Sample Size rationale to reduce size and use special levels
Vetty007
Hello everyone,
I have a question regarding the sample size of an in-process control and the resulting batch release. Since the product is just a folded, dry wipe in a sachet (low risk overall, deviations in the folding or in the size are hardly relevant to safety), that has been in production for more than 15 years - sample size was always 50 pieces - I would like to stay with such a low sample size, but at least be able to justify it accordingly or slightly adapt it.
According to ISO 2895, I would have to take 500 samples for a batch size of 35.500 pieces, if I take the batch size range below (because I only slightly exceed this), I still have to pick 200 samples. If I could use one of the special levels as a basis here, that would be great. Unfortunately, I can hardly find a definition of when and to what extent they can be used. Can anyone give me a hint, where I can finde more details/definitions?
In my case, I am thinking, if its possible to check 200 or 500 pieces, for example, for integrity of the packaging, proper printing etc. and then add these samples back to the batch (assuming they are in spec) and then use just a part of them and with an amount according to the special level, to open the packs and check the content? Until now we took 50 samples, open them and check if the wipe size is correct and folded properly. Checking the integrity of the packaging and printing is included and done before opening, but as this could be easily done and the samples used afterwards (if allowed to do so?) checking 200 would be acceptable.
Even if the value of the larger number of samples is not that high, it is still annoying when it ends up in the garbage afterwards, esp as there are actually hardly any errors here and, above all, no relevant ones. In this respect, it is certainly acceptable to reduce the sample size, the main question is according to which specifications and to what extent.
I would be happy to get some feedback about my thoughts for testing or new ideas, where to look for more information or suggestions or literature recommendations.....
Thanks a lot in advance :)
Mike S.
Happy to be Alive
Your sampling plan should explain when using special levels is appropriate.
Have you considered C=0 sampling plans? Have a look at ASQ H1331 by Nicholas Squeglia.
Vetty007
Thank you for your comment and recommendation. I am not sure, if the ASQ will be accepted by an EU NB, our NB likes to see german standards or ISO andthus I haven't considerd it yet. . Any experience with the acceptance of ASQ by EU NB?
You are right with the comment but its esp. part of my question, how to explain the use of these special levels.
Cybel
I don’t have experience to give you an answer, but I would like to share some thoughts.
As stated in ISO 2859, special levels "may be used where relatively small sample sizes are necessary and larger sampling risks can be tolerated".
I guess the value of “necessary” may be not objective enough (for example: at what point, exactly, the inspection cost becomes too high compared with the risk and final cost of the device?), so I would start evaluating the risk of a larger sampling in my risk analysis, bearing in mind that inspection is, for sure, a protective measure in the manufacturing process but not the only risk reduction measure. Maybe you can increase control over the processes such as printing, cutting, folding or others, for example:
- what is the risk if the wipe size is incorrect?
- can you increase production methods to ensure appropriate wipe size?
- can you validate this process?
(My subsequent and collateral question: if process validation must be performed in case the results of that process cannot be fully verified by subsequent inspection and test, could process validation also be performed in case I don’t want to verify the results of that process, for a number of reason, so that I can avoid sample in process and final controls?)
Zero_yield
"You can observe a lot by just watching."
Seconding Cybel here. This sounds like a job for validation.
Do you already have other in-process controls, like an ERP system, to ensure that the correct materials end up in the correct batches?
Questions to ask yourself:
1. How frequently are is this control finding deviations that:
...could affect patient safety?
...could have regulatory impact?
...could cause an unhappy customer or impact the business?
2. How often do we have a complaint that this control should have caught?
From there, you should be able to do some risk analysis about what you're getting out of the current control.
Mike S.
Happy to be Alive
Then maybe consider ISO 28593: 2017 .
You said the risks were low.
Is your process in control?
Seems like you should be able to do a risk analysis and come up with options.
Vetty007
Thank you for all the valuable comments and suggestions :)
We already controll several parameter during and after production for the (partly) finished product, thus I was thinking to splitt the required 200 test samples, using 50 for a destroying testing (the value in term of cost is very low and not a good reason for a low sample size) and the other ones for the other tests and also "re-use" e.g. the final packages on which we check the correct printing, sealing and packaging of the correct amount of wipes sachets and as this is only a visuable testing, it should be possible to add them to the batch (provided they are in spec) afterwards. We have done a process verification and validation and reached good results (Cpk minimum 2) and of course we have a ERP and make sure to only use the correct material. Thus in general the risk is very low, and mostly without potential influence on patient safety, customer satisfaction or even regulatory aspects. The only risk is a microbial contamination, but the material is checked, the sachet has an antimicrobial coating and the machines were disinfected and checked for contamination before use too - picking 50 sachets at the end of the production line should be enought to check the finished product for contamination. I think I wouldn't finde more positive samples if I collect more - if there is a problem with contamination the 50 samples should be enought to find this problem, if not, more samples will not be helpful .....
Until now we didn't had a relevant complaint, it was just peanuts like, that e.g. the LOT printing wasn't placed correctly, or an arrow to show where the sachet should be opend was missing- All of this is now taken into account in our controlls and it was easy to correct these things.
Okay, then I will buy this ISO 28593: 2017 - compared of one the other ISO with over 200 EUR its cheap, but hopefully includes helpful content.
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
A Whats the rationale for a Sample size of 30 for Capability Analysis? Statistical Analysis Tools, Techniques and SPC 5
K Sample size calculation for the medical device with multiple indications. e.g. suture US Food and Drug Administration (FDA) 3
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
T Sample size calculation Using Minitab Software 3
C What Theory is MIL-STD-105E Sample Size Code Letters Based on? Quality Tools, Improvement and Analysis 3
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 20
T Noob question regarding sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
D Estimate Sample Size for very rare event Using Minitab Software 1
S Determining Sample Size and Method Quality Tools, Improvement and Analysis 12
C Complaint Return Sample Size Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
shimonv Frequency and sample size for lot release of EtO sterilized products EU Medical Device Regulations 2
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 4
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
F Bayes Success run Theorem for sample size during OQ&PQ Qualification and Validation (including 21 CFR Part 11) 4
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
T Sample Size for Design Validation Design and Development of Products and Processes 4
C AS9138 Sample Size Determination AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
R Sample size for clinical validation/investigation EU Medical Device Regulations 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
J Interesting Discussion Sample Size Determination for Medical Device Other Medical Device and Orthopedic Related Topics 19
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
V Firmware Verification Testing & Sample Size Software Quality Assurance 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
P Cleaning and Disinfection Validation Sample Size of 3? Other Medical Device Related Standards 2
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Sample Size Justification for Medical Device Shelf-Life Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
