Sampling Plan - AQL effect on Sample Size
BigEd09
Hello, I am trying to understand why someone would reference an AQL level with the ANSI Z1.4-2003 sampling plans as this has no bearing on the sample size. The requirement on the drawing is as follows:
"INSPECTION REQUIREMENTS: ALL NOTES AND CIRCLED DIMENSIONS TO
BE INSPECTED USING SAMPLING PLAN - ANSI/ASQ Z1.4-2003, LEVEL II,​
AQL = 2.5 AND C = 0 UNLESS OTHERWISE NOTED"
Am I correct in my "assumption" that if the AQL were 4.0, that the sample size would not change in the above requirement?
I also have a C=0 sampling plan that is not from the ANSI standard and the lot size is determined by the size of the lot and the AQL. Unfortunately the sheet does not reference its origin.
Thanks to all that reply.
Ed
Tim Folkerts
This seems to be a self-contradictory requirement.
If you use the Z1.4 tables, then the acceptance number ("AC" in Z1.4 or "C" in other contexts) is determined by the table. It cannot be arbitrarily set to zero. So either you use C=0 or you use the numbers from Z1.4
On the positive side, for small lots (up to 50 items), the Level II, Normal inspection with AQL happens to be AC = 0. So for up to 50 items in the lot you would be fine.
The tables tell you:
  • up to 50 items: inspect 5, accept with no defects found
  • 51-150 items: inspect 20, accept 1 defect
  • 151-280 items: inspect 32, accept 2 defects.
If you inspect 150 items and use AC=0, then you re actually going to AQL = 0.65, rather than 2.5.
Something in the requirement needs to be changed - in my humble opinion.
Also, going to AQL = 4 would indeed change the sample size, at least for small lots. Up to 25 items you would inspect 3 items (AC=0). 26- 90 items you would inspect 13 items (AC=1).
Tim
BigEd09
Tim,
Thank you for your feedback. If I could give you an example to make sure I am clear.
Based on the ANSI standard for a lot of 1300 pcs - Inspection level 2, the sample size would be 125 pcs.
If I follow the c=0, AQL 2.5 part of the requirement, using the C=0 plan that I have, the sample size would be 23.
Major difference for inspection requirement. I need to plead my case with our customer and I just want to be as clear as possible. Thank you fro takign the time to reply.
Have a great afternoon.
//Ed
Tim Folkerts
Tim,
That sounds right.
If your are going to have C=0 for AQL = 2.5, then i see a sample size of 5 from the tables.
I think you can keep any two of the qualifiers "Level II", "AQL=2.5" and "C=0". Once you choose two of these, then the other one will be set. As I read the tables for a lot of 1300:
  • "Level II", "AQL=2.5" --> C=7 (and a sample of 125)
  • "Level II", "C=0" --> AQL = 0.1 (and a sample size of 125)
  • "AQL=2.5" and "C=0" --> Level S-1 (and a sample size of 5)
Tim
aproddutoor
What is the sampling plan used to collect data?
What is the sampling plan used for Inspection?
Can they be the same?
L
Lyregi - 2010
I also have another question on AQL which I hope you folks will not mind me posting in this thread.
Supposedly:
Lot Size: 12,000 units
AQL: 0.65 at General Inspection Level II
Sample size stated: 315
Accept/Reject stated: 5/6
My company practises as follows:
Samples inspected: 800 units
Accept/Reject: 5/6 for minor defects, 3/4 for major defects
What happens if 2 units inspected fall under minor defects and 1 unit inspected fall under major defects? Should I reject the entire lot for such incident?
:cool:
reynald
:cool:
When I was still on the outgoing inspection function, our judgement was that the batch would pass. That is, we do not add the count of nonconformities for the major and the minor. Judgment is done indepently per category.
This set-up was communicated and agreed with both internal and external customers though.
L
Lyregi - 2010
Thanks, pardon me if my interpretation of your judgement is wrong. Am I right to say:
If lot consists of 2 minor defects and 3 major defects, I will still accept this lot?:thanks:
acceptancenewbie
A newbie here and dealing with an identical question as well. I think you would pass the lot as the major defects were less than or equal to the Ac value for major defects and the same holds true for minor defects as well.
David-D
Unless you have something explicitly specified otherwise, the number of nonconformances allowed for the AQL sample are for each characteistic. So if you have two major characteristics (ex. length and width)and one minor characteristic (ex. hole diameter) then are you are limited by the number of defects individually for each characteristic. Therefore, if you had 3 nonconforming lengths and 3 nonconforming widths, the lot would be acceptable while of you had 5 length onconformances and 0 widths (although having less total nonconformances) would be rejected.
David
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F AQL - ISO 3951-4:2011 Sampling Plan Requirements AQL - Acceptable Quality Level 2
P Why sample size for c=0 sampling plan reduces across the increases of AQL AQL - Acceptable Quality Level 2
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
0 AQL Sampling Plan based upon ISO 2859 AQL - Acceptable Quality Level 1
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
P AQL and Sampling Plan as they relate to Functional In-Process Inspections AQL - Acceptable Quality Level 4
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
W AQL and RQL Calculation for Variables Sampling Plan AQL - Acceptable Quality Level 8
L Sampling Plan Risks AQL - Acceptable Quality Level 6
R Reduced sampling plan for sterial products APQP and PPAP 0
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Sampling Plan Questions from the CQE Practice Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Sampling Plan for for Chemical Analysis Testing of Medical Devices EU Medical Device Regulations 3
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
N Use of arrows in ISO 2859-1 Table 1 and 2-A sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S AS9100 Sampling Plan Requirements - 8.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Military Sampling Plan 105E vs. ISO 2859-1 AQL - Acceptable Quality Level 2
kedarg6500 Acceptance Sampling Plan for Variables - Product Performance Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Where could I get reference to an OQA Sampling Plan of 1 per 1000 ? Quality Manager and Management Related Issues 4
R What to Report when Using C=0 Sampling Plan Supplier Quality Assurance and other Supplier Issues 15
R Results: Monte Carlo Simulation of Acceptance Sampling Plan AQL - Acceptable Quality Level 3
G Sampling Plan according to SAE ARP9013 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
G Sampling Plan for a Performance Qualification of an Inflation System Qualification and Validation (including 21 CFR Part 11) 2
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
Q Sampling Plan for Paper and Tape Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
