Scope of ISO 9001 Registration of Automotive Leasing Company?
samer
Involved - Posts
Freinds,
im preparing QMS for automotive and leasing company
we lease vehicle to customer and the same time we fabricate interior steel cage for the same vehicle as an additional service .
we need the (scope of registration ) to be just for the leasing activity without the fabrication section
can this be done in yr opinion ? if you know that the fabricatied cage will certainly affect the final quality of the leased vehilce .
Sidney Vianna
Post Responsibly
Confucio said: "Scope the scope".
can this be done in yr opinion ? if you know that the fabricated cage will certainly affect the final quality of the leased vehicle .
Yes. You can limit the scope of certification to the vehicle leasing activities. I suggest you peruse the document available through this link that explains the difference between the scope of the QMS and the scope of certification.
Hope this helps.
samer
Involved - Posts
reply
sidney,
thanks ,i"ve read hte document but, but my concern was to what degree can I limit the scope of registration as example for two production lines ,are you totaly free to do that , even if you know that there is some common activities between them which will affect the customer satsfaction??
Paul Simpson
Re: Confucio said: "Scope the scope".
Hope this helps.
Thanks to Sidney for posting the links. I have followed the thread through the ISO guidance and am sorely disappointed that you can pretty much choose what you have assessed and certifyed / registered. Here is just one of the examples they provide:
Situation:
A bank provides a variety of services to its customers (i.e. personal and company bank accounts), but chooses to implement a QMS only for its Internet banking services. For this service the bank has claimed conformity to ISO 9001:2000. The bank clearly states in its Quality Manual which services are covered by the QMS. The bank applies all the requirements of ISO 9001:2000 for the realization of its Internet banking services, with the exception of sub-clause 7.5.4 Customer property. The bank does not feel that it has possession of any customer property as part of its Internet banking services and has stated this in the justification for the exclusion of sub-clause 7.5.4 Customer property from its QMS.
Issue(s):
Can the bank exclude sub-clause 7.5.4 Customer property from its QMS and claim conformity to ISO 9001:2000?
Analysis and Conclusion:
The decision made by the bank to exclude sub-clause 7.5.4 Customer property was not justified because the bank does receive information from its customers such as personal and confidential data. ISO 9001, 7.5.4 Customer property requires an organization to exercise care with customer property while it is under the organizations control or being used by the organization. In this situation, the bank’s customers provide important information in confidence when using the service, which constitutes “Customer property”. Therefore the bank has to address the requirements for customer property in its QMS.
Is it only me who thinks this is wrong. IMHO the scope of the QMS should cover everything the organization does. Otherwise you are relying on the registrar / CB to police the organization's use of registration marks to make sure potential customers are not misled into thinking the registration covers more of the organization's activities than it does. Taken to the nth degree you can have an organization that has a thousand product lines and has one manufacturing line assessed and registered. Surely any claims of registration by the organization would be misleading? Or is it me?
Any other examples, anyone?
Helmut Jilling
Auditor / Consultant
....Is it only me who thinks this is wrong. IMHO the scope of the QMS should cover everything the organization does. Otherwise you are relying on the registrar / CB to police the organization's use of registration marks to make sure potential customers are not misled into thinking the registration covers more of the organization's activities than it does. ...
I think you are correct, Paul. An organization should have the right to determine what scope should consist of, but there is no one to police how the organization represents their "partial" certification. Will they openly communicate only one division is registered? Probably not...
Sidney Vianna
Post Responsibly
But it is the CB's responsibility to police the use of the marks and issue a certificate that CLEARLY defines what is certified and what is not. The users of the certificate should also be attentive to it's contents.
In the scenario that an organization, with hundreds of plants around the World, has been requested by a customer to have a plant certified, would you expect the whole organization to go for (unnecessary) certification?
But is is CB's responsibility to police the use of the marks and issue a certificate that CLEARLY defines what is certified and what is not. The users of the certificate should also be attentive to it's contents.
I understand Paul's misgivings, but there are also instances where companies registering to 16949 have non-applicable commericial business; would it be questionable in such a case for company to tout its registration to non-automotive customers? At what point does it become the customer's responsibility to understand the scope of registration?
Sidney Vianna
Post Responsibly
IMO, when a customer relies on a third party certificate, as part of their supplier oversight process, they MUST be educated enough about issues such as this and carefully scrutinize the certificates.
Check this ISO-advice
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Dropping ISO 9001 limits the scope of the ISO 13485 audit? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 - Scope of Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
N ISO 9001 certification with limited scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001:2015 - Extent of Policy and Scope with Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
I ISO 9001 Scope - Exclusion of Design in an engineered solutions company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Changing ISO 9001 Certification Scope Quality Manager and Management Related Issues 4
E Extending current ISO 9001 registration scope to cover SW development Software Quality Assurance 2
A Scope on ISO 9001 Registration Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M How to include Gas Measurement Equipment Servicing & Calibration Scope to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Defining ISO 9001:2008 Scope for a Sterilization Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Defining the scope for ISO 9001 Registration - Software, Hardware and Customer Care ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H Is Scope Validation required for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Adopting New Sites and Divisions into an existing ISO 9001 Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Can we include internal audit (financial) in the scope of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
F Adding a New Office Location to an ISO 9001 Certificate (Scope of Registration) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Jim Wynne Is this ISO 9001 Registration Scope Statement Too Vague? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
H Scope Definition - Scope of ISO 9001 Registration Imported Legacy Blogs 1
S Scope Definition - Scope of ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
G Scope Change? Moving all molding process - ISO 9001 Other ISO and International Standards and European Regulations 3
N ISO 9001 Scope of R&D/IT sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Ideal Internal Audit Frequency and Scope - ISO 9001 Internal Auditing 6
G Determining the Scope of ISO 9001:2000 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
A Focus and Scope of ISO 9001:2000 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Activities Outside of an ISO 9001 QMS Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Control of Records retained outside ISO 9001 Scope Records and Data - Quality, Legal and Other Evidence 5
M ISO 9001 Audit Concern about Written Job Scope & Responsibility for Employee? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Scope of QMS (Quality Management System) - What is it? Clause 4.2.2 of ISO 9001-2000 Quality Management System (QMS) Manuals 4
N Question Re: Scope of ISO 9001:2000 effort ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I ISO 9001:2000 Exclusions for our Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Casana Auditor changing ISO 9001 AUDIT scope midstream - Cannot exclude all of 7.3 anymore General Auditing Discussions 26
C Supplier has different ISO 9001 certification scope and TS 16949 certification scope Supplier Quality Assurance and other Supplier Issues 15
C Part 145 Repair Station Rating and Capability List vs. ISO 9001 certificate Scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 66
E ISO 9001:2000 requirements - Which of these options reflect the scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
M ISO 9001 Scope of Registration - Company sub-contracts everything ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Scope and Purpose - For some reason cannot seem to write anything - ISO 9001 - 7.2.2 Document Control Systems, Procedures, Forms and Templates 8
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 5
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
Q The scope of ISO 21534 Other Medical Device Related Standards 0
