Safety in the Workplace
Muhd Firdaus
Dear members,
i just want to get some opinion and input on the following matter :
a) In terms of safety at workplace, what are the steps to implement safety standard at workplace.
b)If the company is totally new to workplace safety ,how to start to implement it .
c) Any format or checklist for safety. I hope i can get one sample here
Thank You
mguilbert
Re: Safety at workplace
First you will need to know what you standard you will be using. Whether they are ISO or Governmental. Then you will need to know which equipment and procedures that you have that fall under those requirements. Next ensure training has been provided to appropriate personnel. As far as checklist they may have some on this site but you may need to adjust them based on your requirements.
BTW. Thanks for caring about the safety and the health of your employees.:applause:
Hope this helps some.
Boingo-boingo
If your organization is serious about workplace safety, then it should take a professional approach to it, such as putting a system in place to deal with occupational health & safety. There are a number of standards out there that help any organization in developing an OHS management system. The most widely adopted standard is the OHSAS 18001 document. It's sister document, OHSAS 18002, provides guidance on the implementation of 18001.
No checklist will ever replace a robust system. Good luck to you.
Michael_M
I am in the process of re-vitalizing our Safety system. You are lucky in your program is new so you will not have to cross some of the same hurdles I did.
I started with the safety manual. From this I had my starting point.
The state where I live has a sister organization to OSHA for training only (they clearly state that unless it is an immediate danger, they cannot report anything to the enforcement side). They provide training (took the 'how to write a safety manual') and will come out to our plant and assist us in any safety issues. You can see if your state (or country) has a similar service.
Mikishots
All above are good, but make sure you have senior management support. Without it you will fail.
I'm not convinced at that - a few years back, two companies we looked at had safety programs that were considered world class, with other companies coming to learn from them; upper management at both businesses was not interested at all, but it was well implemented by people that cared enough about it anyway. Once the program was getting media exposure, the big boys stepped up and took all the credit (for a program they knew very little about!).
somashekar
Management support / drive is good off course. This will be more essential when you desire to be certified as a management system implementing occupation health and safety.
As a manager at your shop with absolute controls, you can do many things. Look at potentially what can happen and what has happened so far. Discuss and decide how it can be avoided. Any stuff like good house keeping, guards to rotating machines, avoiding spills and leaks, proper storage of materials and suitable use of handling equipment, defined walkways, warning and alerts, ensuring that the machines have emergency stops and where possible the machines operate with guards on / operator uses built in safety mechanisms, (and does not tamper with it and increase danger for convenience or speed of production). Keep First aid in place nearby and equip them with needed things and maintain them. Providing protective clothing, proper personnel protective equipment where necessary and inculcating discipline to use them.
Within your defined area, based on above and your experience, assess what are the risks and the hazards. Grade them with your own knowledge and maturity, and plan what needs to be done to address the risks. Use the below logic which the OHSAS 18k states...
a) elimination;
b) substitution;
c) engineering controls;
d) signage/warnings and/or administrative controls;
e) personal protective equipment.
harry
Dear members,
Thank You
If you are in Malaysia, contact the local Department of Occupational Safety and Health (JKKP) for help.
They will visit you and tell you what to do for each of your processes and machinery. Not as comprehensive as having an OHSAS 18001 system but nevertheless, a good starting point as well as meeting minimum regulatory requirements.
K
kgott
Dear members,
Thank You
See if there is any laws that relate to safety in your workplace. Identify which laws or regualtions (commonly known as legisaltion or statutes) apply to your companys busienss.
Then ask 'what do we have to do to comply with each of the laws'
The answer is most likely along the lines of 'we need to have a documented way of doing this job safely that is known by each person who does the job or uspervises that task, or, we need to have a documented way of complying with this law.
After the doing the above ask yourself the question 'how could someone get hurt in this workplace and what do we need to do to prevent it from happening.'
Again, this will result in having a documented way of..... etc. You can call them procedures if you like.
You also need to have a way of assessing the risk of the event occuring and the severity of possible results of the event occuring.
hope this helps
ssz102
for the steps and standard to implement safety, refer to goverment law and regulations and EHS, meanwhile, trainning and identification are provide to appropriate person and on site is necessary, as well as related records
V Advantages of Training Employees about Health and Safety at the Workplace Occupational Health & Safety Management Standards 19
A Safety Culture in Top Management - The Workplace Safety & Health Act Quality Manager and Management Related Issues 25
Jen Kirley Slaying Workplace Safety Costs The Reading Room 4
M Does ISO 9001 have anything to do with Workplace Safety? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
ScottK Safety in the Workplace Award Winners Funny Stuff - Jokes and Humour 0
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
D Safety data sheets software REACH and RoHS Conversations 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
N German National Requirements - Safety Officer/Authorised Rep Other Medical Device Regulations World-Wide 0
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
A Baby food manufacture - food safety requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 0
dgrainger Informational EU medical device website change from 'Growth' to 'Health and Food Safety' (6/2020) Medical Device and FDA Regulations and Standards News 0
D Safety Assurance Case Report Format ISO 14971 - Medical Device Risk Management 4
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K Things to learn during lockdown.... Safety-related books/articles/threads Book, Video, Blog and Web Site Reviews and Recommendations 2
JAMESH Job Safety - Lockout/Tagout and Respiratory Protocols Manufacturing and Related Processes 3
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
M Differences in post market safety reporting for Combination Product Applicants Medical Device and FDA Regulations and Standards News 1
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
adir88 Information of safety can reduce risk now? ISO 14971 - Medical Device Risk Management 12
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Do you need an Applicable general safety and performance requirements Checklist? EU Medical Device Regulations 2
S VW Supplier Product Safety Representative (PSB) upgrade to PSCR VDA Standards - Germany's Automotive Standards 4
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
T Confirming The Local Safety Regulations for Equipment - I'm in Malaysia General Measurement Device and Calibration Topics 1
MrTetris Unacceptable risk and information for safety ISO 14971 - Medical Device Risk Management 16
A Contraindication Safety Statement in website - Radiotherapy equipment Other Medical Device and Orthopedic Related Topics 1
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C Safety lettering on a product CE Marking (Conformité Européene) / CB Scheme 5
M EU – Chemical Safety Report – CSR – REACH Authorisation decisions – Triton X-100 – Ortho-clinical-Use1 REACH and RoHS Conversations 0
M Informational EU – Minutes of the 24 July 2019 SCHEER Working Group on safety of breast implants in relation to anaplastic large cell lymphoma (BIA-ALCL) meeting Medical Device and FDA Regulations and Standards News 0
M EMC Directive and product safety standards CE Marking (Conformité Européene) / CB Scheme 1
S Safety Class A with no test? IEC 62304 - Medical Device Software Life Cycle Processes 1
M Informational MDCG 2019-9 Summary of safety and clinical performance A guide for manufacturers and notified bodies – August 2019 Medical Device and FDA Regulations and Standards News 0
D Requirement of Pharmacovigilance (Drug Safety) Risk Based Strategic and Tactical Audit Plan General Auditing Discussions 0
M Informational Several US FDA draft guidances, including some specific device guidances for the Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
M Informational USFDA final guidance – Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
M Informational Medical Device Safety Action Plan: Protecting Patients, Promoting Public Health Medical Device and FDA Regulations and Standards News 0
S System safety assesment Federal Aviation Administration (FAA) Standards and Requirements 0
M Informational TGA Consultation: Proposed changes to medical device essential principles for safety and performance Medical Device and FDA Regulations and Standards News 0
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Is there a counterpart to the General Safety and Performance Regulations for the USA? Other US Medical Device Regulations 2
