Scheduling IATF 16949 Audits - Audit Man-Days
QualitySpirit
If any IATF recognized TS auditors read this thread, your input on this will be highly appreciated. I am a TS auditor myself, but I recently switched CB and it happens that the interpretation for audit planning is different.
At my former CB, if I am to plan an audit plan of 2.5MDs e.g. total 20hours
I have a freedom to plan like this.
Day 1: 1hour information review prior to opening + 7 hours TS audit
Day 2: 7 hours TS audit
Day 3: 6 hours TS audit
As long as the total TS audit hours = 20 hours and the audit plan satisfies other rules 5.2 requirements, Veto persons are fine with such planning.
I used this kind of concept to balance the audit. For example, if I need to go to a site far away that requires travel time of 5-6 hours. I would plan the first day a little shorter as I would reach the site in the afternoon and if the client has no night shift, it is totally impossible to audit them for another 8 hours.
Also I balance the second and third day workload.
However at my new CB
They insist in a case of 2.5MDs I have no other choices but to plan.
Day 1: 1hour information review prior to opening + 8 hours TS audit
Day 2: 8 hours TS audit
Day 3: 4 hours TS audit
The CB requires that I go one day prior to the audit and stay nearby the site so that I can undertake the audit for 1+8 hours in the first day, and the second day I also definitely have to plan for 8 hours no more no less.
The CB claimed this rule is from their oversight office, and there is not any flexibility on this regard.
I would be interested to hear if your IATF recognized CB also has this kind of regulation on audit planning.
Thank you in advance :)
QualitySpirit
Re: Need inputs from IATF recognized TS auditors
If you don't like to post, I would be grateful if you could send PM to me about your feedback and I won't share your feedback without your permission.
This new CB causes me real stress, as I don't want to travel one day earlier and have no flexibility to balance work loads.
If it is the case that the requirement is only applied at this CB specifically, I would certainly change to another CB under the previous oversight. :bigwave:
Howard Atkins
Forum Administrator
Re: Need Inputs from IATF recognized TS 16949 Auditors
I do not see any problem with thisand have not had any problems with this.
The amount of time is a maximum not a minimum
From the rules
an audit day is typically a full normal working day of eight (8) hours. A half of an audit day istypically a working day of four (4) hours,
the total audit days may not be reduced by programming longer than eight (8) hours per working day. The only exception is on days when third shift work (i.e. shift that operates outside of the normal working hours of the site) is being covered. The additional hours spent auditing the third shift shall not exceed a maximum of 0.5 audit days (i.e. 4 hours) per audit,
Have you changed from one oversight body to another?
There still is a problem of uniformity between the i=oversight bodies
QualitySpirit
Thank you.
Do you mean your CB allows planning with flexibility the same as my former CB does?
Yes, the CB I belong to now is under a different oversight from my previous CB's. It is not reasonable that different oversight offices have different rules while we are working under the same IATF rules.
Peters
There are sometimes discussions in my CB about these calculations.
Reason for this discussion is text in Rules: "audit day is typically a full normal working day of eight (8) hours". So, some auditors and office personnel read this text literally and require exactly 8 hours, and some auditors and office personnel treat this flexibly. Well, there are sometimes problems with this flexible interpretation when it comes to talk with DAkkS accreditation or VDA.
As for me, the most important is the total amount of hours, not their distribution in days.
My experience:
In my CB I have never had problems with the verifier when sending a report with the days that have 7 hours. They check only total amount of hours/days.
When sometimes colleagues-auditors ask me "Will you approve my report during verification with the days that have 7 hours?", my answer is "yes."
QualitySpirit
Thank you Peters,
Yes the CB quoted exactly the rule sentence that you pointed out.
Actually what CB told me is quite funny.
They said the oversight requires to plan 8 hours per day.
But on the other hand for integrated ISO9001 + TS audit, they allow to count ISO9001 audit time into this 8 hours e.g. it is acceptable for them to plan in a day 6 hours TS audit + 2 hours ISO9001 audit.
This is totally confusing. In my opinion, oversight only has authority over TS16949 audit time while ISO9001 audit time is controlled by Accreditation Body not by them.
Peters
1. I remember several audits with the first day of a 2 or 4 hours. It was the best solution in relation with a travel to the company. And I remember some audits with the first day of a 8 hours but the audit started for example at 3 pm.
2. We have the problem that our bosses usually accept all the directives from oversight and accreditation body. It's difficult to discuss this.
Howard Atkins
Forum Administrator
Thank you.
