Safety Requirements for Bioimpedance Measuring Device Power via USB Cable
eezud
I want to design a a battery powered device which measures bioimpedance. It is intended to be powered only by an external battery pack (5V) via a USB cable. I want to make sure that the device is safe and fulfills the IEC 60601 safety requirements. Although the intended power supply is only 5V, I see that the use of USB cable increases the risk of misuse. e.g., the user can connect it to different USB power source. Also, the external battery pack and its charger are not medically approved.
1. Is there any special requirements for USB power supply in 60601? Or, do I have to treat it as the mains supply (240V)?
2. Will using a medically approved isolated dc-dc converter inside my device be enough for the isolation requirements?
Peter Selvey
If the equipment bioimpedance, then it needs a Type BF isolation barrier which means the measurement circuit is isolated from all other parts by a 1.5kV/4mm barrier (isolated dc/dc power supply, optocouplers etc, visible 4mm separation between tracks on the PCB etc).
Apart from this there are probably no special concerns.
Other parts of the equipment can be treated as operator accessible and only need to comply with IEC 60950-1 requirements.
If the equipment needs to be connected to a PC for normal use (e.g. for display of data or setting parameters), then if the PC is not specified it is up to the user to verify the PC is IEC 60950-1 compliant. You might want to consider risk that the user cannot practically do this, as has been discussed in other threads. In that case a possible risk control could be to increase the BF isolation barrier to 4kV/8mm. Another option may be to advise the use of well known trustworthy brands.
eezud
Hi Peter,
I would like to understand more clearly. The standard says that ME shall have 2 Means of Protection. I checked the table 3, and it states the test voltage for reference voltage:
212 < U < 354V, 1 MOPP = 1.5kV and 2 MOPP = 4KV
and table 8, says
for U < 250ac, 1 MOPP = 4mm, and 2 MOPP = 8mm
I guess your suggested values are from table 3 and 8. Does it mean that if other operator accessible parts of the ME comply with 60950, I just need 1 MOPP?
N German National Requirements - Safety Officer/Authorised Rep Other Medical Device Regulations World-Wide 0
A Baby food manufacture - food safety requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Do you need an Applicable general safety and performance requirements Checklist? EU Medical Device Regulations 2
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Informational EU draft act – Single-use medical devices – safety and performance requirements for reprocessing Medical Device and FDA Regulations and Standards News 0
C CMDR Essential (Safety & Effectiveness) Requirements Checklist? Canada Medical Device Regulations 9
H External power supply - requirements in safety/EMC test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
L IATF 16949 requirements for Product Safety Procedures IATF 16949 - Automotive Quality Systems Standard 14
Marc Definition GSPR - General Safety and Performance Requirements Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
M Annex I - General Safety and Performance Requirements. Precise identity - how provided EU Medical Device Regulations 6
L IATF 16949 - Requirements for Personnel Safety? IATF 16949 - Automotive Quality Systems Standard 15
T ISO 12100:2010 - Machine Safety Requirements Other ISO and International Standards and European Regulations 8
shimonv Safety requirements for secondary cells and batteries IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B China GB4943.1 Safety Requirements - PCB Markings China Medical Device Regulations 0
A VW Supplier Product Safety Representative (PSB) Responsibilities and Requirements VDA Standards - Germany's Automotive Standards 4
Sam Lazzara EU MDR Safety & Performance Requirements vs. MDD ERs (June 2017) EU Medical Device Regulations 3
S FDA Class I Medical Device Safety and Efficacy Data Requirements Other US Medical Device Regulations 5
V VAG Customer Specific Requirements - Product Safety Responsibility Customer and Company Specific Requirements 1
J Electrical Safety Test Requirements for Brazil Other Medical Device Regulations World-Wide 10
S An overview of the automotive safety requirements around the globe; interior products IATF 16949 - Automotive Quality Systems Standard 3
M Incorporating Safety Requirements into Standard Operation Procedure Document Control Systems, Procedures, Forms and Templates 4
M Record Retention requirements for Safety Items Document Control Systems, Procedures, Forms and Templates 7
S Legal Requirements for Test Certificates on Safety Matches for the UK please Supplier Quality Assurance and other Supplier Issues 4
B ISM Code (International Safety Management Code) Requirements and ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S MDD 93/42/EEC Essential Requirements and Safety definition CE Marking (Conformité Européene) / CB Scheme 2
T Safety & Health Documentation Responsibilities and Requirements (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Current Products on the Market and IEC 60601 3rd Edition Safety Re-Test Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
S New Draft FDA Guidance on Enforcement of INDs - Safety Reporting Requirements US Food and Drug Administration (FDA) 0
S ISO9001 and "Health and Safety" Procedure Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Basic Legal Requirements for OHS (Occupational Health and Safety) Occupational Health & Safety Management Standards 2
W PHA (Preliminary Hazard Analysis) and Safety Case per UK MOD requirements Occupational Health & Safety Management Standards 2
J Assessing the understanding of occupational health and safety requirements Occupational Health & Safety Management Standards 3
K EN746-2 Industrial thermoprocessing equipment - Safety requirements.... Other ISO and International Standards and European Regulations 1
M 7.2.1.c Product requirements - Determining product, enviroment, health, safety, etc IATF 16949 - Automotive Quality Systems Standard 4
Randy Mexican occupational health and safety requirements Various Other Specifications, Standards, and related Requirements 3
C IEC60601-1 3rd edition +ve vote - Medical Electrical Equipment Safety Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R UL Requirements - Received a variation notice - Safety caution text Various Other Specifications, Standards, and related Requirements 3
C VW audit requirements Formel-Q - D/TLD - Safety Part - What is D/TLD? Customer and Company Specific Requirements 8
Gman2 ISO 9001 and Requirements as related to SAFETY - Procedure Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
D Safety data sheets software REACH and RoHS Conversations 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
