Sample Range for a valid GRR using ANOVA in Minitab
V
vinny
Hello Covers,
I'm in a discussion with one of my customers from an automotive OEM. They require us to conduct GRR using the ANOVA method in Minitab. We're in a debate over the range of samples used for the study relative to the specification. For example, let's say that the characteristic we are studying has a tolerance of 0.0 +/- 3.0 mm. In order to judge the gage and create as many distict catagories as possible, I want to have my GRR samples to at least span the entire range of the spec limit, and preferably go slightly beyond those spec limits. The customer is saying he would never allow samples for the GRR to be out of spec to the part tolerance. I'm saying it doesn't really matter since we are evaluating the measurement system, not my samples relative to the specification. Validating the measurement system does not have a bias toward one end of the spec or another seems important so we should try to at a minimum include samples from both extremes of the spec (so at least one sample of +3.0 mm and at least one sample of -3.0 mm. I'd actually prefer my samples to range from -4.0mm to +4.0 mm).
I'd appreciate any support or gentle correction to my perspective the group can offer.:confused:
Barbara B
Of course you're right: The samples for a Gage R&R should cover the whole range (process and/or tolerance +/- something). Maybe the customer has a knowledge gap here and you can solve the issue by providing some informations.
As Stijloor already mentioned Miner's blog on MSA is very helpful, see section "Part Selection" in this entry: Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R. Additionally Minitab's White Paper on Gage R&R could provide further information, e.g. comments to Xbar chart on p.8.
Or you can try the "common sense approach" with your customer:
The MSA is conducted to verify that the measurement system is able to
  1. distinguish between good and bad parts AND
  2. monitor process performance accurately (enough).
For both goals the measurement system has to provide reliable results within the whole range of possible values. Since a part outside of the tolerance should be detected (reliably) by its value of the measurement system (regardless how likely it is that such an out of spec value occurs), those parts should be used within a Gage R&R. You can't prove that a measurement system works well on the whole range (tolerance+/-some more or process) if you only have parts for a smaller part of the whole range.
But if your customer doesn't want to have parts outside of the tolerance in the Gage R&R (in contrast to MSA4 requirements), just do what he suggests. The customer should get what he wants - he's paying the bill.
To avoid small ndc numbers you can use the Minitab (R16) Assistant menu for MSA ANOVA (Assistant > Measurement System Analysis). The ndc isn't part of the output ;) Or does the customer have specific requirements regarding the Minitab menu (ndc is part of MSA within the quality tools menu) and/or the numbers he wants to see?
The best way to get your customer happy (in case he remains ignorant to MSA requirements) and to evaluate the measurement system according to MSA guidelines would be to select enough parts of the "customer accepts"-range and additional parts of the "customer doesn't accept"-range (e.g. out of tolerance). After taking the readings you run two analyses, one for the "customer accepts"-part to get the numbers for a satisfied customer and one analysis for internal use to evaluate measurement uncertainty properly according to MSA4.
Barbara :bigwave:
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Method Comparison Design Onput Sample Range Requirement Design and Development of Products and Processes 3
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Gage R&R Sample Size - Sample Range for gage R&R - What is the requirement? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
shimonv Frequency and sample size for lot release of EtO sterilized products EU Medical Device Regulations 2
X Sample SOC2 audit report (or a redacted one) IEC 27001 - Information Security Management Systems (ISMS) 0
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 4
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
D Adding a Class I to a sample box Canada Medical Device Regulations 5
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
D How to list multi-product sample pack in GUDID 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
T ISO 27001 sample audit report IEC 27001 - Information Security Management Systems (ISMS) 5
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
A In which EU countries would it be okay to use sample labels for registration? EU Medical Device Regulations 0
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
Watchcat Identification of Test Sample in Test Reports? Design and Development of Products and Processes 22
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R Medical Device Design verification sample prototype Other Medical Device and Orthopedic Related Topics 14
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
M Inputs on definition of very similar processes for multi site audit sample - IAF MD1 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
