Sales Forecasting by Using Time Series Decomposition [Minitab]
O
ozkaynakm
Nowadays, I try to forecast the sales figures of 8 weeks to come by using performed sales. I have a lot of [weekly] data belong to previous years starting from 2005 up to now.
==> How many weeks should be taken into account for Decomposition?
==> What about your comments If I prefer using the other methods [like Winters, double exp...]. Please note that the minimum accuracy measures are obtained from decomposition. [Also the seasonality and trend is in question regarding my data].
I enter the seasonal length as 52 since a period contains 52 weeks.
Finally, I've obtained accuracy measures;
MAPE 43
MAD 18051
MSD 682263979
Especially, I am not comfortable because of high MSD value. It appears as a very big value to me.
==> Is it reliable to use the forecast numbers extracted from this analysis in view of these measures?
Thanks in advance.
Okan
Stijloor
MAPE 43
MAD 18051
MSD 682263979
Thanks in advance.
Okan
Any Minitab experts who can help Okan?
Thank you!
Stijloor.
Tim Folkerts
From Minitab Help:
MAPE
, or Mean Absolute Percentage Error, measures the accuracy of fitted time series values. It expresses accuracy as a percentage.
MAD, which stands for Mean Absolute Deviation, measures the accuracy of fitted time series values. It expresses accuracy in the same units as the data, which helps conceptualize the amount of error.
MSD stands for Mean Squared Deviation. MSD is always computed using the same denominator, n, regardless of the model, so you can compare MSD values across models. MSD is a more sensitive measure of an unusually large forecast error than MAD.
So since MAPE = 43, the model is on average 43% off from the data. That seems like a fairly large number so future predictions would alos likely be off by at least that percentage.
MAD is very similar, but it is not expressed as a percent. If X is your average sales, then (approximately) 43% of X = MAD. So I am predicting that your raw numbers average somewhere around 42,000 and deviate about 18,000 from that value.
MSD squares the deviation, so if you want to compare it to MAD, you should take the square root. (682263979)^0.5 = 26,120. This is noticeably bigger than MAD = 18,051, suggesting a few points with "unusually large forecast error", according to the Miniitab help.
Tim
O
ozkaynakm
Thank you Tim.
The variable that I used for Decomposition is weekly sales data. It is not average. The sum of sales performed during 1 week constitutes one row.
As far as I understand that the forecast results of this analysis is not reliable.
When I've taken a glance at the residual plots, the residuals show nonnormality. This is the another handicape when we consider the analysis.
These sales numbers have very big standart deviation according to the weeks. It could be one of the reason of this bad result.
Bill Pflanz
It is incorrect to compare MAPE, MAD and MSD since they are just different methods of calculating forecast error. The correct way to evaluate a forecast is to use a number of forecast methods, calculate the forecast error using one (and only one) forecasting error method and choose the forecast method with the lowest error. Common forecasting methods are moving average, weighted moving average, exponential smoothing and seasonal variations.
The number of weeks is not that important unless there are cyclical or seasonal trends. If your business is seasonal then you need to use a seasonal forecast method with decompostion. I would recommend using 3 years of quarterly data.
Bill Pflanz
O Issue with free sales certificate for implants from China China Medical Device Regulations 0
Beth Savage Quality Solutions Sales Representative--Dayton, OH Job Openings, Consulting and Employment Opportunities 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
G Free Sales certificates for Medical Devices - List of countries EU Medical Device Regulations 4
M Covid Free Statements for Implants and sales reps. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
qualprod On Time Delivery KPI for sales? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Identical Sales Package in Different Countries Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
W Core Process Metrics AS9100D for Product Planning? Quotes and sales? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Farley.0 QMS Sales Goals & Quality Objectives Manufacturing and Related Processes 22
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
C Are we required to obtain a Certificate of Free Sales for export to China? Other Medical Device Regulations World-Wide 6
S Handling Cost of Sales requests for Customer Quality Manager and Management Related Issues 2
A ISO 9001:2015 Implementation for Marketing and Sales Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Customer Corrective Action requests and Sales Employees Promises AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G 7.3 Design and Development in a Sales and Service Organisation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Sales Department Internal Audit Internal Auditing 24
S ISO9001:2008 for Sales Office ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Local Agent and Sales Rights in countries like Brazil and Russia Other Medical Device Regulations World-Wide 2
Q Which ISO/TS 16949 clauses are applicable to auditing Quoting and Sales? IATF 16949 - Automotive Quality Systems Standard 19
M Manufacture and Sales of GHS Labels and Pictograms Occupational Health & Safety Management Standards 1
Ajit Basrur China breaks world record for car sales in 2013 ! World News 1
S Auditing Sales and Marketing Processes and Technical Support Canada Medical Device Regulations 2
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Supplier or outsourced? Medical Device installation, sales, training Other ISO and International Standards and European Regulations 7
I International Sales Legal/Regulatory Gray Area? CE Marking (Conformité Européene) / CB Scheme 3
E Marketing and Sales involvement in 8.2.1 Customer Satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Validation of SAP Purchase Order and Sales Order modules Software Quality Assurance 7
B Performance Evaluation for my boutique's Sales Staff Benchmarking 7
C Implementing ISO 9001:2008 in a small Sales and Service company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
N When your Owner is the Sales Guy... Quality Manager and Management Related Issues 6
E List of Sales Procedures required for ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y ISO 9001 Registration - Different Manufacturing and Sales Locations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Control and Traceability of Sign-ups for Sales of a Product Career and Occupation Discussions 9
F How to manage Intermediary Sales Agents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M SFDA Legal Agent and After Sales Agent in China - Differences? China Medical Device Regulations 3
V Query on TS 16949:2009 Certification for a Tool and Die Sales & Service office IATF 16949 - Automotive Quality Systems Standard 3
sagai Renewal of Canada Manufacturer Licence if there is no Sales (Only Support) Canada Medical Device Regulations 5
sagai Renewal of US Manufacturer Licence if there are no Sales (Only Support Activities) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Certificate of Free Sales (CFS) - Need to attach to each lot of exported product? Other Medical Device Regulations World-Wide 2
N Customer Service/Inside Sales Will Not Leave Us (Quality Assurance) Alone! Document Control Systems, Procedures, Forms and Templates 3
M Improving Purchases and Sales Sheets Manufacturing and Related Processes 1
B Sales vs. Quality vs. Manufacturing - Interactions and Responsibilities Quality Manager and Management Related Issues 13
Q Sales, different products/path to client, should be pictured each in Process Maps? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Sales Department KPI's (Key Performance Indicators) template and suggestions Misc. Quality Assurance and Business Systems Related Topics 1
Q Process Maps: Sales, different products, more boxes - Critique my map? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
