Seeking advice on Recurring Findings with Different Causes
bookcat
I need some advice related to the recurring findings. Although process owner performs root cause analysis, correction, and corrective action, almost every audit they always have non-conformity on cash overages/shortages and stocks inventory overages/shortages. They said that the issue is the same but we cannot consider them recurring because the causes are different.
Sme background information.
First visit
Nonconformity: stocks inventory shortages
Root cause: Not following procedure
Corrective Action: Retrain
Auditor verified that corrective action was effective for a period of time therefore, issue was closed.
Second visit
Root cause: shortage due to shoplift
Corrective Action: Close monitoring
Third visit
Nonconformity: stocks inventory /shortages
Root cause: Not clear procedure
Corrective Action: Revise the procedure
Auditor verified that the Procedure was revised and being implemented therefore, issue was closed.
Fourth visit
Nonconformity: same problem
Root cause: different cause
Corrective Action: appropriate to root cause
.......so on and so forth..........
My questions are:
1) Is this a recurring audit finding as far as ISO 9001 is concerned?
2) If shortages are common and taking any action is very hard to be effective against the situation, then can we charge the shortages to them without calling out nonconformity instead?
I would greatly appreciate any advice on this tough situation?
Randy
Yep, bandaid solutions...what do all these have in common?
What can cause a shortage....Have you looked at internal sticky fingers yet?
How about skimming inventory prior to stocking? Inventory comes off truck with one number and the inventory is shorted at stocking with a smaller quantity but the higher one is reported...Very old tactic (I used to work Drug Diversion as a cop....Pharamacists and Doctors did the exact same thing with scheduled drugs)...I did White Collar Crime investigations as well...
bookcat
Yes, we are looking at it as well.
It’s hard to pinpoint the culprit because there are more than one personnel in that area and there are three shift schedules in a day. I think they do the inventory at the end of the day due to large volume of stocks. It is even harder if there is connivance among warehouseman, inventory staff, cahier, and supervisor.
I'm guessing that you have not found the ROOT cause yet. It will keep returning until you do.
Maybe, yes. I agree that the issue will keep returning until we found the root cause and do appropriate corrective action.
Maybe not. They possibly found the root cause. The corrective action is not effective either due to non-consistent implementation, or like what former police officer Randy said, there might be internal sticky fingers.
somashekar
Just as a sidenote ...
Are you also pretty sure that the counting / stocktaking mechanism that reports the inventory shortage is correct and the best for you to rely upon ...
bookcat
Actual/physical count is being done manually and the result is being logged in a computerized system.
somashekar
If manual, If marginal shortages, If small parts and in large numbers, If seen in random parts, then it is your system limit as manual system has its limit.
Look at using some good and precision counter weigh scale.
If your system can permit for C class parts to have cushion, then a +/- of 0.1 or 0.2 % can be absorbed as correct inventory and not mark same as shortage.
bookcat
At first, we established tolerance level considering small marginal shoratages especially unintentional or coudn't be avoided errors. Unfortunately, as we move forward, the shortages are hitting beyond tolerance level.
