TSwilson
Hi All,
I am currently working on product validation testing for a medical device (US/FDA) and we in the process of trying to figure out how many devices are needed for each test. All of the validation testing we have to do amounts to making sure one or another of our products properties (e.g., shear strength, crush strength, etc.) is greater than our specification or in cases like number of particles released during use, less than our specification.
We have already built enough prototypes, samples, etc. that we have a very good idea of the average and “standard deviation” of these properties for our product (some properties clearly do not fall on a normal distribution). The average for each is typically well above our spec (or for particles, well below). For crush strength, the average is high enough, but the deviation is also quite high, though mostly due to some products having a very high crush strength – this was as expected due to the mechanical design, there are some interferences that can come into play to dramatically improve the crush tolerance. To be concrete, let’s say our spec for crush is >=10, the average failure is 14 and the deviation is 4.2 and our measurement precision is 0.5. (Some units can survive many times our spec, but again, none has ever failed to meet 10 – in fact the lowest shear we have encountered was on a device purposely built way out of spec and it failed at 10.8).
For other properties, such as shear strength, we again have to validate that the device survives up to at least our specified shear strength, but again we don’t care if it’s over, just if it’s under. For properties like the shear strength, our data looks like it could be a normal distribution. To give sample numbers, our shear spec is >=1.0 and our average shear at failure is 1.5 with a standard deviation of 0.25 and a measurement precision of 0.05.
Lastly, for particles shed by our device, we are well under the spec and our data does look vaguely like a normal distribution. Our spec is 100 and we measure an average of 30 with a standard deviation of 10 and a measurement precision of (about) 3.
How would I calculate the required sample size for these situations, all one-sided specs, where one is very likely not a normal distribution, one has an a lower bound but no upper bound, and the other has an upper bound, but no lower bound (down to zero)?
Our previous compliance consultants used a formula very similar to the one Bev D gave in an attachment to the thread entitled “Determining Sample Size for FDA Verification and Validation Activities,” but it’s not clear to me that this formula applies to any of these situations (I am however statistically challenged, so please feel free to set me straight).
Thanks in advance for your help,
-Tom
-Tom
