Screw Thread Major and Minor Diameters - Parts vs. Gages
Wayne
Gage Crib Worldwide
The minor diameter of a screw thread ring gage is easily measurable as is the major diameter of a screw thread work plug gage. People frequently check these diameters and then they have questions as to apparent discrepancies in the gages. The three questions raised are:
1. Given that on a screw thread ring gage the NOGO pitch diameter is smaller than the GO pitch diameter, why is the NOGO minor diameter larger than the GO minor diameter?
2. Given that on a screw thread plug gage the NOGO pitch diameter is larger than the GO pitch diameter, why is the NOGO major diameter of a screw thread work plug gage smaller than the GO minor diameter?
3. Given that the screw thread pitch diameters are the same as the screw thread gage pitch diameters, why are the screw thread gage minor and major diameters so much different than the product screw thread minor and major diameters?
To totally discuss the major and minor diameters of thread gages, and the related inspection issues, let me state the following:
1. The screw thread gage major and minor diameters are different than the part major and minor diameters for specific reasons based on one of Taylor’s Principles: The GO should gauge all features simultaneously and the NOGO should gage each feature independently.
2. The GO ring gage major diameter is made as large as possible and is tested to assure that it clears a specific diameter. By design, the GO ring gage major diameter has no measurement function. The part thread major diameter is to be measured via alternate measurement methods.
3. The GO ring gage minor diameter is set at the maximum material condition. This tests the part to assure that the minor diameter has not grown to a point that it would interfere with the mating part.
4. The GO plug gage major diameter is set at the maximum material condition. This tests the part to assure that the major diameter has not shrunk to a point that it would interfere with the mating part. The part thread minor diameter is to be measured via alternate measurement methods.
5. The GO plug gage minor diameter is made as small as possible and is tested to assure that it clears a specific diameter. By design, the GO plug gage minor diameter has no measurement function.
6. The NOGO ring gage major diameter is made as large as possible and is tested to assure that it clears a specific diameter. By design, the NOGO ring gage major diameter has no measurement function.
7. The NOGO ring gage minor diameter is set at or just below the gage pitch diameter. This is to allow the NOGO ring gage to properly measure the pitch diameter and exclude data from the minor diameter. Once the minor diameter passes the GO gage it is considered good.
8. The NOGO plug gage major diameter is set at or just above the gage pitch diameter. This is to allow the NOGO plug gage to properly measure the pitch diameter and exclude data from the major diameter. Once the major diameter passes the GO gage it is considered good.
9. The NOGO plug gage minor diameter is made as small as possible and is tested to assure that it clears a specific diameter. By design, the NOGO plug gage minor diameter has no measurement function.
I hope that you will find this tidbit of information helpful.
Coury Ferguson
Moderator here to help
Very interesting information; so, I thought I would resurrect this thread for any Covers that may find it useful and valuable.
merrick65
Is there a formula to calculate the major/minor diameter? I see that the thread gages specify thread per inch and go & no-go pitch diameter but I do not know how to find or calculate the major/minor diameter.
Wayne
Gage Crib Worldwide
There certainly is a formula, but it will vary depending on the style of thread: ACME; Buttress; Unified; Metric; Whitworth; Centralizing ACME; Stub ACME; Trapezoidal; British Pipe; API and others.
The formula will be found in the standard that defines the thread. Alternatively, you could use thread engineering software.
For more information on Screw Thread Software I suggest you read Elsmar Cove post: Thread Gage Calibration Software to look up required/specs for thread gages.
If you have a one time need, there is a free 10-day trial of ThreadTech software.
G
Gordon Clarke
I've thought of a simple (and inexpensive) way to measure the minor diameter on an external thread and the major diameter on an internal thread. if anyone is interested I'll make a sketch as to how it can be done.
It (my method) is definately is a lot easier than making moulds for internal threads and/or using expensive optical appliances.
The good thing about the tolerances on those two diameters is that they are normally about twice as much as the pitch diameter tolerance.
Who knows, maybe my sketch (if asked for) will give someone the "kick" to come up with perhaps an even easier method.
The following remark is mainly for Wayne :)
I can't really imagine why anyone would want to measure those two diameters unless there was a problem and it had to be determined what exactly was wrong and by how much. ;)
Wayne
Gage Crib Worldwide
Gordon;
Typically the only measurement that need be taken related to these two diameters is one to assure that the maximum material condition has not been violated. Properly calibrated thread gages will assess that condition.
With the J-series threads, measurement of the external thread minor diameter can help assess the condition of the controlled root radius.
If measurements are desired, variable thread measurement systems have attachments which can be used to measure the external minor diameter and internal major diameter of screw threads.
G
Gordon Clarke
This could be an "apple pears" discussion but I'll try anyway :)
"Typically the only measurement that need be taken related to these two diameters is one to assure that the maximum material condition has not been violated. Properly calibrated thread gages will assess that condition".
It isn't that I disagree but "assessing" isn't quite the same as measuring. The biggest disadvantage with gauges is that "a miss is as good as a mile". In other words when the gauges say "fault" the user is left wondering by how much and what is wrong.
"If measurements are desired, variable thread measurement systems have attachments which can be used to measure the external minor diameter and internal major diameter of screw threads".
