I agree with the cost/benefit at the end of the day...
But just for discussion sake, let's take another example:
I have a (moderately) high value plastic component. Again, just like with the screw, sometimes during assembly this part is found to be non-conforming (giant burr, slightly warped and doesn't fit...whatever). As with the screw, these are almost always just scrapped and a new one used - nothing NC goes further up manufacturing.
If this is a regular occurrence, I'm loosing money!
At the end of the day, it ends up for me at cost/benefit (or risk analysis if you prefer).
FWIW: I am also assuming that there is a corporate culture that supports the assembly person to complain upwards when they face bent screws every single day...
If I bought a box of screws, and one or two were bent...I'd just move along.
If I bought a truckload of kitchen cabinets and two were broken...different response.
Both of these happen every day, and neither one of them is worth building a new system to address...and you are quite correct, the impact on the business is a primary factor for determining the response.
When the folks noticing the bad screws complain to each other, but not to folks who can do something about it...working on the culture can have tremendous impact. Making them fill out forms much less so.
In either case...if the 'broken thing' was used anyway, and moved down the line to the next step anyway...that has to be addressed almost regardless of screw or cabinet. It is a symptom of a deeper systemic problem.
