Scrap is NCR or not - What regulation
Mark Meer
#11
...Anyone who is trying to hide behind needing a regulation doesn't want to be "found out" that the process they are responsible for is costing the organization money...
...The hidden agenda behind the resistance to document scrap is asymptomatic of a major dysfunction. Any organization that resists the basic notion of documenting rejected and dispositioned as scrap product is playing silly games...
To be charitable to the OP and their organisation, it's possible that there's another explanation. It may be that their established process for documenting NCs is robust (see Ninja's post), but when it comes to less significant items the process seems overly onerous.
When I hear "where's the regulation?", I'll often read it as "do we really need to do this?". In this interpretation, the problem is more failing to understanding why it's valuable, and that there may be easier approaches - not necessarily that there are nefarious motives at play.
...Scrap represents piles of money in boxes or on the floor...
This may also not be the case.
Here's an example from personal experience:
We used to have a single form for documenting NCs. It was quite detailed - which was good in most cases. However, every so often during assembly, a screw would fail to screw in properly (e.g. it was bent slightly, or threads were damaged). This would be a component non-conformance, but it seemed totally overkill to use the NC form every time this happened. The screws are less than pennies apiece, and they are always just scrapped.
So, to deal with this, we adopted another system for logging such NCs - Just table with a few columns detailing the when, what, and disposition (pretty much exclusively scrap) - something assembly personnel can fill out in a matter of seconds.
If the OP's situation is like this, then I can understand why management would be wondering "why are we doing this?". To the OP: if this is like your situation, understand that you can develop alternate methods, and the NC data can still be useful in the long-term.
#12
Agree with Mark.
the important regulatory requirement in most standards is the identification of non-conforming material to prevent it's use in a non-conforming state or - during more paranoid days - of use by enemy countries or black market resellers. so called 'toe tags' or 'red bins', etc.
The toe tag would have very little info on it, but usually enough for the engineer or MRB to disposition the material. if the disposition was patently obvious (scrap) then disposing of the material in a red bin that would later be emptied and scrapped was used. If the industry were sufficiently regulated (e.g. Aerospace), there might be requirements for accountability/traceability of the material.
So the OP may very well have a good reason for asking about 'over documentation depending on their industry.
In general I've never found the tracking of NCs to be all that much helpful except for financial accounting and prioritization purposes. this is because the cause - unless there was an obvious 'oops' by operator or equipment - is simply unknown without hands on investigation.
ScottK
Not out of the crisis
#13
Can I ask a question....
are we talking
A) scrap due to nonconforming product found during or after the process?
or
B) scrap due to set-up, change over, shutdown, leftover material, etc... i.e. expected scrap?
Because I would not write an NC for B.
Ninja
Looking for Reality
#14
are we talking
or
Nor for a bent screw...I would just replace it and have no NC to record...the part would never make it that far before it was just fixed.
#16
If your process was to complete a NCPR every time you discovered a bent screw, your process needs changing. That's NOT what ISO 9001 has ever required this, but DOES require a record.
Mark Meer
#17
Question: why the exception for a bent screw? In practice, we treat all components that go into final product the same - If they are found to be NC during assembly, it is documented.
...In general I've never found the tracking of NCs to be all that much helpful except for financial accounting and prioritization purposes. this is because the cause - unless there was an obvious 'oops' by operator or equipment - is simply unknown without hands on investigation.
With respect to scrapped items, this definitely tends to be the case in practice. However, while financial impact is certainly the most obvious thing one can derive from such documented NCs, they may also help to indicate:
  • Potential issues in receiving inspections - e.g. why are NCs being identified in assembly and not caught in receiving? Perhaps the receiving sampling can be adjusted?
  • Potential issues with a particular batch of components - e.g. why are all the NCs within a particular date range?
  • Potential issues with personnel/training - e.g. why is it the same person logging all the NCs?
Also, the preponderance of the same NC overtime may eventually lead to a decision to investigate subsequent instances more thoroughly.
Ninja
Looking for Reality
#18
Well, there is certainly an assumption here on my part...that being WHEN the bent screw was identified.
Assuming as I have that during the fab of the part someone tried to put in a screw, found it bent and unusable, and got a good screw to use instead...the only thing I MIGHT choose to document is that another screw was used...but I might not even bother doing that. When you make stuff, non-perfect situations happen every day, why waste the time and paper?
If that assumption is incorrect, and it was passed down the line to further process steps or final QC and found there I would document it...there is more of a systemic issue.
Formally document every time something doesn't work ideally and was addressed in a minute during the same process? Hardly. It would be like filing paperwork for dropping my screwdriver.
Formally document that a process step allowed NC product into further manufacturing? Certainly.
At the end of the day, it ends up for me at cost/benefit (or risk analysis if you prefer). If I complained to Home Depot every time I pulled a roofing nail out of the box that didn't have a head on it, I'd never get the roof on. If I found the box of roofing nails actually contained screws, I'd complain.
FWIW: I am also assuming that there is a corporate culture that supports the assembly person to complain upwards when they face bent screws every single day...
Mark Meer
#20
...Formally document every time something doesn't work ideally and was addressed in a minute during the same process? Hardly. It would be like filing paperwork for dropping my screwdriver.