Welcome to the real world:deadhorse:
Those of us that work for different CBs with different Oversight bodies know that there are great differences between them:bonk:
risk_experts
Audit days for QMS (EMS) are calculated on rules of International Accreditation Forum (IAF). Name of this document is IAF MD 5:2015.
K AS9100D production process scheduling requirements Internal Auditing 14
S Scheduling a Crisis Management Audit? Reasonable Request? Internal Auditing 2
B AS9120 Internal Audit Scheduling & Planning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B TS 16949 Auditor Availability and Registrar Scheduling Delays Registrars and Notified Bodies 4
I CB Scheduling ISO9001 Surveillance Audit 15 Months past Re-Cert Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
insect warfare Internal Auditor Scheduling Tool Internal Auditing 9
SATHYABALARAMAN Process assessment & scheduling the audit IATF 16949 - Automotive Quality Systems Standard 4
R IAF Time Window requirements for scheduling Recertification Audits Registrars and Notified Bodies 6
A Risk Based Internal Quality Audit Scheduling and Planning Internal Auditing 2
S Scheduling Jobs through a fast paced Sheet Metal Job Shop Manufacturing and Related Processes 5
B Implementing and Rolling Out a Kanban System to Dictate our Scheduling Lean in Manufacturing and Service Industries 3
S Scheduling Internal Audits Internal Auditing 5
V Visual Control - Takt based Production Scheduling Lean in Manufacturing and Service Industries 8
R Internal Audit Scheduling Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 21
R Tracking Production Scheduling Lean in Manufacturing and Service Industries 18
Ron Rompen Shiftwork Scheduling - An unusual problem - Need help please Human Factors and Ergonomics in Engineering 13
L Manufacturing Production/Labor Scheduling Tool Manufacturing and Related Processes 3
L How to Audit Procurement and Maintenance Scheduling Activities General Auditing Discussions 5
A Problems with our Registrar - Scheduling Audits Registrars and Notified Bodies 21
Z Laboratory Test Scheduling and Tracking Gantt chart Excel .xls Spreadsheet Templates and Tools 3
A Managing and Scheduling Internal Audits Internal Auditing 5
N Registrar Expectations from Customer in Audit Scheduling Registrars and Notified Bodies 5
M Lean without Computers? - Scheduling Lean in Manufacturing and Service Industries 4
M Preventive Maintenance Scheduling Software recommendations Lean in Manufacturing and Service Industries 8
P Suggestions on conducting an Internal Audit on 7.5.1.6 Production Scheduling IATF 16949 - Automotive Quality Systems Standard 2
M Are there Advantages to Forward Scheduling? Misc. Quality Assurance and Business Systems Related Topics 2
S Scheduling or Creating a Global Audit Schedule - Examples General Auditing Discussions 5
A Production Planning, Scheduling and Warehouse Management Manufacturing and Related Processes 8
H Visual Management - Production Scheduling Board Lean in Manufacturing and Service Industries 13
T NC: Lack of efficiency measurement for scheduling/shipping: clause 5.1.1 IATF 16949 - Automotive Quality Systems Standard 20
Icy Mountain Audit Scheduling for TS16949 - Audit split up by several 'working days' General Auditing Discussions 7
J Delphi Level Scheduling Logistics powerpoint .ppt Course Customer and Company Specific Requirements 1
J Small Machine Shop - No process planning or job scheduling - ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Production Scheduling General Auditing Discussions 25
S TS 16949 Internal Audit Scheduling - Seeking Advice Internal Auditing 10
A Scheduling Internal Audits - What should I be auditing and when Internal Auditing 8
M Scheduling Internal Audits - Has ISO 9001:2000 changed how you schedule your audits? Internal Auditing 14
A Scheduling Internal Audits: Status and Importance of the Activity Internal Auditing 4
S Commercial gage scheduling software package that can store multiple PPM histories General Measurement Device and Calibration Topics 7
S Order Driven Production Scheduling QS-9000 - American Automotive Manufacturers Standard 1
D Production Schedule - Looking for some good ideas on production scheduling software Quality Assurance and Compliance Software Tools and Solutions 3
F Scheduling Internal Audits - What is meant by 'based on status and importance'? Internal Auditing 35
L Scheduling Internal Audits - Chrysler-specific Requirements Internal Auditing 7
Marc Supplier Delivery Performance Monitoring - Critical Path Scheduling - TE - 4.15.6 Supplier Quality Assurance and other Supplier Issues 2
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 6
A IATF Non-Conformance 5 Why IATF 16949 - Automotive Quality Systems Standard 2
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
D Is IATF certification required when customer doesn't require it? IATF 16949 - Automotive Quality Systems Standard 19
A Laboratory scope on the IATF IATF 16949 - Automotive Quality Systems Standard 5
