Same auditor shouldn't do two consecutive Internal Audits on same Process/Procedure?
Meggsy
Hi Guys,
I am looking after the QA area of my branch (~30 people), and do 4 Internal Audits each month (each one looking at a different Process or Procedure), each Process or Procedure being audited once per year. I have someone else audit me on the Document Control, Management Review and Internal Audit processes, since I look after these and can't really audit myself.
It has been suggested to me that I shouldn't do two consecutive Internal Audits on the same Process/Procedure, and that we should have a group of auditors on rotation. Everyone else here (including me!) is very busy, and I doubt I'd get the buy-in to ask others to do regular audits.
Does anyone know if this is the case? I have looked through AS19011, but this mostly seems to refer to certification-type audits, and not the informal compliance audits that we conduct. We certainly don't have teams doing audits here, what we look at is too minor to require that.
Thanks in advance.
Colin
Re: Same auditor shouldn't do two consecutive Internal Audits on same Process/Procedu
There is no requirement regarding someone doing consecutive audits on a process. It would be 'nice to have' someone different so that you get a different perspective but this is not practical for many organisations.
If there is the option to 'rotate' auditors, I would recommend that you do as you get different opinions depending on whether the auditor's own process is 'upstream' or 'downstream' or not connected to the process being audited. If it is not an option, just carry on auditing!
Al Hector
I agree with Colpart.
You are doing ok now, if you have the competence to do the audit, you follow your audit program and you don’t audit your own work.
May I ask who made this suggestion?
Of course that you can build a team of auditor who can audit by rotation different processes, but there is no requirement to do so.
All the best!
Alin
We seem to agree that this is a crazy suggestion! Meggsy, it sounds like you might be doing too much - too many audits, but it's difficult to tell. I only think it sounds like too much.
However, to answer your fundamental question - it is a good idea to do consecutive audits! You were there at the first audit, you can best decide what has happened since! The idea of 'fresh eyes' is a nice one, but not for an internal audit! Some organizations like to rotate their CB auditors, but for internal auditors is unrealistic and you will lose a lot of knowledge of particular issues etc.
Don't do it - but you might want to take a look at how many audits are being done and change the focus........
Randy
Not do 2 consecutive audits of the same process or activty? If that were true then 99.999% of my audit work would be invalid as it would almost be for all CB auditors.
Listen to Andy and Colpart and tell whoever to stick to their area of expertise 'cause auditing doesn't seem to be it.
Jen Kirley
Quality and Auditing Expert
I do almost all the auditing for my organization, against quality, safety, environmental and calibration lab standards.
The plus to having this is I can run to a thread of incremental improvements. This year I can focus harder on document control, while last year I hit hard on training.
On the flip side, there's something to be said for the "little boy at the parade" factor in having a fresh set of eyes look at a process.
In any case, there is NO requirement for rotation in any standard I have worked with.
Craig H.
This is almost laughable. A case could be made that the same person should audit every time to maintain consistency. Under the proposed criteria we would be in big trouble because I have done every internal audit here for, oh, 10 years or so, except for the QA department, and that has been audited by the same person all that time as well.
We are not in trouble. External audit NCs over the last five years can be counted on one hand.
DsqrdDGD909
Hi Guys,
Thanks in advance.
What kind of business? Do you find that the audits are effective at finding nonconformances and improving the system? If so, no requirement to change.
We use 5 auditors here to audit 10 processes (Departments) for 9001 and 3 of the 5 do 14001 as well. I think having them do different areas keeps them fresh and alert and shows the auditees that we are serious about our IA program.
Migre
Whilst I tend to agree with the majority of the replies here, you did state that the initial suggestion was just that - a suggestion? If so, that person's reasoning may echo some points already posted on this thread.
