Samples for GR&R - Can we get the 10 samples from multiple models
sinned
Registered Visitor
In GR&R study, we normally get 10 samples of the same model of part. Can we get the 10 samples from multiple models (in same product family) of parts with the same measurement system ? For example, my product family includes a bar shape part of different width. Say, model A, model B, model C, model D. Can i take 3 parts from model A, 3 from model B, 2 from model C, and 2 from model D together as the 10 samples for my GR&R study ?
b.rgds - dennis
Welshwizard
The selection of parts affects any characterisation of the relationship of the part variation to the measurement variation therefore you will need a faithfull representation of the part variation if this relationship is important for your needs.
Selecting parts from different families for use in a study such as this is fine if you are happy that the characteristics being measured are the same, including the geometry and size and that the manufacturing processes are the same. If the other part families are made on the same machines with the same process then the estimate of part variation will be faithfull for that process including whether they were made on different days and subjected to different environmental conditions.
You hint at using parts of different widths, again, is it reasonable to assume that the part and measurement variation should not change due to this change in width? If yes then you wont be reasonably estimating part variation and your measurement error estimate will reflect parts from different processes.
Hope this helps
John Predmore
The GR&R compares the variation between appraisers to the variation among the parts. If you mix apples and oranges, your GR&R will quantify people's ability to distinguish apples from oranges, which may not be what you are after. If you plan to use your gauge to distinguish good apples from bad apples, all your samples should be in the range of good-to-bad apples. If you want to differentiate between good apples and better apples and not-as-good apples, it would be best to use this as your range of sample parts.
sinned
Registered Visitor
Yes. The family of parts are all made from the same production line under same process, eg. grinding. The only difference could be the grinding wheel size and the adjustment of the cutting depth. The main purpose of doing in this way is to try to cover more than one model in the study and the GR&R is assessed in term of %GRR instead of %P/T.
Actually I think this is similar to using gauge blocks of different length to do GR&R study. Some people do mentioned this method as I read from book / the web. Is it really not recommended ?
You can do anything you want, but “just because you can doesn’t mean you should”.
I’d start by understanding what you are trying to understand about your measurement system. Remember that the goal of any study is not ‘pass’ but to gain insight and understanding that allows you to make quality parts. The study you propose won’t really inform you of much at all.
P Retention Samples for medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
Z Labeling for Medical Device Samples - Surgical instruments 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Retained samples from each batch of spinal implant medical screws that we make ISO 13485:2016 - Medical Device Quality Management Systems 7
WEAVER Retention of golden samples for GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
K How Many Samples to send for Chemistry Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
A Generating samples from a population in Minitab Using Minitab Software 0
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
K UDI Labeling for Medical Device Samples 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Guidance Required for Examining 168 Hour Salt Spray Test Samples Manufacturing and Related Processes 5
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
E Requirements for sending Medical Device Samples to Indonesia Other Medical Device Regulations World-Wide 5
Z Labeling Requirements for Free Samples supporting Clinical Evaluation EU Medical Device Regulations 2
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R Customer Complaint - Samples vs. Removal - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
GURU SDI Cleanliness Requirements for Initial Samples Customer Complaints 4
WEAVER Gage R&R Sample Selection - Can we include NG Samples? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
knightarmourus Keeping the test samples in after market nlight alloy wheel production Manufacturing and Related Processes 2
knightarmourus Initial Samples with dimensional deviation in Serial Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Is Process Validated samples required for IND submission ? US Food and Drug Administration (FDA) 2
M Traceability of Tissue Samples US Food and Drug Administration (FDA) 1
H Is design verification and validation required for samples accompanying the quotes ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M How to compare 2 independent samples having 3 factors 3 levels Statistical Analysis Tools, Techniques and SPC 5
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
D Samples & Inspection Check Sheet Templates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Superiority of Drawing vs First Samples Customer Complaints 9
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
S Do I need to initiate a Customer Complaint for Engineering Samples? Customer Complaints 4
V EMEA/UK cGMPs Requirements for Pre-Shipment Samples, Input Materials US Food and Drug Administration (FDA) 0
P Is the European directive, 2011/65/EU applicable for Engineering Samples? RoHS, REACH, ELV, IMDS and Restricted Substances 5
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J External Laboratory in ISO/TS 16949 - Maintenance oil samples IATF 16949 - Automotive Quality Systems Standard 3
S Should PPAP Samples Come from a Production Run? APQP and PPAP 3
B Hypothesis Tests with nonparametric dependent population samples Using Minitab Software 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Is Metals Analysis of Water Samples considered "sampling"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
V Process OQ for Medical Devices - Are Samples Required to be conditioned? Manufacturing and Related Processes 2
0 Sample divider for PET flake bulk samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
K Machine Press Tooling Operation Inspection Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
T Test of difference for mean for 2 samples Statistical Analysis Tools, Techniques and SPC 13
L I have four groups to compare, and each group has three samples Using Minitab Software 4
S Samples to be tested for Salmonella in United Kingdom Food Safety - ISO 22000, HACCP (21 CFR 120) 3
