Sampling Plan and Procedure wanted - Chemical Trading Company
raghu_1968
#11
OK. Thank you. Now in the case of square root(N) +1 which equals the number of containers to sample, what method do I use to determine how many samples from each container?
The container which i mean is "a drum". The statement which is provided previously has to be read as:
1. If the number of drums from the lot/batch is less than 5, then all the drums have to be sampled.
2. If the number of drums from the lot/batch are more than 5, then Square root(N) + 1 has to be followed.
chimie
#12
Yes, I understood that part, but I wanted to know how to determine how many samples from each drum? Thank you.
v9991
#13
quantity of sample from each drum should be determined by :-
amount required to perform the single identification test +
total sample required for complete-analysis
above logic sounds well with fewer no. of containers;
where there are more no. of containers, we simply draw representative samples from each drum, collect samples for individual-representative samples and pool/blend(bag) rest of quantity for pooled analysis; (replace the remaining quantity into a identified containers)
however, i would like to reiterate the point that...square root(n) + 1 is old practice...you might be forced to upgrade through some audit observation...
(the point is, through square root procedure, you are not inspecting individual container...hence not ensuring the quality of material....)
chimie
#15
Got one more question, please. Can we do a complete analysis testing on at least 3 different lots of material that come in and then reduce the testing to just critical tests after having confidence that we have a reliable supplier? Thanks!
v9991
#16
it depends on regulations pertaining to respective geographies/countries. where you operete and also where you supply...
for US ...YES,
in India, ...NO
for EU...not sure...
but I am not really sure if 3 batches are adequate...
whatever be the number...it ought to be supported by
1) suitable systematic assessment (viz., audits, trend of OOS / complaints at partners end...
2) criticality of materials to your product performance
3) !!! etc !!! need to back it up with your own procedures & its assessment of effectiveness of such reduced testing program.
4) you will also need to account for technical/logistic feasibility of particular analytical technique!!! (though this would not provide any marks in the quality/technical reviews...)
if you look at it,,, each one of points above needs to have specific-assessment criteria outlined in your procedures, and then have suitable review mechanisms built into your system to take care of roll-back as and when required...
hope this helps.
raghu_1968
#17
Can you elaborate this little bit. Interested to know about the alternate to square root(n) + 1.
v9991
#18
1) alternate is already mentioned in my earlier post...sample each container and run physical observation & identification/critical test on that...+ pool the sample and perform complete analysis on same. (
particular to raw materials... the uniformity/homogeneity have impact on output/quality of product...hence, its our responsibility to ensure that identity, purity of materials...leads to above recommended approach)
2) another alternative is discussed which is similar to that of next one.. here in WHO document...
ref. pg 18 of http://apps.who.int/prequal/info_general/documents/TRS929/WHO_TRS_929-Annex4.pdf
3) another alternative usually followed in packaging materials is the sampling plans providing stringent/tighetened-normal-reduced criteria (derived from mil standard of acceptance sampling) ...again depending upon the level of confidence required for specific material - process and partner's performance etc.,
just in case if you have not already seen this...
ref. tables secion V...MIL-STD-105D...http://www.woodencrates.org/standards/MIL-STD-105.pdf
hope this helps...
A Level 2 Sampling Plan SOP (Standard Operating Procedure) Request Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
L Sampling Plan Risks AQL - Acceptable Quality Level 6
R Reduced sampling plan for sterial products APQP and PPAP 0
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
J Sampling Plan Questions from the CQE Practice Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Sampling Plan for for Chemical Analysis Testing of Medical Devices EU Medical Device Regulations 3
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
N Use of arrows in ISO 2859-1 Table 1 and 2-A sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S AS9100 Sampling Plan Requirements - 8.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Military Sampling Plan 105E vs. ISO 2859-1 AQL - Acceptable Quality Level 2
kedarg6500 Acceptance Sampling Plan for Variables - Product Performance Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Where could I get reference to an OQA Sampling Plan of 1 per 1000 ? Quality Manager and Management Related Issues 4
R What to Report when Using C=0 Sampling Plan Supplier Quality Assurance and other Supplier Issues 15
R Results: Monte Carlo Simulation of Acceptance Sampling Plan AQL - Acceptable Quality Level 3
G Sampling Plan according to SAE ARP9013 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan for a Performance Qualification of an Inflation System Qualification and Validation (including 21 CFR Part 11) 2
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
Q Sampling Plan for Paper and Tape Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B In-Process Sampling Plan for a Secondary Package Adjustment Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E How to determine the Lot Size for the OQ Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
G Sampling Plan - Sample Size Justification for a Bottling Cleaning Process Validation Qualification and Validation (including 21 CFR Part 11) 2
I Alpha and Beta in the Sampling Plan for ISO 2859 & ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
