Sampling Method for Stability Study - Implementing MSA Study on Testers
  • Thread starter Jacquiline.Fjeldstad
  • Start date
our company is starting to implement msa study on testers. but for economy reasons, we plan to implement it on sampling basis only. we'll pick a number of testers only to represent the performance of the tester population as a whole. is it ok to proceed with this procedure? if yes, can you share with me some sampling plan or formulas that we can use?
thanks.
depends.
Are the testers replicates of each other?
Are these testers used for testing your product or are they your product?
what do the testers test for?
What do you hope to gain by performign an MSA on a tester??
Hi Bev D,
Thanks. My answers to your questions are written below.
Are the testers replicates of each other? Yes they are.
Are these testers used for testing your product or are they your product? Yes they are our product. Automotive products.
what do the testers test for? They test for electrical functionality of the devices.
What do you hope to gain by performing an MSA on a tester??
1. conformance to TS16949 requirements
2. several advantages of performing msa like: a. obtain criterion to accept new test equipments, b. obtain basis for evaluation a tester accepted of being deficient, etc..
L
Lena66
I think you`d better test it when your product have some changes or your instrument have changes.
What do you mean by electrical functionality? Does this mean that they provide a Pass/Fail test result or actual numerical test results? If the latter, can you test against a standard reference value?
Hi Miner,
Our testers provide Pass/Fail results, and at the same time, they can also provide the actual numerical test results.
Going back to my first question, is it ok if we do sampling on the stability study? If yes, can you share with me some sampling plan design to use?
Thanks!
brahmaiah
Hi Miner,
Thanks!
In your first letter you had said that you are conducting MSA study on your testers.In the proposed MSA study is your tester one of the products or is it a testing equipment tp carry out MSA study?
V.J.Brahmaiah
Stijloor
V.J.Brahmaiah
Post #3 in this thread provides the answer to your question.
Stijloor.
Caster
An Early Cover
Hi, our company is starting to implement msa study on testers. but for economy reasons, we plan to implement it on sampling basis only. we'll pick a number of testers only to represent the performance of the tester population as a whole. is it ok to proceed with this procedure? if yes, can you share with me some sampling plan or formulas that we can use? thanks.
This seems to be a case of family MSA studies. Customers often want "every gage that measures my part" to be subject to an MSA study.
However, TS registrars often accept the family gage argument where one study represents all such gages. For example one study for all 6" calipers of one brand.
Do you have tens, hundreds, or thousands? You have nothing to lose with your idea, pick as many as you can handle/afford and see what you learn. If they are all great you have some support for your sampling approach. If the study shows problems, you have work to do to improve all gages.
Good luck.
Hi Miner,
Thanks!
In your situation, I would consider any MSA study to be more of a design qualification study. Perform an MSA on a small quantity of testers to initially qualify the design. After that, you should follow standard manufacturing controls to ensure that you repeatably build the testers to design requirements.
You then have the option to periodically repeat the MSA at some extended frequency (if desired) or when you change the design. I do not recommend performing MSA as a sampling inspection.
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
C Work Sampling Method for Induction Melting Process Improvement Six Sigma 3
A AQL Tables or Binomial/Poisson Method? Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
M Sampling Method for 25 pieces a week of a cable with connectors Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Sampling Method for CNC Machined Products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
S Statistically valid method for multiple raw material sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Sampling method for u control chart - Medical Records Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Sampling plan/method that accepts on ZERO defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Ppk Sampling Method - Does data for Ppk have to been continuous? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
R Reduced sampling plan for sterial products APQP and PPAP 0
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
8 Activity Sampling Exercise Lean in Manufacturing and Service Industries 11
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
A ISO 2859 Single Sampling - Clarification regarding the sampling table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R DCMA Sampling of CSI Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
