Sample Size for Attribute Binary Data
optomist1
A Sea of Statistics
Hi To All Covers,
I seem to be experiencing a brain cramp of sorts.....I have conducted eight separate observational studies of a process that is measured in a binary manner; a go or no-go outcome.
Using minitab, I have constructed a p - bar chart; sample sizes have varied from 35 to 121 pieces or units. The p-bar over the eight separate observational studies is 8%.
Question: What sample size do I need to "ensure" that all subsequent observational studies & sample sizes are correct; will be large enough to detect a defect if one is present.
Regards,
optomist1
Re: Sample Size Attribute Binary Data
Will You be doing SPC? Monitoring the process to see if the defect rate changes
Or will you be inspecting lots to see if they meet some acceptable defect level?
optomist1
A Sea of Statistics
Hi Bev,
Strictly SPC, monitoring the process.....
Regards,
Marty
optomist1
A Sea of Statistics
Hi Bev,
A little more detail, I conducted 11 observational studies, the most recent p-bar is 8%.
Thank you for your assistance.
Regards,
Marty
Steve Prevette
Deming Disciple
Hi To All Covers,
Regards,
optomist1
Going back to the original question - which appears to be - if the average failure rate is 8%, how many do I need to sample to "ensure" that I detect that there is a failure.
If I replace "ensure" with 95% confidence (a standard threshold out there), then my sample size should be 36
That is - =BINOMDIST(0,36,0.08,FALSE) = 0.049
If the failure rate is 8% and I sample 36 units, there is less than 5% chance I will not find a defect. THIS IS ASSUMING a number of things - such as each unit has an identical probability of failure, and all units are independent from each other.
So, when I do the p-chart, I'd suggest making sure each subset is at least 36 in size.
Statistical Steven
Statistician
Hi Bev,
Regards,
Marty
Marty
If you are doing SPC, then the sample size is a function of more than just ensuring that all future observational studies are correct. Since you quote an 8% average, the upper and lower limits can be calculated for any sample size. How much "sensitivity" to you require to a shift from 8%?
Statistical Steven
Statistician
Steve, a sample size of 36 still gives a lower control limit that is less than 0. How do we reconcile that a sample of 36 with no defects is within the common cause variability of a process with 8% defective rate?
Steve Prevette
Deming Disciple
I'm not surprised that the LCL is less than zero, since I only calculated to 95%. One could do the same calculation to ensure that the LCL is greater than zero.
But I will defend 36 as a good choice in this example. I can use the 2 out of 3 less than two standard deviations below average (and 4 of 5 one below, and 7 below) to detect decreasing trends. I assume though, that detection of increasing trends is more important. The 36 gives me a more frequent update, but would avoid the issue of just the change of a single defect moving you from 0% to 8% to 16% if I use a 12 point sample size.
optomist1
A Sea of Statistics
Thank you both for your thoughtful repsonses, yes ensure is 95%, accepting a 5% producers risk.
The process in question, involves the insertion of one object into another...purely a mechanical process. Yet there are FEW key input variables that can be controlled to any degree, the one key input that does influence the outcome is not covered by a specification, not controlled, nor has it been quantified to a reasonable degree.
Each unit is independent as is the probability of a defect (if I correctly understand your assumption). Of course this "36" merely addresses the most recent observational study or the 8% p-bar. For the other seven studies the p -bar ranged from 19% - 10%, and sample sizes from 38 to 122 units. I do not like attribute or pure binary data, too little insight and too few options for analysis.
Regards,
Marty
True categorical data has very little informative value...but if it's all you've got at least a p-chart will tell you if and when you get better or worse.
As for sample size for different defect rates: the smaller the defect rate the larger the sample size will/should be. One approach is to simply use the smaller defect rate to set your sample size. This will be the most 'conservative' approach. The other approach is to calculate the grand average defect rate [sum(#defects)/sum(sample sizes)] and use that defect rate to determine the sample size. (the formula Steve used for the Exact Binomial is (without using EXCEL functions): n =LN(1-Confidence level)/LN(1-p_bar). Where LN is the natural log and the confidence interval is 95% or 99% (expressed as a proportion; .95 or .99)
You might also want to simply plot your 'observational studies' in time series on a p chart (using variable control limits based on the varying sample sizes) to assess if the process was stable through your studies or if it was changing.
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Sample Size Attribute DOE (Design of Experiments) Six Sigma 9
C Attribute Data - What is the required sample size (medical field)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
N Finding Sample Size - Data Type is Attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 2
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
T Sample Size for Design Validation Design and Development of Products and Processes 4
C AS9138 Sample Size Determination AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
R Sample size for clinical validation/investigation EU Medical Device Regulations 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
J Interesting Discussion Sample Size Determination for Medical Device Other Medical Device and Orthopedic Related Topics 19
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
V Firmware Verification Testing & Sample Size Software Quality Assurance 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
P Cleaning and Disinfection Validation Sample Size of 3? Other Medical Device Related Standards 2
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Sample Size Justification for Medical Device Shelf-Life Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Process Qualification Sample size Document Control Systems, Procedures, Forms and Templates 6
G Sample size for IEC 60601-1-11 environmental tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
