Sampling Plans & Control of Nonconforming Product
#21
Tim Folkerts said:
I wouldn't say its a question of caring vs not caring, but rather a question of how much I care. I care enough about deer in the road to wear a seat belt, but not enough to stay at home. It's a balance.
Similarly for bad parts. There are cases where paying less is worth a few bad parts in a lot. There are cases where paying for inspection is worth avoiding unusually bad lots.
Just my $0.02
Tim F
Tim, I understand, trust me, but what you're talking about has nothing whatsoever to do with my question. In the case in point, a decision has been made to do screening inspection. This means that someone is concerned about bad parts getting into stock or production (what other reason could there be to do the inspection?). The OP informs us that after defectives are found, if the number of defectives is lower than the AQL limit, the lot is accepted without further screening even though the lot "probably" contains more defectives.
So.
Why do the inspection in the first place if you're OK with sending bad parts to production? Asked another way: What is the purpose of the inspection if you're willing to send bad parts to production?
Tim Folkerts
#22
The purpose of inspection isn't to verify that the lot has just a few bad parts.
The purpose is to verify that the lot isn't outrageously awful.
For every slightly bad (but still acceptable) lot, inspection is a waste of time and money. You use manpower, you reject some lots that really aren't too bad - and in the end the product is just as good (or bad) as if you hadn't done the inspection. I agree with you 100% that this is worthless.
For every truly awful lot, however, the inspection may well be advantageous. A really bad lot could easily wipe out the profit of 10 or 20 good lots. If you have no profits for a month because of one bad day, it could well be worth a few dollars per day of inspections costs as insurance against losing the month's profits!
For every acceptable lot inspected, you lose a little money. For every awful lot inspected, you save a LOT of money. Estimates of costs, rates, etc would be needed to decide in specific cases whether the savings exceeds the costs.
I think this is getting more directly at your central issue. :yes:? :nope:?
Tim F
Manix Automotive Sampling Plans. HELP! Working on an Automotive process control plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Disposable Medical Device Sampling Plans per ISO 2859-1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Relating Cpk to Sampling Plans - AS9100C Para 8.2.4 & AS9103 Para 4.4 d. Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
K Sampling Plans - Continuously Decreasing Sampling Over Time Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G Why do we use Sampling Plans based on Producer's Risk? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
J Sampling Plans - AQL Table Application AQL - Acceptable Quality Level 2
Q Inspection Methods and Plans - Forgetting to Switch Sampling Levels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C C=0 vs. AQL MIL Standard 105 E - Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Sampling Plans - Guidance to Sampling a Process during Validation Qualification and Validation (including 21 CFR Part 11) 12
T Skip Lot Sampling Plans (SkSP) - Oil for Trans Fatty Acid Content Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O Sampling Plans for a Medical Device - What to use for my Accept and Reject Number? AQL - Acceptable Quality Level 3
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Cleaning Validation Plans, Sampling, etc - Allergens in Food Qualification and Validation (including 21 CFR Part 11) 1
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A What is a good lot size? We use the C=0 Sampling plans at AQL %1.0 AQL - Acceptable Quality Level 9
B AS9100C Sampling Plans - When samples have known nonconformities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Sampling plans for mass-produced fasteners - I'm concerned with PPM and AOQL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Sampling Plans for Critical Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Zero Acceptance Number Sampling Plans, Fifth Edition (e-Book) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V How to use Sampling Plans - Confusion on Lot Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
G Sampling plans for large quantities along lines of ISO 2859-1:1999 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
R Sampling Plans - ISO 2859-1: 1999 - How to calculate the switching score? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Asian Supplier Sampling Plans besides MIL-STD-105? My thought was ISO 2859? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Sampling Plans for Corrective and Preventative Maintenance Service Orginizations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
QChas The Source of "C=0 Sampling Plans Index Values (Associated AQLS)" AQL - Acceptable Quality Level 3
R Need to set up sampling plans in Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S Developing sampling plans based on AS1199, ISO 2859-1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Can Continuous Sampling Plans be applied to service organizations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Reducing Inspection Costs - Sampling Plans and Producer's Risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Sampling Plans - Can a company create its own Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
A Sampling Plans and Cpk - Ways to Calculate the Sample Quantity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
