Re: Scrap Material Areas-How to control nonconforming material
Or you can tag them with the part number, revision level and as set-up pieces. You can also list set-up scenrio's, which machine the part run's best on, what machine it does not run well on. etc. etc.
That is the best material to use. Our company (we have over 100 CNC machines) does it that way. One suggestion to make it work better for you, would be to paint the parts red to identify the as Nonconforming. You will need to define this in your Nonconforming Material process/procedure.
