clatoz
We make primarily Class I, with a few Class II devices. For our stability program, we are required to test 60 samples at each time point for a Pass/Fail test, which gives an upper probability of failure of <5% at the 95% confidence interval. For stability tests which generate numerical results, where we will use regression analysis, we are required to test 17 replicates at each time point. This seems extreme, as from what I've seen in the Pharma industry, typically only 3-5 samples are tested at each time point. Just curious what sample sizes others in the device industry use for their stability testing? Also, if anyone could provide some references for sample size selection for stability testing. I couldn't find anything in the ICH guidelines or ASTM F1980. Thanks in advance.