At the end of the day, it ends up for me at cost/benefit (or risk analysis if you prefer)....
I agree with the cost/benefit at the end of the day...
But just for discussion sake, let's take another example:
I have a (moderately) high value plastic component. Again, just like with the screw, sometimes during assembly this part is found to be non-conforming (giant burr, slightly warped and doesn't fit...whatever). As with the screw, these are almost always just scrapped and a new one used - nothing NC goes further up manufacturing.
If this is a regular occurrence, I'm loosing money! As I said in the previous post, a preponderance of such cases might be good grounds for revising our receiving sampling, or supplier controls.
But, were I treat this like the screw and focus purely on "does it allow NC product into further manufacturing?", these would all get scrapped and go undocumented. Other than, as you say, relying on a corporate culture, there would be nothing in place to identify this as an issue (except, perhaps, in the long term some accounting queries I suppose).
M NCR Disposition Practices - Traceability of Scrap Nonconformance and Corrective Action 5
L Scrap % calculation for a year. Manufacturing and Related Processes 3
M Targets / limits for PPM/ Scrap Manufacturing and Related Processes 2
M Scrap metric/ Waste metric Manufacturing and Related Processes 1
S Cost of Poor Quality (CoPQ) - Scrap element of calculation includes lost margin? Misc. Quality Assurance and Business Systems Related Topics 7
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
N Interesting Discussion Murder mystery and mission creep - Challenged to eliminate scrap AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
Sidney Vianna IAQG News Future AS9147- Management of Unsalvageable Parts - Previous scrap parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Establishing a monthly scrap cost target Lean in Manufacturing and Service Industries 11
WCHorn Rendering Scrap Unusable before Disposal (AS9100D, Section 8.7) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
S Scrap % Calculation Formula Manufacturing and Related Processes 10
R DPPM? Scrap? Both? How to report Returns Misc. Quality Assurance and Business Systems Related Topics 6
N Ways to Destroy Scrap Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
N What Can I Do With Plastic Pellet Scrap? Manufacturing and Related Processes 17
Z Scrap Process - They weren't Physically (Dimensionally) Nonconforming Manufacturing and Related Processes 6
S Cell Rubber Stamping PPM for Scrap Analysis Quality Tools, Improvement and Analysis 1
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R How to Handle 'Scrap and Replace' of Non-Conforming Products Nonconformance and Corrective Action 9
M Start Up Scrap vs. ppm (Parts per Million) in an FMEA IATF 16949 - Automotive Quality Systems Standard 17
Q Temporary Control of Scrap at the Machines while the Process is Running Nonconformance and Corrective Action 6
J Scrap, Control or Marking - Ball Bearing Distribution and Re-Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q ISO 9001 Clause 8.3: Scrap, Rework, Repair, Why? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Disposition of Reject vs. Scrap Material Nonconformance and Corrective Action 6
F Do we need to destroy all nonconforming scrap product - AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
D Scrap Procedures - Example wanted Quality Manager and Management Related Issues 2
N Scrap Stored Long Term in MRB - ISO 9001 Nonconformance or Annoyance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Calculating Scrap Level for Cp=0.97 Statistical Analysis Tools, Techniques and SPC 3
R Analysing Scrap from Machinery Statistical Analysis Tools, Techniques and SPC 8
P Disposal of Plastic used in Medical Parts (Scrap) ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Scrap + Replacement always? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Gather and Analyze Production Scrap - MiniTab 16 vs. Excel Data Analysis Quality Assurance and Compliance Software Tools and Solutions 5
P Scrap handling system in soap industry - example Lean in Manufacturing and Service Industries 1
N Quality Objective - Scrap Measureables ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Discarding Customer Scrap product without their knowledge Misc. Quality Assurance and Business Systems Related Topics 4
A Scrap vs. Rework Classification - Scraping the resistor or reworking the PCB board? Quality Tools, Improvement and Analysis 10
L Quality Objectives Ideas - Currently we have Scrap & rework, OTD, survey results, etc Manufacturing and Related Processes 50
E Recording Scrap - Problems in the Medical Device Manufacturing Sector ISO 13485:2016 - Medical Device Quality Management Systems 4
A How do I set up a PPM with Total pcs shipped vs. Total Scrap for the month Statistical Analysis Tools, Techniques and SPC 10
A Control Chart to Track Effectiveness of Actions to Reduce Scrap Rate Six Sigma 7
P Study of Scrap on one of our production lines - What to use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L Control of Nonconforming Product in a Tool Shop - Scrap Dies Nonconformance and Corrective Action 5
B Unregistered Bulk Scrap Metal Suppliers - Do they need to be ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 10
T Nonconformity Records - Nonconformity vs. Scrap - 8.3 Requirements Records and Data - Quality, Legal and Other Evidence 14
O Scrap rate in the iron foundry casting industry Benchmarking 3
SteelMaiden Scrap Trader Kidnapped? UK scrap trader kidnapped by Chinese client World News 5
B The correct approach to calculating Internal Scrap ppm Statistical Analysis Tools, Techniques and SPC 3
K Scrap Material Areas - How to control nonconforming material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