jerry_Malaysia
If this shortage issue will leads to "ability to meet customer requirements in terms of quality, lead time and cost", it will be a big issue. Customer would not be very happy if they find out this. It may affect future contract not to be awarded to your organization. Therefore, comprehensive plan should be establish which shall include root cause analysis and effective temporary and permanent corrective action
:2cents:
M Seeking advice regarding use of off-the-shelf (OTS) batteries Other Medical Device and Orthopedic Related Topics 4
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S Zyglo Fluorescent Dye for Leak Testing - Sloooooow acting - Seeking advice Reliability Analysis - Predictions, Testing and Standards 4
smryan Analytical Scale - Seeking brand and buying advice General Measurement Device and Calibration Topics 7
G Seeking advice on Display norms of Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
smryan Seeking advice for statistical data that will be worthwhile Quality Tools, Improvement and Analysis 29
N STED vs. CE /FDA etc - Seeking advice ISO 13485:2016 - Medical Device Quality Management Systems 3
D How to Benchmark? Is Benchmarking of any value? Seeking advice Benchmarking 34
A Linearity and Bias Study - Bias Study fails - Seeking advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Warehouse Internal Audit - Seeking Tips and Advice Internal Auditing 17
G Slow electronic documentation system - Seeking advice Document Control Systems, Procedures, Forms and Templates 2
O Vigilance System - Seeking example Procedure and Implementation Advice ISO 13485:2016 - Medical Device Quality Management Systems 4
P Supplier Performance Issue - Seeking Advice Supplier Quality Assurance and other Supplier Issues 7
G Starting A New Job - Seeking good advice for me as I walk in the door Career and Occupation Discussions 7
J I'm Back - Working From Home - Seeking Advice and Suggestions Career and Occupation Discussions 15
S APQP Timetable - The stage to producing a sample - Seeking Advice IATF 16949 - Automotive Quality Systems Standard 5
H NCR (Nonconformance Report) - External customer - Seeking Advice Nonconformance and Corrective Action 9
S Software Validation Training - Medical Devices - Seeking advice on outside trainers Training - Internal, External, Online and Distance Learning 3
T Developing TS-16949 Internal Audit Schedule - Seeking Example and Advice Internal Auditing 9
A Seeking GR&R study advice - Batch Cycle Time Reduction in Lead Refinery Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C How to become a good SQA (Supplier Quality Engineer) - Seeking advice and resources Supplier Quality Assurance and other Supplier Issues 7
E Software Freeware write in ASP for Quality System - Seeking advice Quality Assurance and Compliance Software Tools and Solutions 4
U AS9100 Documentation structure and details - Seeking Advice Document Control Systems, Procedures, Forms and Templates 3
K Transition from ISO9001-2000 to TS16494 - Small Business Seeking Advice and Help IATF 16949 - Automotive Quality Systems Standard 4
F Project Management book - Seeking advice and recommendations Book, Video, Blog and Web Site Reviews and Recommendations 2
G 8.1.2 - Knowledge of basic statistical concepts - Seeking Training Advice Training - Internal, External, Online and Distance Learning 6
A GM's GP-12 Training - Seeking advice on training providers Customer and Company Specific Requirements 7
Q My company needs a new Quality Policy - Seeking Advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Seeking Advice on Manuals and Books on Implementing a TS16949 system Book, Video, Blog and Web Site Reviews and Recommendations 3
H Flow chart to show the various paths a job can travel - Seeking Advice Document Control Systems, Procedures, Forms and Templates 7
L Seeking Advice on Starting a Consulting Service Consultants and Consulting 17
P Seeking Training Advice: Cycle Counting Training - Internal, External, Online and Distance Learning 7
S Contingency Plans - Seeking Example and Advice QS-9000 - American Automotive Manufacturers Standard 11
J Seeking: FMEA (Failure Modes Effects Analysis) Training Advice Training - Internal, External, Online and Distance Learning 10
S TS 16949 Internal Audit Scheduling - Seeking Advice Internal Auditing 10
A Seeking advice about what I have to do before we're ready for a certification audit IATF 16949 - Automotive Quality Systems Standard 3
E Terminated - Job Seeking Advice and Discussion - Over 200 Posts with Advice Career and Occupation Discussions 204
I FMEA - DFMEA Software - Seeking Advice Quality Assurance and Compliance Software Tools and Solutions 3
M Design for Manufacturability (DFM) Software - Seeking advice Design and Development of Products and Processes 2
J Seeking Advice - Effective QMS Software for Controlling Audits, Documents etc.? Quality Assurance and Compliance Software Tools and Solutions 19
P Seeking advice regarding missing and cross threaded bolts Manufacturing and Related Processes 6
M FMEA and Control Plan Software - Seeking advice Quality Assurance and Compliance Software Tools and Solutions 12
normhowe Seeking a De Novo Consultant Paid Consulting, Training and Services 7
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
A ISMS - Seeking VAPT Consultant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
K Seeking ISO 13485 Registrar Recommendations Registrars and Notified Bodies 15
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
