Sampling plan to detect defective units - Given N=6000, PPM=500
K
keatwoon
Can anyone help to answer the following question:
Given N=6000, PPM=500;
How many sample size do I need, to be 95%confidence, to detect and prevent the use of the unacceptable materials in the given lot size? Thanks.
given that this isn't a homework question:
I would use the Poisson and the sample size to determine if the lot is not 500ppm or worse is 5992. sorry. such small defect rates require large sample sizes when you are using only pass/fail criteria. If you were to be measuring for continuous data characteristics, the sample size could be MUCH smaller.
the formula for the Poisson reduces to the following when we accept on 0, reject on 1: -ln(1-confidence)/p if 500 ppm p = .0005
so -LN(1-.95)/.0005 = 5992
Tim Folkerts
Yes, when the sample size gets close to the lot size, then the hypergeometric distribution is a better at getting the correct probabilities. Unfortunately, the equation is somewhat complicated and involves factorials. Excel does have this functionbuilt in, but factorials for large numbers become huge! Sample sizes much over 100 return an error.
Details about the eqaution can be found at
http://mathworld.wolfram.com/HypergeometricDistribution.html
Part of the challenge is that your error rate is so small. 500 ppm = 1 part per 2000 = 3 parts per 6000. Assuming 500 ppm is the limit on acceptable lots, you are trying to deterine if there are 4 or more defects out of the 6000 pieces.
If you have to use a pass/fail type test and if the test is labor intensive, this might be a good place to consider a continuous sampling plan. I haven't work the exact numbers, but it would be something like:
* reject the lot if 1 of 500 is bad
* reject the lot if 2 of 1500 are bad
* reject the lot if 3 of 3000 are bad
* reject the lot if 4 out of any number are bad
* accept the lot if 0 of 2000 is bad
* accept the lot if 1 of 4000 is bad
* accept the lot if 2 of 5000 are bad
* accept the lot if 3 of 5900 are bad
Always note that this assumes a random sample. you shouldn't just take the samples in order because the defects are quite likely to be clustered in many real situations.
Tim F
Helmut Jilling
Auditor / Consultant
RE: PPM=500 - if this is internal PPM, it is indeed pretty good. If 500 is an external PPM performance, it is not good at all. An external 500ppm would fall below the performance of almost every certified client I work with.
Also, please bear in mind, you are discussing AQL levels. If you are talking about automotive clients, the default is usually C=0.
Sorry - but in this case, your best approach is either a poke yoke inspection device and 100% inspection (if possible) OR use a "variables" sampling plan if your characteristic of interest can be measured and expressed with continuous data (as opposed to pass/fail categorical data). A sample plan that uses continuous data will enable significantly smaller sample sizes...
Tim Folkerts
Bev,
I have to agree with you. :agree1:
I was answering the statistics question of what sort of plan would be required to meet the original "specs" of a sampling plan to acheive a particular confidence level, etc. It turns out that a sampling plan to acheive the desired goals as stated is not particularly practical. Even the continuous sampling plan would require testing a good fraction of the parts from each lot.
As you rightly point out, this is a case where the original problem should re-thought. You provide two excellent alternatives - 100% testing or finding a variable to measure rather than a pass/fail test.
Tim F
Statistical Steven
Statistician
Excellent post! Just a caveat, Poisson should be used when npq <5 otherwise use the binomial. In this case, the difference is in the 3rd decimal place.
N
nielsmx
Isn't that 100% inspection?
Sorry, I'm not a statistician, but if I see the number 5992 out of 6000, I get the feeling that we're talking about 100% inspection. And once we are talking about 100% inspection, we can throw away the defective pieces and make sure that we deliver 6000 pieces defect free.
What we still have to do is checking our inspection for defects. Too often the production (or development) process is thought to be in need of inspection, however, I assume that inspectors are also human and as much prone to producing defects, so if we did 100% inspection, what will be our confidence of delivering according to the spec?
yes the theoretical requirement for the Poisson is not met. This is a consistant problem with very low defect rates...but we must remember that both teh Poisson and the Binomial are only models and estimates. The real proof is if they are useful for need. (to paraphrase George Box). Other factors suchas how the samples are taken and how the defects may or may not cluster will add more 'inaccuracy' to the result thant the choice of distributional model. and as you point out the differences are slight anyway.
I choose to use the Poisson in most cases (not all) because it is easy to calculate
But of course the real point here is that with small defect rates we need to stop looking for proportional sampling plans and begin assessing alternatives sucha s poke yoke and continuous data plans. you simply cannot guarantee zero defects with proportional sampling plans adn this is where so much of industry is headed - an drightly so in my opinion.
L Sampling Plan Risks AQL - Acceptable Quality Level 6
R Reduced sampling plan for sterial products APQP and PPAP 0
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S How to make a Sampling Plan - Conveyor belts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Help develop sampling plan for prototype samples (medical devices) Statistical Analysis Tools, Techniques and SPC 7
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
J Sampling Plan Questions from the CQE Practice Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Sampling Plan for for Chemical Analysis Testing of Medical Devices EU Medical Device Regulations 3
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
N Use of arrows in ISO 2859-1 Table 1 and 2-A sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S AS9100 Sampling Plan Requirements - 8.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Military Sampling Plan 105E vs. ISO 2859-1 AQL - Acceptable Quality Level 2
kedarg6500 Acceptance Sampling Plan for Variables - Product Performance Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Where could I get reference to an OQA Sampling Plan of 1 per 1000 ? Quality Manager and Management Related Issues 4
R What to Report when Using C=0 Sampling Plan Supplier Quality Assurance and other Supplier Issues 15
R Results: Monte Carlo Simulation of Acceptance Sampling Plan AQL - Acceptable Quality Level 3
G Sampling Plan according to SAE ARP9013 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan for a Performance Qualification of an Inflation System Qualification and Validation (including 21 CFR Part 11) 2
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
Q Sampling Plan for Paper and Tape Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B In-Process Sampling Plan for a Secondary Package Adjustment Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E How to determine the Lot Size for the OQ Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
G Sampling Plan - Sample Size Justification for a Bottling Cleaning Process Validation Qualification and Validation (including 21 CFR Part 11) 2
I Alpha and Beta in the Sampling Plan for ISO 2859 & ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
V Sampling Plan for Final Inspection and Process Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
