Sampling - Clause 8.2.4 - What do the words "known non conformities" mean here?
Sohail
1. Refer to clause 8.2.4 "The plan shall preclude the acceptance of lots whose samples have known non conformities"
Now this statement is very confusing to me. Does it mean that NO REJECTIONS ARE ALLOWED IN THE CHOSEN SAMPLES? i.e AQL is not acceptable in sampling inspection of AS9100 REV B QMS? That means if take statsitically valid sample of rivets (say 20 out of 1000) and if even one rivet is rejected then the lot must be rejected or the lot must be 100 percent insepected?
What actually word "known non conformities" mean here? Does it mean that the lots whose previous history shows that there are usually non conforming parts in this type of lot, or does it mean that after inspection some non conformities are found in the sample chosen.
Is sampling standard 105 E obsolete?
I hope i have explain my question well.
Thanks:confused:
2
antoine.dias
Re: Sampling - Clause 8.2.4
It means exactly that. No non conformities are allowed in the sampling.
It also means that the AQL can only be used to have a good basis for number of samples to be taken from a certain lot. AQL cannot be used for release criteria of the lot.
There is something similar in the ISO TS 16949 ( when sampling is used for attribute testing the acceptance criteria must be 0 defects )
Best regards,
Antoine
Mike S.
Happy to be Alive
2
Yep, the sample must have no nonconformities -- also known as a "C=0" sampling plan.
You can use an AQL chart -- like MIL-STD-105/ANSI Z1.4, etc. and set the number of allowed defects to zero as one way to get a decent C=0 sampling plan. Also check out a book by Nicholas Squeglia called "Zero Acceptance Number Sampling Plans" for another route to take.
BadgerMan
You have made the correct interpretation. :agree1:
Your acceptance number will be zero defects (C=0) and your reject quantity will be one defect or defective item.
clara
2
Dear all,
I am a new member, I am working for a company providing aircraft equiment in Asia. We are auditing against the AS9100 standard.
Concerning this requirement, I would like to know if it has to be applied to the incoming inspection acitivity ?
Thanks very much for your advices.
Clara
Dear all,
Clara
the short answer is yes.
however, remember that rejected lots are subject to preliminary review and disposition. you could screen the incoming lot, have your vendor screen it, rework it, or submit a request to repair it or "use as is"...
clara
Dear BadgerMan and Bev D,
Thanks very much for your reply .
It's clear now and I have apply the Zero Acceptance Number Sampling Plan developped by Nicolas L. Squeglia for our incoming inspection .
Very pleased to have chance to work with you.
Have a nice day.
Clara
clara
Dear everybody,
I would like to know , in incoming inspection, can we apply the exemption mode when the preceding 10 lots are accepted ?
Thanks for your advices.
Clara
Dear everybody,
Clara
if the standard quoted by tthe original poster applies to your organization - or if a similar requirement is placed on you by any other standard or Customer - then the answer is NO. acceptance sampling *in general* applies to the lot in front of you. (the past cannot predict the future - the process may have changed since the last 10 lots and you must deal with what you have now.)
If you are under no written/explicit requirement to have a zero acceptance sampling plan you can do whatever you want. However, my advice woudl be to use zero acceptance sampling plans as most Customers these days are intolerant of any shipped non-conformities. and the best approach as always is to not use a single source of data for your decisions. SPC, continual improvement, Problem solving methods, etc. should be working as a system to improve your quality. Focus on improving the process and not whether or not you should accept a lot if it you find one or more defects in the sample
Q Sampling Plan Acceptance Criteria - ISO TS 16949 Clause 7.1.2 IATF 16949 - Automotive Quality Systems Standard 8
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R AS9003 Clause 4.20.2 - Customer-approved acceptance sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
R Reduced sampling plan for sterial products APQP and PPAP 0
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
8 Activity Sampling Exercise Lean in Manufacturing and Service Industries 11
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
A ISO 2859 Single Sampling - Clarification regarding the sampling table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R DCMA Sampling of CSI Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
T ISO 13485: 2016 Internal Audit - Is sampling on projects allowed? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Sampling for stability studies - Class II surgically invasive devices Other Medical Device and Orthopedic Related Topics 1
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