My initial thought (which is, not surprisingly, primarily coloured from my own experience) is to agree that you are fine to carry on as you are. However, there are pros and cons (in many of these examples, flip the pros on their heads to get the cons) to both methods of addressing this:
Same auditor on consecutive audits - pros:
Familiarity with the area of work (Processes, procedures, working practices, staffing levels, hierarchy, current pertinent issues (good or bad), product/service offered etc)
Familiarity with staff (Building good working relationships, confidence etc)
Complete awareness of ongoing non conformances / recommendations / issues identified via audits
Gradual removal of the 'fear factor' (amongst auditees and, on occasion, auditors?) - potentially leading to more productive audits of greater value
Different auditors on consecutive audits - pros:
As previously alluded to, 'a fresh pair of eyes'
In conjunction with the above, potentially more of a need to delve into the 'basics' of the area being audited. A greater willingness to ask what may be perceived as 'stupid questions' (God, I hate that phrase...) may uncover more than the line of questioning taken by someone familiar with the activities being audited (i.e. a more in-depth, informed line of questioning).
At the end of the day, this will depend on a couple of key factors - is the resource available to do this and is it an approach you actually favour? Whichever you opt for, it should be fairly straightforward to convey your feelings to the person who made the suggestion. After all, they didn't state that such a method has to be adopted?
I'm not sure what is meant by 'fresh eyes'. If you have internal auditors who 'don't see' stuff, there's one or two things going on!
They're either not competent - not 'seeing' something because they don't understand or are inexperienced often comes with the idea that auditors should be 'independent or from another department. If they have been lulled into a sense of security in doing their audits, that's also a competency issue. Auditors should be engaged in planning for their audits to minimize this risk!
And/or they are not being objective and impartial!
Whatever it is, it's an audit management task to deal with it.
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
F AS9100 - How many times can the same auditor audit your system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Can An External Auditor Also Write The Same Non-Conformance As An Internal Auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Do I have to have the same auditor for all company divisions General Auditing Discussions 2
J Repeat Visits By Same External Auditor for the Last 10 Years General Auditing Discussions 22
S How long have you had the same ISO 14000 auditor? General Auditing Discussions 1
T CE Marking - Bench mark Device from same manufacturer CE Marking (Conformité Européene) / CB Scheme 2
P Arena simulation, How can my Arena model have exactly the same output each time I run it? Process Maps, Process Mapping and Turtle Diagrams 0
M Are you allowed to reuse the same asset number if the device was replaced? General Measurement Device and Calibration Topics 10
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
K 510K new manufacturer but same components Other US Medical Device Regulations 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
G Same intended use devices - Technical file EU Medical Device Regulations 5
K More than one importer for the same device EU Medical Device Regulations 3
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
L PMA and Non-PMA parts in same finished goods area? Federal Aviation Administration (FAA) Standards and Requirements 1
D CE Marking Requirements MDD & MDR - new product development covered under same scope EU Medical Device Regulations 1
C Failure nets - Same level effects FMEA and Control Plans 0
C Subsidiaries; same/different Quality Policies? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Can a manufacturer (in South of Korea) have multiple Brazil Registration Holder (BRH) for same brend name? Other Medical Device Regulations World-Wide 1
S Multiple Authorized Reps in the EU for the same device? EU Medical Device Regulations 3
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
qualprod Write down same nonconformity in several processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J UDI Requirements - Products that all fall under the same family 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
B AS9100 Multiple Distributor warehousing locations under same Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
GStough Informational SN EN ISO 9001:2015 and SN EN ISO 13485:2016 on Same Certificate? Registrars and Notified Bodies 7
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
MrTetris Informational Risk Register - Same hazardous situation, different severity of harms ISO 14971 - Medical Device Risk Management 7
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
S CE Marking requirements - A Medical device with different config sold under same name EU Medical Device Regulations 0
qualprod ISO 9001 - Cl 6.1 and 9.3 and 10 - Opportunities for Improvement the same? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P Is throughput yield the same as FPY or FTY? Rolled Throughput Yield Manufacturing and Related Processes 3
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
qualprod Transition and recertification at the same time? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Legal requirement for same indications as in Country of Origin Other Medical Device Regulations World-Wide 4
H Numbering for documents with same content but different language ISO 13485:2016 - Medical Device Quality Management Systems 4
D CE Mark with same NB (Notified Body)? CE Marking (Conformité Européene) / CB Scheme 4
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
B PMCF study plan is same to clinical investigation plan? EU Medical Device Regulations 3
