Sample size for IEC 60601-1-11 environmental tests
guymlech
Dear Friends
similar to my last question - but for a different standard,
I am trying to understand what is the proper sample size for environmental tests when using the IEC 60601-1-11 standard.
where can I find a reference to a sample size for it?
Thank you all
Guy
:thanx:
Peter Selvey
Sample size itself is not generally mentioned in type testing.
The basic requirement (as per the definition in the standard) is that a type test should be representative of production. In theory the number of samples required to be confident about compliance depends on the expected variability of the test result and the margin to the limit. For example a transformer temperature test run to stable temperatures result might be 72C, and the limit is 100C. In this case, a single test is fine. On the other hand if the result is 97C, and the limit 100C, would could not be sure about compliance in regular production.
In safety related type testing the situation is made complicated as many of the requirements in the standard are conservative, and the test itself may be based on multiple worst case assumptions (worst case load, highest ambient, longest time etc). In such a case, a single test may be fine by virtue that potential variability in production has already been taken into account when developing the test method and limits.
For IEC 60601-1-11, the main point is performance. Many performance specifications are also conservative, but usually there will be one or two which are critical and need close attention to making sure a type test is representative. For this we should fall back to basic principles. A home use thermometer for example, usually requires a precision resistors in the measurement circuit. If the manufacturer is cheap and uses 1% 250ppm resistors and other low quality parts, it is possible that the environmental tests pass but the results show up significant changes in measurement accuracy at 0C and 45C. if the result is close to the limit, we cannot be confident about regular production. More samples are required (or better design ...).
On the other hand if the manufacturer uses 0.1% 50ppm resistors and other quality parts, and calculates the error budget and confirms it is well within the limits at the temperature extremes, and tests at 0C and 45C show no detectable change, one sample may be enough.
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
Q Sample Size justification for IEC 60601-1 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Human Factors and Usability Testing in the US - smaller sample size than the required 15 users Human Factors and Ergonomics in Engineering 6
D Risk Based Sample Size and Standards Compliance ISO 14971 - Medical Device Risk Management 2
Z Design verification test sample size under the scope of first in human study submission in Europe Medical Device and FDA Regulations and Standards News 3
B Sample Size vs Number of Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Attribute MSA-AIAG 4th How to calculate sample size IATF 16949 - Automotive Quality Systems Standard 12
A Sample size selection for process validation - continuous data Reliability Analysis - Predictions, Testing and Standards 9
L PQ Sample Size across multiple lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Sample size considerations in medical process qualification Reliability Analysis - Predictions, Testing and Standards 11
H How to calculate sample size and sample frequency Statistical Analysis Tools, Techniques and SPC 2
K Sample size calculation for the medical device with multiple indications. e.g. suture US Food and Drug Administration (FDA) 3
V Sample Size rationale to reduce size and use special levels EU Medical Device Regulations 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
T Sample size calculation Using Minitab Software 3
C What Theory is MIL-STD-105E Sample Size Code Letters Based on? Quality Tools, Improvement and Analysis 3
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 20
T Noob question regarding sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
D Estimate Sample Size for very rare event Using Minitab Software 1
S Determining Sample Size and Method Quality Tools, Improvement and Analysis 12
C Complaint Return Sample Size Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
shimonv Frequency and sample size for lot release of EtO sterilized products EU Medical Device Regulations 2
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 4
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
H Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
T Sample Size for Design Validation Design and Development of Products and Processes 4
C AS9138 Sample Size Determination AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
R Sample size for clinical validation/investigation EU Medical Device Regulations 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
J Interesting Discussion Sample Size Determination for Medical Device Other Medical Device and Orthopedic Related Topics 19
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
