Sample Approval by Customer - Customer doesn't send/return their approval
G
geamami
Hello all,
I've got a little problem to solve for my employer. I'm a Advanced Quality Engineer responsible for implementing ISO/TS 16949. As you know, this is not the easiest job but it's a challenge :)
Here's my question, ISO/TS 16949 is required a sample approval by the customer (See paragraph 7.3.6.2 and 7.3.6.3) In my company we always providing a first sample and send this to the customer for approval but in most of the cases the customer doesn't send this approval. How to handle in and what can we do to tease the customer or do I interpret the ISO/TS on the wrong way?
Thanks for your advice.
Gerard Vervaart
Stijloor
Re: Sample Approval by customer
Hello all,
Gerard Vervaart
Gerard,
ISO/TS states: "When required by the customer, the organization shall have a prototype programme and control plan."
Do you always send prototypes or only when required by the customer?
This issue should actually be discussed and agreed upon during the contract review stage. (see 7.2)
Does this clarify?
Stijloor.
P
Phil Fields
Hello all,
Gerard Vervaart
It has been a while since doing any Automotie submissons (15+ years ago). Without the sample submission approval from your customer, how are is your company authorized to ship production parts?
Phil
antoine.dias
Phil
Are you going to get paid for the shipments ?
You may have difficulties in that direction if your products are not officially released. Although the signature on the file is a completely different thing than the release of the product in the system at the customer's side.
Best regards,
Antoine
G
geamami
Thank you both for your very quick replay on my question. I've read the passage but didn't realize that this was only when required by customer. I've just started in my new job and also at this company (6 weeks). I've got no idea why they always provide customer samples, I think because customers sometimes changing their requirements. The approval they've got now is because of the first order they receive from that particular customer. It sounds a little amateurish and it is :) You see, there’s a lot to do at this company.
Regards,
Gerard
G
geamami
Re: Sample Approval by Customer - Customer doesn't send this approval
Hello Antoin,
Not all of our customer are automotive related customer, to be honest, we only have a few automotive customer but to get a ISO/TS certification you have to formalize and document a sample approval process.
I think I have to go back to paragraph 7.2, create a sort of questionair with all the customer needs enumerate. Of course also the question if they need a first sample.
Regards,
gerard
Randy
Just be honest with them and forgo all the Quality mumbo-jumbo. Tell them that you cannot and will not ship until approval by them is received and if they insist then it's "caveat emptor" and they will need to bear all the costs and burdens associated afterwards.
This isn't so much a Quality thing as it is a contractural thing...you have obligations and so do they.
Hello all,
Gerard Vervaart
The comments thus far indicate that it's not clear what sort of samples you're referring to. You don't mention PPAP, so I'm assuming you're talking about some sort of preproduction samples. Unless you or your customer has an explicit requirement for submission and approval of samples, you don't have to worry about it. On the other hand, if submission and approval is required by the customer, you have two options: you can inform the customer that development will not proceed until approval is granted, or you can invoke implied approval by formally informing the customer that unless samples are approved within some specific reasonable amount of time, approval will be assumed and you will move on. If this is the tack you take, you'll need to document it in your system.
If sample submission and approval is your own company's requirement, just get rid of the requirement.
G
geamami
Hello Jim and Randy,
These were the answers I was looking for, thanks for your great help.
For sure I will contact our legal department to legalise the clause I want to put first on the quotation and otherwise to the samples together with First Sample measuring report.
Whish you all a great and fine Easter.
Gerard
S Is TGA approval required for a ARTG listed IVD for a sample type addition? Other Medical Device Regulations World-Wide 11
A One of APQP Process Steps - OTS (Off Tool Sample) Approval APQP and PPAP 1
J Sample Approval - Cost Consideration APQP and PPAP 3
Howard Atkins Initial sample approval guidelines - PPAP, FAIR, etc. for medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
C Sample qualification to be IEC 60601-1 series tested IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Y DFMEA Sample in Semiconductor FMEA and Control Plans 2
T Cease Production Sample Procedure Manufacturing and Related Processes 1
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
Quality Runner Continuous monitoring of validated process – sample sizes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
I Mixing tank sample points Qualification and Validation (including 21 CFR Part 11) 4
T Sample size calculation Using Minitab Software 3
C What Theory is MIL-STD-105E Sample Size Code Letters Based on? Quality Tools, Improvement and Analysis 3
Stefan Mundt AS9100D Engineering sample purchases - Supplier not approved AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
U Determining population defect rate from sample defect rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 19
T Noob question regarding sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
P Worst case HLD sample for efficacy studies Other US Medical Device Regulations 0
D Estimate Sample Size for very rare event Using Minitab Software 1
M Summative evaluation: how many sample per participant? IEC 62366 - Medical Device Usability Engineering 5
S Determining Sample Size and Method Quality Tools, Improvement and Analysis 11
C Complaint Return Sample Size Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
shimonv Frequency and sample size for lot release of EtO sterilized products EU Medical Device Regulations 2
X Sample SOC2 audit report (or a redacted one) IEC 27001 - Information Security Management Systems (ISMS) 0
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 4
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 4
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
D Adding a Class I to a sample box Canada Medical Device Regulations 5
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
D How to list multi-product sample pack in GUDID 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
