff Frost said:
JSW05
Gee and all the years I have been using a ASME recognized term Gauge which is an instrument for measuring, testing, or registering pressure above atmospheric pressure and its incorrect English.
You would thank that when an organization like ASME who wrote a pressure gauge, oops gage standard B40.1 would only use those terms recognized in a Quality Dictionary.
Boy that causes my Hysteresis to have a big error, oops can't find Hysteresis in Quality Dictionary. Now what do I.....
Jeff
Gauge, as in Gauge Pressure (psig) is referenced to atmospheric pressure. It is the most common type of pressure gauge, as opposed to an Absolute Pressure Gauge (psia), which is referenced to absolute zero (a perfect vacuum).
Now, none of this has anything to do with whether someone spells the measuring device Gauge or Gage. Gage is simply a commonly used variant spelling of gauge, which is the proper term. It is akin to spelling through as thru - technically it is incorrect, but so common that it is the norm (in the USA that is).
jane_ackerman - 2010
#26
Safe Guard Integrity
At a previous company that I worked for, we applied sealing wax to the gib stop screws on calipers. If the gib stop screws work loose and allow the gib to move, this can affect the accuracy of the gage.
Another example of this is with snap gages. After the dimension is set, some kind of sealer should be put on the adjustment screws so they don't come loose and allow the anvils to move.
For mics, you may want to plug the thimble adjustment hole and remove the little tool (from operator access) that is used for making that adjustment.
Just some food for thought.
~Jane
apestate Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure General Measurement Device and Calibration Topics 6
Ajit Basrur How to demonstrate Safeguarding of "Intellectual Property" in an Organization? Other ISO and International Standards and European Regulations 7
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 4
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
