Sample size for creating a data base as a reference to a tested variable
I am interested in creating a database of certain properties of a material in order to have a reference for checking products that got rejected by the user.
the intent is to have a range of values for each property in order to place the rejected products properties in that range.
My question is how do i determine a sample size to create a reliable database?
the purpose is to check for material degradation on the rejected products.
the range will be made up from products with new material.
by comparing the rejected materials properties to the range I prepared, I can have an estimate of the degradation that took place.
Thank you!
We would need more information on. The situation to provide useful information: do you know the lot number of the returned material? Do you know the ‘range of material values at time of production or acceptance for shipment? What is the material? What form is it shipped in? How homogenous is the material property within a batch? From piece to piece?
Also if I’m understanding your description you want to take the returned material and ‘categorize’ it’s material property value into some ‘range’ instead of just recording the value? Why? If you know the lot’s original value (average and SD as long as the sample size used is representative of the non-homogeneity of the production batch/lot) and you know the returned value then you can easily calculate teh amount of degradation....
Ronen E
Problem Solver
Moderator
Thank you,
Thanks again.
Are you planning to sample "products with new material" (new out of production?), in order to establish the property's range in new (acceptable) products?
Thank you for the response.
the material is PcU.
I have the LOT number but there is no information on the properties of the new produced PcU.
The LOT number enables me to know from what batch of raw material the product was made from.
post production the material is checked visually and therfore i dont have any information about how homogeneous are the material properties in a batch.
my assumption is that the visually approved products are accepted and now, I assume, the first step is knowing the sample size to take in order to get the missing information.
Thanks you,
Why can’t you test the post production material? That is really the first step. The correct sample size is dependent on many things:
- the homogeneity of the original production/fabrication lot
- the standard deviation of the lot
- the amount of precision you need in your estimate
- the alpha risk (you might think of this as ‘confidence’ which equals 1-alpha and not is not confidence in the layman’s sense)
Generally the first step is to take a series of small samples across the lot to determine the first two items. You appear restricted to only measuring returns which makes understanding the first two things very difficult.
I would start by measuring all returns until I was comfortable with the data - when it looked ‘stable’.
There is another option: Why do you want this data? What are you going to do with this data? Are you trying to correlate one of hte properties with the reason for the return? In other words are you trying to do some kind of root cause analysis?
What do you think establishing a ‘range’ will do for you?
I am trying to characterize and evaluate the wear in order to do a root cause analysis.
since i dont have the original parameters of the post production materials i think establishing the range will help me in determining any degradation of the material and loss of mechanical properties.My idea was to start testing now for homogeneity and standard deviation with the products that will be out of production soon, just like you suggested.
i started to measure returns and to analyse data too.
I was interested to know how can i estimate the number of samples to check from the post production in order to establish those parameters.
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
T Sample Size for Design Validation Design and Development of Products and Processes 4
C AS9138 Sample Size Determination AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
R Sample size for clinical validation/investigation EU Medical Device Regulations 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
J Interesting Discussion Sample Size Determination for Medical Device Other Medical Device and Orthopedic Related Topics 19
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
V Firmware Verification Testing & Sample Size Software Quality Assurance 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
P Cleaning and Disinfection Validation Sample Size of 3? Other Medical Device Related Standards 2
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Sample Size Justification for Medical Device Shelf-Life Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Process Qualification Sample size Document Control Systems, Procedures, Forms and Templates 6
G Sample size for IEC 60601-1-11 environmental tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
C Sample Size for Stability Testing Other Medical Device and Orthopedic Related Topics 2
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
F Power and sample size for factorial design Using Minitab Software 4
S Sample Subgroup Size for NP/P chart - nPbar>=5 Statistical Analysis Tools, Techniques and SPC 4
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
S Low Sample Size for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
