Sample Size for Rejected Units
V
veness
Hi All,
In semiconductor industry, from the lot size of 12000 units, 600 units are rejected units in Test. Now I would like to draw sample from 600 rejected units for X-ray analysis. How many samples i should take for X-ray to conclude the defect mode in these rejected units? (Example: offpad wire bonding).
Pls advice.
Thanks and regards,
veness
Statistical Steven
Statistician
Hi All,
Pls advice.
Thanks and regards,
veness
I am going to suggest three different approaches, with three different sample sizes. You need to assess which scenario fits you best.
Scenario #1
How many unique defect modes are there? If there are less than 10 modes, you can take 5 times the number of modes to estimate the percent of each mode in the defective tests. If the number of modes is higher, then you will need to test a substantial amount to ensure all modes are in the sample.
Scenario #2
You can use the square root of N+1 leading to a sample size of 26 using N=600. This would be used to test if all 26 had a defect. You can also use regular attribute sampling plans for different AQL and LTPD values if the purpose is to confirm the test with X-ray analysis.
Scenario #3
Would require doing X-ray on both the "good" and "bad" project to confirm the inprocess testing and X-ray are consistent. Since you have a 5% defective rate, you can take a sample if 50 "bad" and 50 "good" using a 2x2 contigency table. You will need to use a test like Fisher's Exact since the expected value in some of the cells will be less than 5.
Hope that helps some....
V
veness
Hi Steven,
I seek for your further advice.
Scenario #1:
Question: How do you define "5 times the number of modes"? Any statistical theory behind?
Thanks...
Statistical Steven
Statistician
Hi Steven,
Scenario #1:
Thanks...
Veness
Failure modes are for example shorts, pits, missing components, etc. The idea of 5 times has no real statistical theory, but more a practical experience that shows for common defect modes, this works best to ensure all defects are captured in a sample. If you want a more statistically rigorous method, you can look at the probability of each defect mode and use a weighted sampling strategy.
Steven's approach is very sound:
How many test failure modes are there in the 600? For each of these test failure modes, how many possible defects are there that can create the device level failure you have observed?
for each test failure mode, take 5-10 devices for each of the possible defects
then see what you get.
there really is no precise statistical formula for this. take some data, then if needed you can take more. Also ask yourself - willl a precise knwoledge of the defect type distribtuion change any action you will take to solve the problem? if not then all you need is a gross estimate that the defect occurs and a rough estimate of how frequently it occurs (often or not very often)
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 2
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
T Sample Size for Design Validation Design and Development of Products and Processes 4
C AS9138 Sample Size Determination AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
R Sample size for clinical validation/investigation EU Medical Device Regulations 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
J Interesting Discussion Sample Size Determination for Medical Device Other Medical Device and Orthopedic Related Topics 19
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
V Firmware Verification Testing & Sample Size Software Quality Assurance 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
P Cleaning and Disinfection Validation Sample Size of 3? Other Medical Device Related Standards 2
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Sample Size Justification for Medical Device Shelf-Life Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Process Qualification Sample size Document Control Systems, Procedures, Forms and Templates 6
G Sample size for IEC 60601-1-11 environmental tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
C Sample Size for Stability Testing Other Medical Device and Orthopedic Related Topics 2
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
F Power and sample size for factorial design Using Minitab Software 4
S Sample Subgroup Size for NP/P chart - nPbar>=5 Statistical Analysis Tools, Techniques and SPC 4
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
S Low Sample Size for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