"If measurements are desired" is the whole point. If at an inspection (process or receiving) a gauges "says" defect then production can either be stopped or returned to supplier. It still doesn't help the machinist as he'll/she'll want to know what is wrong and by how much. Still, if it's a supplier it's easier to say, "your problem". :notme: If manufacturing and inspection each have their own gauges then a micron difference is enough to affect the result.
" ...... variable thread measurement systems have attachments which can be used to measure the external minor diameter and internal major diameter of screw threads".
Are any of these measurement systems you refer to inexpensive compared to for example, gauges?
I'll make a sketch (very soon) of what I think could be an inexpensive method of measuring the minor diameter on an external thread and the major diameter on an internal and you (and anyone else) can let me know what you think.
Wayne, one thing I think we are in complete agreement with is that making the perfect thread is a combination of gauging and measurement. The measuring for machine set up (especially pitch diameter) and gauging for a quick check during manufacturing.
Wayne
Gage Crib Worldwide
Hopefully the measurement is taken at the machine during screw thread production. Analysis of the problem is more expensive than, and will usually lead to the same result: Replacing the cutting tool. So why bother.
If ... a gauge "says" defect then production can either be stopped.... It still doesn't help the machinist as he'll/she'll want to know what is wrong and by how much.
Again, the least expensive thing to do is replace the worn cutting tool. Why do we care what is worn on the cutting tool, and adjusting a worn cutting tool to bring the thread into agreement with the gage will only increase the thread form deviation in another area.
Thus the stipulation in ANSI B1.2 paragraph 2.2.1 (see attachment): "...a product screw thread is considered acceptable when it passes a test by any ... gages,...provided the gages being used are within the tolerances specified..."
They are not inexpensive compared to gages, but if such measurement, for some reason becomes critical, they are not prohibitively expensive.
... making the perfect thread is a combination of gauging and measurement. The measuring for machine set up (especially pitch diameter) and gauging for a quick check during manufacturing.
Gordon, I agree with most of this statement. The measurement of the pitch diameter is important during machine set-up. Monitoring production with screw thread gages is vital during manufacturing. That said, the making of a "perfect" thread need not be attempted because it is virtually impossible.
Regardless of all that, tools to measure threads abound, and making a better one is always a good thing to accomplish.
G
Gordon Clarke
I've finally managed to write what I promised and it's in the enclosure/attachment. Wayne, I agree more or less with what you write. The "more or less" is due to the different ways we approach thread inspection.
From your point of view I can't imagine a company manufacturing threaded components without thread gauges ;)
G
Gordon Clarke
Wayne (gageguy) gave me a few suggestions as to how i could improve my attachment so here is the updated, and hopefully improved, version.
Thanks Wayne :applause: :thanx:
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Free iPhone app - Screw Thread Calculator After Work and Weekend Discussion Topics 0
S Screw Thread Go and No Go Gauge Standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A STI (Screw Thread Insert) Thread Gauge-use Before or After Insertion? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
H Runout Measurement of a shaft with screw thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Wayne User's Manuals for Variable Screw Thread Measurement Systems General Measurement Device and Calibration Topics 1
Wayne BECO Taper Screw Thread Specifications Document Control Systems, Procedures, Forms and Templates 6
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
G Screw Thread Inspection Methods Manufacturing and Related Processes 1
G Practical Screw Thread Information & Tolerances General Measurement Device and Calibration Topics 98
J Screw Thread Inspection Standards? Double Ended Stud Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
H Pedicle screw system Conformity Assessment Other Medical Device Related Standards 2
B M85049 backshell strain relief screw torque Manufacturing and Related Processes 1
R Validation for Anodizing titanium orthopaedic screw Other Medical Device Related Standards 2
D FDA Test requirements for a General Pedicle Screw vs. Shank Screw Other Medical Device and Orthopedic Related Topics 1
A Help with acceptable screw gage values per standard BS 919 for Go/ No Go gage General Measurement Device and Calibration Topics 4
M What is a PHP screw? M2 x 10 PHP screw SS Manufacturing and Related Processes 11
P Question About Flat Head Screw Specification Design and Development of Products and Processes 2
Marc Time Warner - Bandwidth Cap Screw - Beware Internet 'brown-outs'? After Work and Weekend Discussion Topics 2
A Validation of bone screw manufacturing process Other Medical Device and Orthopedic Related Topics 9
ScottK Screw Machine Stock Users - Increase in bent bars on receiving? Manufacturing and Related Processes 9
T Orthopeadic products Sterilization Location (bone screw, plates, bolts, etc.) ISO 13485:2016 - Medical Device Quality Management Systems 5
S How to Calibrate or Verify Screw Pitch Gages General Measurement Device and Calibration Topics 16
P Poka Yoke For Breaking Screw Tap Manufacturing and Related Processes 26
J Maximum bend allowable tolerance on a three and a half inch truss head machine screw Manufacturing and Related Processes 4
apestate Is a component of a pedical screw system considered a finished medical device? ISO 13485:2016 - Medical Device Quality Management Systems 4
Wes Bucey A High Reliability Manager's Nightmare - The Lost Screw Reliability Analysis - Predictions, Testing and Standards 11
Geoff Cotton ISO 6H Go Screw Plug Gauges Calibration to ANSI / B1.16M vs BS 3643 General Measurement Device and Calibration Topics 5
T Pin gage identification in a small CNC/Screw machine job shop General Measurement Device and Calibration Topics 9
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
