background :-
in pharmaceutical drug products, most of the testing involves destructive testing,
some tests have quantitative results;
using single-units to report single values.
others using multiple units to report single value.
further
some tests have qualitative(attribute) results, mostly as pass/fail with only one criteria.
again some tests use single units and others use multiple units
Question :-
A) when a sample size is determined, lets say n=100, (with c=0)
request clarifications on interpretation of data.
references :-
reference on US FDA citing for a statistical basis for qualitative tests1
another reference...
there are similar expectations are outlined for the quantitative tests as well.
further
Question :-
- does it mean that each test characteristic to be analysed on 100 samples. (i.e., if there are 10 tests, then sample size =1000)
- can 100 be distributed among 10 tests with respective way (viz., one test might require 1 sample, another 20, another 10 etc)
references :-
"Furthermore, revise your sampling plans to ensure they are statistically appropriate and non-uniform contamination can be detected. The revisions should encompass finished API testing, in-process testing, and raw material acceptance testing."
For example, your firm's finished product sampling plan for (b)(4) and (b)(4) in Propofol Injectable Emulsion is not representative of the batch produced. A total of thirteen units are sampled per lot, with three tested for bacterial endotoxin and ten tested for bioburden. This sampling of thirteen units is irrespective of lot size, which may vary from (b)(4) to (b)(4) units (vials) per lot.
Your response, dated August 10, 2009, is inadequate. You do not reference a sampling plan that utilizes basic elements of statistical analysis or provide a scientific rationale for sampling that would vary the amount of samples taken according to the lot size. Your response does not define a confidence limit to ensure an accurate and representative sampling of the product.
