Schedule for SOP Review - Listing by Names of Process Owner versus Job Titles?
TracyShirley
I have been given the task of setting up a schedule for SOP reviews by listing all the procedures for the different manuals and setting an "Owner" and due date. Is there anything within ISO that sets a requirement when listing the "Owner" by just Job Title or their Names? I know this sounds kinda... well, dumb I guess, but I was presented with this question by one of my bosses so I figured I would ask. The schedule is just for this year so it is not something that is necessarily set in stone and would change year to year (or when a new procedure is added/removed).
Thank you in advanced!
Stijloor
Re: Names versus Job Titles?
Smart thing to do is make references to titles.
Of course, responsibilities and authority for that position (role) must be defined.
Stijloor.
RoxaneB
Nope, not a dumb question at all! :D I think many of us have struggled with this dilemma at least once and, as much as this does not answer your question, it really depends on what works for your organization.
A smaller company may prefer to use names. A larger company may prefer to use titles.
I am one of those people who is quite happy to sit on the fence, right in between both opinions. Why? Because people come-and-go, and having the title is good way for a new person replacing the former person to know which documents fall under his/her umbrella. A title is also an excellent way to show that the person reviewing/approving a document is the most suitable person. For example, in most organizations, the Quality Manager would not be the most suitable candidate to approve the content/format of the HR Orientation Checklist.
Having names, however, is good to include that bit of a "personal touch" and accountability. To show that the HR Manager must approve something is great, but to show "Jane Doe, HR Manager" is responsible...wow, now that's something.
And should Jane leave, to be replaced by John Smith, don't worry about having a mass blitz to change your documentation. Simply include, in your document control protocols, the process that the correct name/title will be added at the time of the next review.
That's my take on your situation. :D
P
phloQS
On the one hand this gives you a good chance to do a review on your documents more often ( every time a new colleague arrives), on the other hand you have to review the documents each time. Otherwise auditors will find n.c. very easily.
This is why I would always prefer jobtitles. I think there are documents which are not reviewed very often and do not need it in every company. So, why not the job title? The only document which must fit than is the organigramm.
Regards
phloQS
Marcelo
Please note that, whatever you do, it has to be done at an individual level, i.e., if you go thru the job title way and have more than one person with that title, you need to differentiate between them (Engineer 1, Engineer2, etc). This is true with responsibilities and authorities, and would be the same to process or document "owners" (the term owner refers to a responsibility of a person)
It doesn't have to be done at an individual level if all individuals with the job title in question are given the responsibility and authority for review and approval. Most times it probably will be best to identify an individual, but that doesn't mean it has to be done that way.
Statistical Steven
Statistician
The issue with using names is that you could have people change roles, leave the company or be out on medical leave when the review and approval are planned. I like to use titles when possible. I have even seen companies use verbiage like Manager, Process Engineering or their delegate. Just make sure that you do not put yourself into a compliance quadry.
JAltmann
I prefer titles, simply so i don't have to change the documents as often. But if i was in a relatively small company where people where multiple hats or titles i wouldn't think it a bad thing to use names.
Ultimately it falls into that dreded catagory of "it depends". Go with the method that works best for you, both should be accetable to an auditor.
Marcelo
Not to begin a parallel discussion, but as far as I understand, responsibility (what someone is expected to do) and authority (what someone is allowed to do) are for individuals, not groups. You may need to have people performing the activities of others (for example, if someone goes on vacation), however this has to be planned at the individual level.
It's good to always be careful to distinguish between what's required under the standard, and what's prudent but might not be specifically required. Assuming that the OP is referring to ISO 9001, there is no requirement to identify individuals who are responsible for document review/approval. The requirement (ISO 9001-2008 4.2.3 (a) and (b)) is review and approval. There is also no general requirement that states that R&A must be assigned to specific individuals as opposed to groups of people with the same job title.
It's not unusual for review/approval requirements to be expressed at different levels, depending on the nature of the change or review. For example, for a new process document, the requirement might be for a process owner to review and approve, while periodic review or review of minor changes might be assigned at a lower level (any quality engineer, e.g.).
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
T Internal Audit Schedule when Hiring Out Internal Auditing 7
M Informational EU – Schedule of meetings of MDCG and subgroups – 2019 Medical Device and FDA Regulations and Standards News 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
D Delivery Schedule Performance - IATF 16949 Cl. 9.1.2.1-d IATF 16949 - Automotive Quality Systems Standard 3
K Is an annual "audit schedule" the same thing as an audit scope/ audit plan? Internal Auditing 8
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
M MDSAP Audit Plan - Please share an Audit Plan/Schedule/Agenda ISO 13485:2016 - Medical Device Quality Management Systems 7
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
M Example Internal Audit Schedule wanted Internal Auditing 47
C DCMA (Defense Contract Management Agency) asking for Inspection Schedule Dates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L Sourcing Audit Schedule for Supplier Audits IATF 16949 - Automotive Quality Systems Standard 3
A Management Review not conducted according to schedule Management Review Meetings and related Processes 9
T Are Customers required to follow a Manufacturers Maintenance Schedule? ISO 13485:2016 - Medical Device Quality Management Systems 3
S No Audit Schedule and Internal Audit not Performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
D Health & auditing/assessment schedule Imported Legacy Blogs 0
L R2 Certification Internal Audit Plan, Audit Sheet, and Schedule Manufacturing and Related Processes 2
B Is there an FDA requirement for a Supplier Audit Schedule US Food and Drug Administration (FDA) 22
S Help me with preparing Internal Audit Schedule based on Risk analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B ANVISA B-GMP Inspection Schedule Other Medical Device Regulations World-Wide 4
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
B Corrective Action for Deviation (delay) in the Delivery Schedule Quality Manager and Management Related Issues 10
R Internal Audit Schedule Conformance Quality Manager and Management Related Issues 31
Y Training Plan/Schedule - Can anybody share a format or template for annual training Training - Internal, External, Online and Distance Learning 8
J TS 16949 Clause 4.2.3.1 based on Customer Required Schedule IATF 16949 - Automotive Quality Systems Standard 2
L ISO 13485 Internal Audit Schedule example needed Internal Auditing 9
S Schedule D II Format for Medical Device Registration India Other Medical Device Regulations World-Wide 3
Moncia Supplier Audit Requirements for ISO 22000 - Is a schedule required? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
M QSIT-Based ISO 13485 Internal Audit Schedule Internal Auditing 8
K Seeking help in making a decision - Project behind schedule Quality Manager and Management Related Issues 11
Q Maintenance Schedule with Client in my Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Does anyone have an example of an ISO 14001 Internal Audit Schedule ISO 14001:2015 Specific Discussions 2
J Timing of an Internal Audit Schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Receiving inspection and Internal Audit schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
F How to Integrate Audits and Audits Schedule - ISO 9001 and OHSAS 18001 Occupational Health & Safety Management Standards 2
V Layered Process Audit Schedule example Process Audits and Layered Process Audits 2
N Second Party (Supplier) Audit - Audit Schedule and Audit Report Template/Format General Auditing Discussions 3
E Document Retention Schedule Requirements per ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
V How to calculate for LCL and UCL for Schedule Deviation Quality Tools, Improvement and Analysis 2
D Is there any software for making an Injection Molding Machine Schedule? Lean in Manufacturing and Service Industries 6
E Milestone / Schedule / Plan for Quality Management System Misc. Quality Assurance and Business Systems Related Topics 3
