Sampling for capability studies for variables and attributes
enorht
Context: It is very difficult to explain the necessity of validation to our supply so we do not have a solid OQ (meaning no identification of critical parameters such as speed, ...). I just have a machine capability performed on a complex and aluminum product using all the axes (8 or 9) of one equipment. As all the equipment are of the same brand, we decided to accept this "OQ".
I am currently performing a performance qualification of CNC equipments. They are used for the manufacturing of orthopaedic implants (screws, rods, nuts, ...). We have decided to manufacture for each kind of product (based on their physical dimensions) at least three batches representative of the routine. We already identified for each of them critical dimensions and critical aspect. Most of them are measured but few of them are controlled by a GO/NO test or visual aspect.
we agreed with the supplier for the three first batches of each product reference to control and record:
- 100 measures for each dimension per batch --> my aim was to have enough data to perform a capability study and calculate the lower bound of capability index with a confidence level of 95%. I saw that 100 measures are a good sampling to have relevant confidence in the capability indexes (and i will have 300 measures if there are no variation inter lot). But i did not find relevant sources.
- 100% of control GO/NO GO and 100% for the visual aspect. honestly, the production was launched without ending the protocol writting so we decided to have the maximum of values. but I do not know if I have to write a rationale with an approach of LTPD/AQL for critical defauts or do i need to also perform a capability study (with minitab). How can i justify this sampling in my protocol?
The aim is to validate the manufacturing process by showing that:
- for the dimensions measured, the process is stable and have a pp/ppk lower bound at 95% of confidence > 1.33. After that, should I calculate the Z score, calculate the %ppm and link to the AQL/LTPD too?
- for the characteristics controlled by visual inspection or GO/NO GO controls, i do not know if i i have to use capability studies too or claim a NQA/LTPD %...
Thanks for your help,
bobdoering
Stop X-bar/R Madness!!
This is only true if you have identified the correct distribution. Machining variation should NOT be normal, so standard Ppk calculations would not apply. As much data as you have, if you measure your diameters and capture the highest value and lowest value on the diameter slice, you pick up your with-part variation (often ignored to analytical peril). Then following that data over a time-ordered sequence should see the values gradually increase until the part reaches an upper limit where it needs to be offset. It should be offset to a lower limit, then allow the tool to continue to wear. This sawtooth is the continuous uniform distribution - and should be evident in your process. If so, set you control limits to 75% of your tolerance and you have a 1.33 capability. Other dimensions, such as concentricity, parallelism, etc. that are unilateral need curve fitting to determine capability. Using either Cpl or Cpu alone is crap statistics because the process behavior is not modeled best by "1/2 a normal distribution". Curve fitting is more correct. 125 samples is considered a good number.
As far as go/no go - you can also do capability but not to Ppk. It is pretty much % good. You might want to do Gage R&R first, using the attribute agreement method to see how well your operators can find the defects. It ends up being far more interesting.
enorht
Thank for your reply. I am not sure to understand everything about you said. I plan to measure diameter, length of thread, tap. Do you have a link to illustrate the sawtooth that you describe.
I was planning to use the lower bound of the capability index estimate in order to state something like "I am confident at 95% that my process capability is at least 95%". Is it not correct? What do you mean by curve fitting?
For GO/NO GO, we cannot perform GR&R because we do not have the ressources (only one controller) and I cannot convince my supplier. So the best for GO/NO GO would be to calcule a %good with the capability analysis of Minitab?
I am not english native speaker so i am sorry to ask you to explain me more clearly. I did not understand everything, do not hesitate to give me some illustrated links.
Thanks,
Z Reduced Sampling based on Process Capability (AS9100 Standard) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
R Reduced sampling plan for sterial products APQP and PPAP 0
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
8 Activity Sampling Exercise Lean in Manufacturing and Service Industries 11
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
A ISO 2859 Single Sampling - Clarification regarding the sampling table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R DCMA Sampling of CSI Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
T ISO 13485: 2016 Internal Audit - Is sampling on projects allowed? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Sampling for stability studies - Class II surgically invasive devices Other Medical Device and Orthopedic Related Topics 1
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
C Sampling of Class IIb Implantables under EU MDR - Assessments to the EU MDR EU Medical Device Regulations 4
